In this two-part series, we’re looking at why batteries fail, especially during extreme weather. We know extreme temperatures can be tough on automotive batteries. But there are other factors that can cause batteries to fail any time of year.
Counterman Magazine:
The Network:
      ✔️ Poor Fuel Efficiency
      ✔️ Starting Problems
      ✅ Final Thoughts
      Bosch Mobility Aftermarket announced the re-launch of its passenger car and light duty truck battery offering, now known as the Bosch Premium Battery Program. The company said this revitalized program embraces a new name emphasizing its exclusive focus on premium batteries and includes new stock-keeping units (SKUs) for the Bosch S5 Premium Power Flooded Batteries and the Bosch S6 High Performance AGM Batteries.
      “This emphasized focus on premium batteries, with 90% market coverage, guarantees shop owners and end-users alike will confront less complexity in our battery line, while enjoying greater inventory efficiency,” said Dennis Krob, senior product manager at
      link hidden, please login to view. “We’ve been listening to customers and understand these two areas are critically important in today’s market. We’re proud to be refreshing our offerings at a premium level to meet these demands, while helping drive business and streamline operations.”
      link hidden, please login to view said it will expand its portfolio of S5 Premium Power Flooded Batteries by 13 new SKUs. These batteries boast a three-year warranty and provide dependable starting power, a long service life and reduced risk of acid leakage in newer car models with high electronic demand. The new program also includes three new SKUs for the Bosch S6 High Performance AGM Batteries. According to the company, these batteries promise a lifespan up to two times longer than conventional alternatives and provide consistent, optimal power for start-stop vehicles and models that use regenerative braking. The S6 batteries offer a warranty guaranteeing free replacement for four years after the date of purchase.
