After its initial U.S. launch in October 2023, UniClutch said it is expanding its North American footprint with two additional SKUs – 4Terrain and Track – “to enhance how enthusiasts can experience this one-of-a-kind clutch product.”
Compatible with the UniClutch Flex Fit Installation system, existing UniClutch owners can upgrade to the new range-topping models by swapping in the new Track or 4Terrain core unit.
With the second iteration of the UniClutch system, the brand is reaching even more drivers.
UniClutch Track
Track holds up to 1,450 foot-pounds of torque capacity with a heat-resistant ceramic dual core; lightened chromoly billet cover assembly; and a stronger quad drive sprung dampening system to handle punishing motorsport use, “while still being street-able,” according to the company.
“Tested with pro drift drivers and circuit racers, it’s great for any motorsport discipline or professional use,” the company said. “The Track ICT variant introduces an innovative intercooler for a further (up to) 40% reduction in heat, perfect for muscle cars and other applications developing massive torque at very low RPM.”
UniClutch 4Terrain
4Terrain stands out due to its heat dissipation designed for 4×4’s, featuring ICT intercooler technology, according to
“This innovation reduces fade, sustaining more slippage during extreme off-roading conditions, allowing drivers to maintain control and performance even in the harshest environments,” the company explained.
Together with a new quad drive sprung 4×4 dual core featuring an upgraded friction composition, 4Terrain boasts 1,450 foot-pounds of torque capacity and an anti-corrosion, anti-flex, heavy-duty billet steel cover assembly.
The entire UniClutch line is retailing at select NAPA stores across the United States and at
Create an account
Register a new account
Sign in
Sign In Now
      Standard Motor Products, Inc. (SMP) announced it continues to add to its line of kits. Standard and Blue Streak offer Kits and Multipacks in a variety of categories. Among its most popular are Blue Streak GDI High-Pressure Fuel Pump Kits and Ignition Coil Multipacks, the company said. Blue Streak GDI High-Pressure Fuel Pump Kits help technicians solve low-fuel-pressure symptoms by replacing all components at once to ensure a complete repair,
      link hidden, please login to view said. These kits include an all-new high-pressure fuel pump, cam follower, the required seals, and mounting hardware. Ignition coils can lose spark energy over time, causing poor fuel mileage and reduced performance and if one coil fails, it is likely the others are on track to fail. Blue Streak Ignition Coil Multipacks include a full, matched set of new, better-performing coils, saving time, restoring performance and reducing comebacks. SMP said other popular kits include complete Standard Turbocharger Kits, Oil Filter Housing Kits, and Fuel Injector Multipacks and Blue Streak Blower Motor Resistor Kits, Camshaft and Crankshaft Sensor Kits, Variable Valve Timing (VVT) Service Kits and VVT Solenoid Kits. In the past two years, specific Blue Streak Kits have been awarded the Best New Product of the Year and Best Problem-Solver by the Import Vehicle Community, a community of the Auto Care Association.
      New coverage has recently been introduced across many of these categories, according to SMP. Blue Streak GDI High-Pressure Fuel Pump Kits have been released for 3.7 million General Motor vehicles, like the 2019-16 Chevrolet Cruze, 2019-18 Chevrolet Equinox, and 2019-18 GMC Terrain. Standard Oil Filter Housing Kits are new for multiple popular makes and models, including the 2024-19 Jeep Grand Cherokee, 2024-19 RAM 1500, 2024-19 Dodge Durango, 2016-11 Volvo S60, and more. Blue Streak Cam and Crank Sensor Kits have been released for a variety of popular Ford vehicles, and Standard Turbocharger Kits are new for Ford, Volvo, and General Motors vehicles like the 2019-16 Chevrolet Cruze and Buick Encore, SMP said.
      Commenting on the expansion, John Herc, vice president of vehicle control marketing at
      link hidden, please login to view, said, “Parts professionals are looking for more complete kits and multipacks for a number of reasons. First, it helps technicians perform a complete repair without having to chase parts from multiple places. Additionally, service writers find it easier to explain one line item on an invoice rather than a list of parts. Whatever their reason, they look to Standard and Blue Streak for complete repair solutions.” The post
      Dayco, a supplier of engine products and drive systems for the automotive, industrial and aftermarket industries, is expanding its timing chain kit line with 41 part numbers to cover another 49 million vehicles in operation (VIO). Additionally, the company is introducing the next generation of its AutoPartIQ inventory assessment tool—with new features for a more productive customer experience.
      New Parts Bring Timing Chain Kit Coverage to 120+ Million
      Dayco’s aftermarket team launched the line in 2022 due to the car parc shift from timing belts to timing chains at the OE level. The
      link hidden, please login to view, which feature OE-quality components, cover high-volume light-duty engine applications. They include all the necessary components for a thorough and complete repair, building on Dayco’s mission of recommending system replacement as a best practice. Dayco says the kits include: Timing and secondary chains that prevent stretch for the life of the kit – and address the no. 1 replacement issue; Precision-machined cam and crank sprockets for quiet, noise-free performance; Direct fit OE-quality, high-grade plastic guides, as well as VVT solenoids and cam phasers when the application calls for it; and Packaging that features a QR code that links directly to detailed installation instructions. Dayco backs its entire timing chain kit line with an industry-leading two year or 60,000 mile (96,000 kilometer)  link hidden, please login to view, whichever occurs first, giving technicians confidence in what they’re installing. Three of the new part numbers are already available, and the remaining 38 are scheduled for Q1 or Q2 2025.
      “We entered the timing chain kit market to meet the needs of our customers. The line continues to grow with sales increasing year over year and we are supporting our high-quality product line with important investments in warranty and training material,” said Tom Tecklenburg, Vice President, Aftermarket, Dayco North America. “We encourage our customers as well as shop owners to reach out to our tech team to schedule virtual training and to learn more about this line if they aren’t already stocking it.”
      link hidden, please login to view announced the company has expanded product coverage for its starter and alternator, brake caliper, brake pad, brake shoe, power brake booster and brake rotor programs, with 505 new part numbers covering 302 million vehicles in operation. The new part numbers are offered through QB, Quality-Built, Quality-Built Black Series and Pure Energy brands powered by
      link hidden, please login to view, which serve the professional installer market. A select list of late-model part number introductions can be found link hidden, please login to view. A complete list is available by contacting a Motorcar Parts of America sales representative. “In addition to our private label offerings, our Quality-Built and Pure Energy products are steadily gaining momentum in the professional market, and the introduction of new part numbers underscores our proactive approach to developing, cataloging, and distributing products to meet evolving demand,” said Jamie Cook, senior vice president of sales and marketing.
      link hidden, please login to view announced the launch of 20 new products in North America. The new part numbers include complete strut assemblies and shock absorbers, representing nearly 8 million vehicles in new coverage. The launch includes coverage for light vehicles like the Hyundai Sonata, Mercedes-Benz C-Class and Subaru WRX, in addition to popular pickup truck applications, including the Ford F-150, Chevrolet Silverado and the Dodge Ram 1500, among others, according to link hidden, please login to view. “We are continually launching aftermarket products using the same high-quality components as our original equipment offerings,” said Bruno Bello, director of global marketing at PRT. “These new items not only expand our portfolio but also strengthen our presence in North America. The new products are in stock and ready to ship!”
      For more information, call 1-770-238-1611, visit
      link hidden, please login to view announced the release of an expanded range of timing chain kits and components for Q3 2024. The company said this latest product launch provides aftermarket solutions for a broad selection of popular vehicle makes and models. Cloyes said this quarter’s new offerings include comprehensive timing chain kits for Ford and Subaru vehicles. They’re designed to support Ford models such as the F-150, Mustang, Expedition and Transit, with engine sizes ranging from 2.7L to 3.7L. Subaru models, including the Forester, Impreza, Outback, and BRZ, are also covered, with kits tailored for 2.0L and 2.5L engines.
      Cloyes further expanded its product line with new timing chain kits for Mercedes-Benz and Mazda vehicles. Mercedes-Benz kits are designed for the 2.1L and 2.7L engines found in models such as the E250, GLE300d, and Sprinter vans. For Mazda, owners of vehicles such as the Mazda 3, CX-5, and MX-5 Miata can benefit from Cloyes’ new timing and oil pump chain kits, the company said.
      In addition,
      link hidden, please login to view now offers expanded coverage for Hyundai, Kia, and General Motors vehicles. The new kits support popular Hyundai and Kia models like the Sonata, Optima, Santa Fe and Sorento, with engine sizes ranging from 2.0L to 2.4L. For GM, Cloyes has introduced timing chain kits for 1.4L and 1.5L engines in models such as the Chevrolet Spark, Malibu, and GMC Terrain. Cloyes said each kit is engineered for optimal engine performance and includes a variety of essential components such as timing chains, accessory drive belts, variable valve timing (VVT) components and water pumps, where applicable. The company added that the kits “provide all necessary timing and oil pump chain system components to ensure long-lasting, efficient engine performance, meeting or exceeding OEM standards.”
