This article, contributed by Tom Cook, is courtesy of
All companies engaged in the global supply chain seek to lower the “landed costs” on their goods in imports and exports sales, purchasing and operations.
While there are numerous components that make up “landed costs,” duties, taxes and tariffs are a huge factor and can often be a detriment to global trade.
Duties, taxes and tariffs are costs borne by the importer as the goods enter a country. These fees are assessed by the country’s local customs authority. In the USA, this is the U.S. Bureau of Customs Border and Protection (CBP).
These fees are determined by what the product is and where it is from. The “what” is known as the HTS (Harmonized Tariff Schedule) and the “where” is the actual origin country of the product.
While some of the guidelines are standardized from one country to another, we must understand that the customs rules and their interoperation often vary differently from one country to another. Sometimes the differences are slight and in other countries the differences are huge.
The importer of record (IOR) has the primary responsibility to determine the correct HTS and origin upon entry of the goods for customs clearance in the country of import.
Most importers utilize the services of freight forwarders, customhouse brokers and/or 3PL’s to provide these clearance services, as well as rely on their expertise to accomplish the clearance process in a successful and compliant manner.
Importers may also obtain the assistance of these service providers in determining the correct HTS classification and
the origin.
Importers are legally responsible to exercise:
• Due Diligence
• Reasonable Care
• Supervision & Control
These standards are the responsibility of the importer of record (IOR). If the IOR outsources the responsibility to a customs broker, under the “supervision & control” standard, the IOR is still responsible for supervising and controlling for the statements and information provided by this third-party on their behalf.
This standard requires the importer to have a working knowledge of the import regulations and be able to properly supervise their outsourced provider.
Customs recognizes that an importer may need guidance in the clearance process. This may be received from CBP, a qualified consultant, a customs attorney or a practitioner that has expertise in customs regulations.
It is critical to understand the steps in managing duties, taxes and tariffs. The first is to understand how the import regulations apply, followed by learning what measures can be taken to mitigate the risk and cost associated with duties, taxes and tariffs. If the origin and the classification are the controlling factors, it is important to understand that this is where the answers lie to mitigation.
For example, Section 301 tariffs on certain goods exported from China into the U.S. may add as much as a 25% surcharge to the import landed cost. This resulted in many companies seeking out alternative sourcing options to avoid this surcharge.
In addressing alternative sourcing options, nearshoring, reshoring and friend shoring – countries such as but not limited to Vietnam, S. Korea, Taiwan, Malaysia – all presented viable options.
In some situations, the acquisition cost may have been higher, but when calculating the landed cost, with the 25% duty eliminated, the comparison demonstrated a viable alternative to the importer.
Companies involved in aftermarket sales, where margins are tight, can benefit from this type of analysis and mitigation strategy.
Another strategy involves the Harmonized Tariff Schedule, or what the product is, from CBP’s perspective.
First, we want to make sure we are utilizing the proper HTS number. It can be possible that the correct HTS number, when changed, will offer a lower duty rate.
Secondly, what we refer to as “Tariff Engineering” is a legitimate manipulation of a product’s design or materials that impacts its classification and potentially lowers the duty rate.
The choice of materials, the functionality of the product, product specifications or qualities all impact how a product is classified.
For example, changing the make-up of the materials utilized in fabrics, such as the mix of cotton, rayon, nylon, etc. will change the classification of a product. Features such as changing the product to be waterproof and adding other qualities may also change the tariff classification and impact the duty rate.
Another example may be how the product is designed; for example, for personal utilization or for commercial application, may have an impact.
How parts and equipment are assembled and utilized can also have an impact on the classification as well as the origin.
The amount of “value-add” in the manufacturing or assembly process can also impact how CBP will view the origin and/or the HTS, therefore directly impacting the duty rates.
Tariff Engineering requires R&D, engineering, and technical support, as well as guidance from trade professionals that can assist in interpreting the import regulations and research prior CBP rulings.
CBP has a great resource called CROSS which is a searchable database of CBP rulings that can be retrieved based on simple or complex search characteristics using keywords and Boolean operators. CROSS has the added functionality of cross-referencing rulings from the initial search result set with their modified, revoked or referenced counterparts.
Rulings collections are separated into Headquarters and New York and span the years 1989 to present. Collections can be searched individually or collectively.
CROSS can be an excellent resource in managing the impact of duties and tariffs on
landed costs.
Duties, taxes and tariffs often emanate from political and economic positions from government offices and agencies.  We witnessed this when President Trump put forward the 232 and 301 Tariffs in his first year in office.
China then secured retaliatory duties. We have seen these similar actions in the EU, Australia, Mexico and Canada.
Personnel in the aftermarket engaged in global supply chain purchasing, sales and operations need to pay attention to the political and economic situations in the countries they do business in, as regulations impacting duties and tariffs change frequently with both positive and negative consequences.
Additionally, trade organizations’ lobbying efforts should be followed with the Executive Branch and Congress. These efforts seek to keep open free trade concepts and minimize the utilization of duties and tariffs as political and economic weapons in global affairs.
Studies have been accomplished that clearly demonstrate the negative impact of tariffs on manufacturing, distribution, and trade costs in the global supply chain.
While many tariffs are designed to protect industries or certain markets, they generally wreak havoc in global trade and have negative impacts.
The automobile industry, its suppliers and ancillary industries such as the aftermarket are significantly impacted by duties, taxes and tariffs.
In controlling “landed costs,” duty and tariff mitigation as outlined above are all good strategies, but there are other options that also should be considered:
• Utilization of Foreign Trade Zones
• Consolidating Transportation Providers and Carriers
• Running annual Freight RFP’s
• Choice of INCO Terms
• Alternative Sourcing
• Free Trade Agreements
• Location and methodology in warehousing, fulfillment, and distribution
• Utilization of Technology
• Demand Planning Systems
In summary, developing strategies in tariff mitigation is a viable solution to duty and tariff management and ultimately lowering landed costs and enhancing your company’s competitiveness in both import and export purchasing
and sales.
Thomas Cook is Managing Director of Blue Tiger International, a global consultancy advising on supply chain management, trade compliance, purchasing, trade and disruption management, global business and logistics. For more information, go to www.bluetigerintl.com. Tom can be reached directly at [email protected].
      link hidden, please login to view N.A announced the expansion of its aftermarket portfolio with 13 new belt drive SKUs that offer application coverage for over 5.2 million vehicles in operation (VIO).  A news release from
      link hidden, please login to view said the latest product expansion “brings innovative solutions designed to meet the evolving needs of modern vehicles and repair technicians. The upgraded components enhance efficiency, simplify installation and reduce inventory complexity for distributors and shops.” The company’s new product lineup features:
      Three pulleys covering over 2.1 million VIO. Seven overrunning alternator decouplers (OAD) spanning over 860,000 VIO. Three belt tensioners covering over 2.2 million VIO, now featuring advanced engineering upgrades for improved performance and ease of use. “It is essential that shops have access to reliable, OE-equivalent aftermarket parts as vehicles become more advanced. With 11 of the 13 new SKUs being first-to-market and OE-engineered, we’re giving technicians access to solutions that weren’t previously available,” said Ana Maria Lopez, product application manager at Litens Aftermarket N.A. “This is about staying ahead of industry complexity and ensuring shops have the right parts when they need them.”
      All new SKUs are available now through
      link hidden, please login to view distribution network, with additional product expansions planned throughout 2025, the company said.
      link hidden, please login to view N.A. announced the promotion of Scott Howat to director of sales and marketing. In this new role, Howat will oversee all sales channels across the region, driving strategic growth and market expansion, the company said. Howat joined Litens in 2022, bringing over 30 years of experience in sales, marketing and product management. Most recently, he served as national sales and marketing manager.
      “As Litens Aftermarket continues to grow across North America, we are committed to ensuring our leadership team reflects our vision for the future,” said John Lussier, president of
      link hidden, please login to view “Scott’s extensive industry experience and strategic approach to sales and marketing make him the ideal leader to drive our continued success and growth.” Over the past two years, Litens Aftermarket said it has experienced significant growth, and this promotion—along with other upcoming leadership changes—is part of the company’s strategic effort to align its internal talent with the areas in which those individuals can deliver the most value. By positioning leaders like Howat in key roles, the company added it is strengthening its aftermarket team and ensuring continued success in an evolving market.
      Throughout his career, Howat made a notable impact while working at the Auto Care Association, Affinia Group, Dana, Echlin and Gates Corporation. Howat holds a Master Automotive Aftermarket Professional (MAAP) designation from the University of the Aftermarket. Additionally, he has served in leadership roles with various industry associations, including as a member of the Automotive Communications Council, member of the Auto Care Association Marketing and Communications Committee, and Chairman of the Marketing Executives Council for the Automotive Aftermarket Suppliers Association (now known as the Motor and Equipment Manufacturing Association), among others, according to Litens.
      *After this statement was released, Mexico President Claudia Sheinbaum announced on X (formerly Twitter) that the U.S. and Mexico have reached an agreement to delay tariffs for a month. In exchange, Mexico will be putting 10,000 National Guard troops on the Mexico/U.S. border as conversations between the countries continue.
      On Saturday, Feb. 1, 2025, President Trump issued
      link hidden, please login to view imposing tariffs on imports from Canada, Mexico and China. The tariffs were implemented under the International Emergency Economic Powers Act (IEEPA), citing a national emergency related to illegal immigration and flow of illicit drugs like fentanyl into the U.S. Bill Hanvey, president and CEO,
      link hidden, please login to view, emphasized the serious impact the proposed tariffs would have on the automotive aftermarket industry, U.S. consumers and businesses: As of the morning of Feb. 3, only the Executive Order for Canada has been officially published on the White House’s website. The Executive Orders for Mexico and China are pending official release; however, unofficial copies indicate they follow a similar framework to the Canada order.
      Key Details of the Executive Order
      IEEPA is a federal law granting the President authority to counter unusual and extraordinary threats to national security without requiring congressional approval or extensive agency review. While historically, IEEPA has been used to impose economic sanctions, this is the first time IEEPA is being used to impose tariffs.
      IEEPA requires the president to “consult” with Congress “in every possible instance” before taking action. While the president can act unilaterally, they must provide regular reports to Congress on the actions taken.
      Tariff Rates and Products
      The Executive Orders do not list specific products subject to the tariffs but states that the tariff applies to all goods which are “products of” these countries.
      The new tariff rates below apply “in addition to any other duties, fees, exactions or charges” applicable to imported products. In other words, these tariffs will be applied on top of any existing import duties or tariffs already in effect.
      Canada: 25% tariff applies to imports from Canada, with energy products subject to a reduced 10% tariff. Mexico: 25% tariff applies to imports from Mexico. China: 10% tariff applies to imports from China. Implementation Date
      The tariffs apply to goods entered for consumption, or withdrawn from warehouse for consumption, on or after 12:01 a.m. Eastern Time on Feb. 4, 2025.
      Goods loaded onto vessels at the port of loading or in transit on the final mode of transportation prior to entry into the United States before 12:01 a.m. Eastern Time on Feb. 1, 2025, are not subject to the additional duty, subject to certification requirements with U.S. Customs and Border Protection (CBP).
      Exemptions
      The Executive Orders do not outline any exceptions nor establish an exemption process. The Executive Order also states that the tariffs will remain in effect until the President determines that the countries have taken “sufficient action to alleviate the crisis.”
      Retaliation Clause
      The executive order states that if Canada, Mexico and/or China retaliate against the United States, President Trump may increase or expand the scope of the duties imposed under this order.
      Drawback
      Drawback (duty refunds) will not be available.
      De Minimis Treatment
      Duty-free de minimis treatment will not be available.
      Responses from Affected Countries
      Canada: Prime Minister Justin Trudeau
      link hidden, please login to view that Canada will impose retaliatory tariffs of 25% on $155 billion U.S. goods. Tariffs on $30 billion will take effect on Tuesday, Feb. 4. Tariffs on the remaining $125 billion will take effect in 21 days. Tariffs will apply to a range of U.S. exports, including alcoholic beverages, agricultural products, clothing, sports equipment and household appliances. The list of products subject to the initial $30 billion in tariffs can be
      link hidden, please login to view. Mexico: Mexican President Claudia Sheinbaum
      link hidden, please login to view that Mexico will implement tariff and non-tariff measures in response to the tariffs. Sheinbaum emphasized the need for bilateral cooperation and called for discussions on trade policy. China: The Chinese government
      link hidden, please login to view the new 10% tariff. China stated that it will file a complaint with the World Trade Organization and is preparing additional countermeasures. Ongoing Monitoring and Member Feedback
      The Auto Care Association is closely monitoring these developments and will share new information as it becomes available. For the latest updates, visit
      link hidden, please login to view. “We welcome your feedback to help us better understand and assess the impact of these tariffs on our industry and businesses,” said the Auto Care Association, “Please share with us by contacting Angela Chiang, director, international affairs, at [email protected].”
      MEMA Aftermarket Suppliers announced it will host a virtual Advocacy Town Hall on January 30 @ 11 a.m. ET, where its Advocacy team will share the latest on policy and legislative efforts that impact the aftermarket, including Right to Repair, tariff developments and supply chain challenges.
      link hidden, please login to view for the chance to stay informed and engage with MEMA’s advocacy work on the issues that matter most to our industry, the organization encouraged. The post
