Incorrect Catalog Search Results May Be Your Fault
By OReilly Auto Parts
SPRINGFIELD, Mo., Feb. 05, 2025 (GLOBE NEWSWIRE) -- O’Reilly Automotive, Inc. (the “Company” or “O’Reilly”) (Nasdaq: ORLY), a leading retailer in the automotive aftermarket industry, today announced record revenue for its fourth quarter and full-year ended December 31, 2024. The results represent 32 consecutive years of comparable store sales growth and record revenue and operating income for O’Reilly since becoming a public company in April of 1993.
