What appears as one of the most basic tools in your custgomers’ tool box or in your tool corral is far from it. Screwdrivers come in many shapes and sizes, and they are not created equal. The differences in design and manufacturing can add up to a valuable tool you own for life, or one that just takes up space.
This downloadable document features a collection of “screwdriver tips,” including the most common types, things to consider when buying them and ways to get the most out of your tools.
      Why you should empty the master cylinder before bleeding brakes
      Why testing modern sealed batteries takes more than hydrometers and refractometers
      If you’ve ever looked into car engine management systems, you’ve probably come across the terms ECM (Engine Control Module) and ECU (Engine Control Unit). While these terms are often used interchangeably, they are not exactly the same. Understanding the difference between ECM and ECU can help you diagnose vehicle issues, make informed repair decisions, and ensure your car runs efficiently.
      At Clifford Auto Parts, we specialize in high-quality ECMs and ECUs, providing affordable replacements with free shipping across the USA. In this blog, we’ll break down the key differences between ECMs and ECUs, their roles in vehicle performance, and how to know when it’s time to replace them.
      ✅ What is an ECU (Engine Control Unit)?
      The Engine Control Unit (ECU) is a broad term referring to any electronic module that controls various aspects of a vehicle's operation. Modern cars often have multiple ECUs that manage different systems in the vehicle, such as:
      ✔️ Engine Management (ECM) – Controls fuel injection, ignition timing, and emissions.
      ✔️ Transmission Control (TCM) – Regulates automatic gear shifting.
      ✔️ Brake Control (ABS Module) – Manages anti-lock braking systems.
      ✔️ Body Control (BCM) – Controls lighting, windows, and climate systems.
      The ECU acts like the brain of the car, receiving signals from sensors and making real-time adjustments to optimize performance, efficiency, and safety.
      ✅ What is an ECM (Engine Control Module)?
      The Engine Control Module (ECM) is a specific type of ECU dedicated to managing the engine’s performance. It ensures the correct amount of fuel, air, and spark is delivered to keep the engine running smoothly.
      A faulty ECM can cause serious performance issues, including:
      ✔️ Check Engine Light Staying On
      ✔️ Engine Stalling or Misfiring
      ✔️ Poor Fuel Efficiency
      ✔️ Starting Problems
      At Clifford Auto Parts, we offer tested and warrantied ECM replacements for Ford, Dodge, Jeep, Chrysler, and more, ensuring a plug-and-play experience for vehicle owners across the USA.
      ✅ How Do ECM and ECU Work Together?
      While the ECM specifically controls the engine, it still communicates with other ECUs in the car. For example:
      ✔️ The ECM and TCM (Transmission Control Module) work together to ensure smooth gear shifting.
      ✔️ The ECM and BCM (Body Control Module) coordinate engine start functions with security and lighting systems.
      ✔️ The ECM interacts with the ABS Module to adjust power delivery during emergency braking situations.
      Modern cars rely on these interconnected systems to provide seamless driving performance.
      ✅ When Should You Replace Your ECM or ECU?
      If your vehicle is experiencing engine trouble, transmission issues, or persistent warning lights, you may need to replace the ECM or a specific ECU. Some warning signs include:
      ✔️ Check Engine Light stays on, even after repairs
      ✔️ Sudden drops in fuel efficiency
      ✔️ Rough idling, stalling, or misfires
      ✔️ Transmission shifts erratically or gets stuck in a gear
      ✔️ Car fails to start despite a working battery
      Ignoring these symptoms can lead to costly repairs. The best way to diagnose the problem is to use an OBD-II scanner to check for ECU or ECM-related fault codes.
      ✅ Why Choose Clifford Auto Parts for ECM & ECU Replacements?
      At Clifford Auto Parts, we specialize in providing high-quality, reliable ECM and ECU replacements that fit seamlessly into your vehicle. Here’s why thousands of vehicle owners trust us:
      ✔️ Wide Selection: We offer ECMs & ECUs for Ford, Jeep, Dodge, Chrysler, and more.
      ✔️ Lifetime Warranty: All our ECMs come with a lifetime guarantee for peace of mind.
      ✔️ Fast & Free Shipping: Get your replacement within 3 business days, anywhere in the USA.
      ✔️ Affordable Pricing: Save hundreds of dollars compared to dealership prices.
      ✔️ Plug-and-Play Compatibility: Our ECMs are programmed and ready to install.
      Don't let a failing ECM or ECU slow you down! Shop today at link hidden, please login to view for top-quality replacements.
      ✅ Final Thoughts
      Understanding the difference between ECM and ECU helps car owners diagnose vehicle problems, make informed repair decisions, and ensure long-term performance. While ECUs control multiple car functions, ECMs specifically manage the engine’s performance.
      If you're facing engine issues, poor fuel efficiency, or transmission troubles, it may be time to replace your ECM or another ECU module. At Clifford Auto Parts, we provide tested, warrantied, and affordable ECMs and ECUs to keep your vehicle running like new.
      🚗 Need an ECM replacement? Visit link hidden, please login to view today!
      📞 Questions? Call (516) 494-7838 for expert assistance.
      Hunter Engineering has introduced a website that breaks down sophisticated ADAS procedures and terminology into easy-to-understand topics, as a means to help simplify the ever-complicating conversations around ADAS.
      Available for free to access and use, Hunter’s interactive ADAS Learning Tool works on touchscreen tablets or desktop computers. Designed to assist counter workers or allow customers to explore on their own, the tool succinctly answers many of the why, when and how questions both shops and consumers have regarding ADAS calibrations,
      link hidden, please login to view explained. “ADAS has received plenty of attention the past several years, but comparatively little of it deals with talking to actual vehicle owners,” said Tommy Maitz, Hunter director of marketing. “This learning tool will help shops have more informative and effective conversations with their customers about which systems are included on their cars, and the need for calibrations.”
      The tool begins by separating ADAS procedures into four main categories – camera, radar, ultrasound, internal – and provides brief overviews and images for each type to aid with in-person discussions. From there, a user can examine the color-coded vehicle image to learn about the specific functions and locations of ADAS components, and when calibrations would be recommended or required.
      Also included on the page are extensive lists of the names OEMs use for the ADAS systems across their models, color-coded to locations on the image. Although the names vary widely across the dozens of OEMs, the functions usually fall into one of the four main categories, Hunter said.
      “While shops generally know much more about ADAS than their customers at this point, there’s still some confusion and uncertainty when they talk to them,” Maitz said. “This tool is a quick and easy way for everyone to understand the concepts and get on the same ADAS page.”
      For more information, visit
      MANN+HUMMEL announced the parts kit for its MANN-FILTER fuel filter PU 10 023/1 z KIT for pickups makes maintenance easier, thanks to the patented disassembly tool. It offers a very high degree of particle separation and efficient water separation, while also being ideally equipped for future fuel filtration requirements, the company said.
      “Efficient, fast, and clean – this is how the significantly improved handling of the PU 10 023/1 z KIT can be summed up,” explained Frank Bartel, product manager fuel filters at MANN+HUMMEL. This is made possible by the innovative handhold developed by
      link hidden, please login to view, which facilitates disassembly and is included with every filter, and by the modern and functional design of the filter element and housing cover. Changing the filter without this grip, however, requires a lot of force and is only possible with pliers or similar tools. Resistant to Dirt and Water
      “The innovative filter has an extremely high separation efficiency of more than 96 percent with a particle size of four micrometers,” MANN+HUMMEL said. “This means that 9,600 out of 10,000 incoming particles are retained. For context, these particles are up to 25 times smaller than a human hair.”
      It is not only impurities that can have a negative effect on the components of the injection system, but also water droplets. This applies particularly to modern common rail systems, which place high demands on fuel quality. The MANN-FILTER PU 10 023/1 z KIT filters out more than 95 percent of the water contained in the fuel and operates in three stages, the company said.
      In the first step, the filter medium reliably removes solid impurities from the diesel. The second filter stage works with a coalescing fleece that absorbs the finest water droplets from the fuel/water emulsion and combines them into much larger droplets. In the third filtration step, a water-repellent screen fabric ensures that the enlarged droplets do not enter the injection system. MANN+HUMMEL said it has developed this screen fabric in such a way that it is elastic and can withstand the mechanical requirements of pressure and temperature both during operation and at standstill. Bartel explains: “Thanks to its flexible design, it can effectively absorb the forces that arise and so has proven to be particularly robust, including in situations such as when the fuel freezes.”
      The seal materials of this fuel filter are resistant to standard diesel, biodiesel variants, and novel synthetic diesel fuels such as hydrogenated vegetable oils (HVO). They have the corresponding OE approvals and ensure a permanent hold as well as the complete sealing of the filter.
      Series Supplier
      link hidden, please login to view said it has already started series production of this highly efficient fuel filter for a renowned vehicle manufacturer. The filter is available on the independent automotive aftermarket in original equipment quality as a PU 10 023/1 z KIT for various Ford Ranger pickup models and complements the extensive MANN-FILTER product range. MANN+HUMMEL has been granted a patent for the disassembly handhold by the German Patent and Trademark Office as well as in other countries. Worldwide, more than 1,200 researchers and developers at MANN+HUMMEL work on pioneering solutions with the aim of creating real added value and optimally meeting customer needs, the company said.
