      Do you know how to correctly install a new vehicle battery?
      Selling the Upgrade
      Bottom Line for Counter Pros
      link hidden, please login to view N.A announced the expansion of its aftermarket portfolio with 13 new belt drive SKUs that offer application coverage for over 5.2 million vehicles in operation (VIO).  A news release from
      link hidden, please login to view said the latest product expansion “brings innovative solutions designed to meet the evolving needs of modern vehicles and repair technicians. The upgraded components enhance efficiency, simplify installation and reduce inventory complexity for distributors and shops.” The company’s new product lineup features:
      Three pulleys covering over 2.1 million VIO. Seven overrunning alternator decouplers (OAD) spanning over 860,000 VIO. Three belt tensioners covering over 2.2 million VIO, now featuring advanced engineering upgrades for improved performance and ease of use. “It is essential that shops have access to reliable, OE-equivalent aftermarket parts as vehicles become more advanced. With 11 of the 13 new SKUs being first-to-market and OE-engineered, we’re giving technicians access to solutions that weren’t previously available,” said Ana Maria Lopez, product application manager at Litens Aftermarket N.A. “This is about staying ahead of industry complexity and ensuring shops have the right parts when they need them.”
      All new SKUs are available now through
      link hidden, please login to view distribution network, with additional product expansions planned throughout 2025, the company said.
      ✔️ Poor Fuel Efficiency
      ✔️ Starting Problems
      ✅ Final Thoughts
