hatever happened to engine colors? Every manufacturer had their own specific hue. Orange, blue, red, gold…there were lots of options. Purists get serious about it too. If you’re going to pop the hood at a car show, the color better be right.
At the risk of sounding partial to the classics, I’m going to say I miss those days. The majority of the engine blocks were clearly visible, and air cleaners, brackets, braces and pulleys all had a nice finish, only to be topped aesthetically on performance models with chrome-plated air cleaners or valve covers.
Under the hood, there was something nice to look at, adding incentive to clean and degrease the engine on a regular basis. If you were from my generation, when you got a new (used) car, one of the first things you did was clean the engine and engine compartment. Having a clean mill under the hood was just an extra way to take pride in your car.
Open the hood on today’s cars and you get plastic, then more plastic. Finished in less-than-exciting flat black, with the occasional glimpse of an aluminum cylinder head, there’s just not as much to get excited about when it comes to cleaning your engine. But, is it important? You bet.
There are plenty of theories surrounding whether or not it can affect the performance, and even question if a clean engine will run cooler. The fact is neither is true. I always think my cars run better after waxing them, but I know that’s scientifically impossible, so I chock that up to the car’s “soul.” I’ve never experienced a situation where a dirty engine makes it run worse. Engines just don’t care.
Some might argue that layers of grease and grime can prevent heat dissipation from the engine, and while you could probably prove that scientifically, in practice, it makes no difference. If there is reality to that, it would be in such minor fractions of a degree that it simply wouldn’t matter.
Where it does matter is that leaks, both coolant and oil, are the primary contributors to a dirty engine. The fluids themselves build up and coat the engine, as well as other parts of the car depending on the severity of the leak, and this creates many problems. One, it makes it difficult to find the source of the leak. As a technician, there are times when an engine is so dirty, you have to clean it first before you can pinpoint a leak.
The other consequence is these fluids getting onto other components. Oil wreaks havoc with rubber, and can soften coolant hoses, engine mounts, belts, weatherstrips and even electrical connector weather seals. Finally, the oil buildup traps dirt and before you know it you can have a thick layer of oily, greasy grime that will come off in huge chunks.
A little dust never hurt anything, but it’s amazing how much “stuff” comes up off the road and settles in the engine compartment. Dirt, rocks, asphalt, leaves, you name it, it will find a way in. The problem with debris is that it can fall into the engine when replacing things like spark plugs or valve cover gaskets, or even when doing something as simple as the air filter or adding oil. There’s a lot of damage that can occur if this happens.
The final benefit to cleaning your engine is it allows you to evict any rodents that may be residing in one of the many cozy spots under the hood, just waiting to chew their way into an expensive repair.
So, when your customer asks about cleaning an engine, not only can you give them good reasons, but you can offer them solutions and know-how to ease their concerns about the often-told story of cleaning an engine and experiencing a no-start situation afterward. With a few simple precautions, they won’t have any trouble.
My starting point begins with access. On most vehicles today, there’s almost always a plastic cover on the top of the engine, which I might mention hides a lot underneath, and the engine is often dirtier than you realize. I remove all of these covers, and if the vehicle has a lower engine cover, I remove these as well, since they’ll just hold everything you clean off the engine.
The first step in the cleaning process belongs to compressed air and a blow gun. Large amounts of debris such as leaves or the occasional mouse nest can be sucked out with a shop vac, or just grabbed out by hand and thrown away. But a blow gun will take care of all of it. I’m always sure to wear safety glasses and a dust mask, then I work my way from top to bottom of the engine and compartment, blowing out all dust and debris, focusing on areas that typically trap a lot, such as around the spark plugs and intake manifold.
As I work my way down, I blow debris off the frame, suspension and body parts that are accessible, and also off the top of the transmission, since it will trap a lot. Finally, I blow out the radiator and condenser fins (which by the way CAN affect engine temperature and A/C performance). You’d be surprised how much dirt comes out of these.
With the bulk of the debris removed, it’s time for degreaser. The first step here is to cover any electrical components that will be affected by water, such as the alternator and distributor, if equipped, as well as the intake duct for the air cleaner, or any exposed air filter. I use plastic disposable grocery store bags for this. Keep in mind two things here. One, most things are sealed up, and it’s not uncommon to have water splash up when you drive in the rain. Cars are built to handle this. But two, this is just incidental water splashing and nothing is meant to have pressurized water sprayed at it, sealed or not, so as long as you cover electrical components, and don’t spray directly at any of them, you won’t have a problem. Just be careful with high-pressure power washers.
Now it gets simple. I put cardboard under the car to collect the drippings that are about to occur, then spray the engine, as well as surrounding components with degreaser, and let it soak. It’s always a good idea to read the instructions for the degreaser to beware of any damage it could cause to anything such as the vehicle paint. After the degreaser has had time to soak, I use a cleaning brush to scrub the excessively dirty areas, and, in some cases, a scraper may be required when there’s a lot of buildup.
I tend to use a second application of degreaser, and let it soak, then scrub some more before rinsing it off. Then, I remove the cardboard and put a large plastic tub underneath to catch the big clumps of grease that may wash off. When rinsing things, I use light spray around electrical components, and limit the full force of the hose nozzle to the block, heads and intake, or anywhere there’s serious grease removal.
A final trick I use is to hook up the hose to hot water, when possible. If you have a utility sink, you can get adapters that allow you to do this. Hot water makes a huge difference in cutting through the grease, but you’ll use a lot of it, so if you’re at home, I never start the job just before someone needs a shower, or you might end up in a different type of hot water.
With everything cleaned up, remove all the protective plastic coverings, blow off any excess water that’s puddled up anywhere, reinstall any covers you removed, and you’ve just done your car a favor.
Why wait for the occasional customer who asks about cleaning their engine? Spring cleaning is good under the hood, too. Latex gloves, dust masks, safety glasses, engine degreaser, cleaning brushes, a blow gun, hose nozzle, plastic tub, absorbent mats and shop rags are all great supplies you likely have in stock. Finish it off with some microfiber towels and a spray detailer to wipe any surround paint surfaces, just in case any solvents splash out.
    • By ctplg
      How To: Clean Battery Terminals
