Filtration and Lubrication Concerns When Pressurization Symptoms Occur the Oil Filter Is Often Blamed
When filters bulge, gaskets blow, or filters dislodge from their mounted position on the engine, the oil filter is almost always blamed. Some install the second or third filter still convinced the filter is the cause. The filter is the victim, as over pressurization is the reason for the event and these issues have plagued […]
      Selling the Upgrade
      Bottom Line for Counter Pros
      A Dynamic Kickoff
    • By Mighty Auto Parts
