One of the more difficult things about any technology is all the new terms you seem to get hit with, and in the automotive world, CAN bus was one of those terms. The second half, “bus,” was a term we had already used for many years, primarily as “bus bar.” A bus bar was a metal strip or bar that distributed power among multiple components.
In the automotive world, even when fiber-optic turn-signal indicators mounted on the front of a fender were as high-tech as it got, bus bars were inside many components such as fuse panels and relays, and sometimes under the hood for various engine electronics.
Then computer electronics took over. At first, we just had one electronic control unit (ECU) to deal with, and it was for the engine. Before you knew it, there was a transmission control unit, then the ABS control unit (not necessarily in that order). Wiring harnesses got bigger … and bigger and bigger.
Today, a car can have as many as 150 ECUs. In addition to the familiar engine, transmission, brake and airbag control units, doors, seats, mirrors, power steering, audio systems, cruise control, batteries and charging management systems all have their own control units. And as you can imagine, that’s just scratching the surface.
As technology was taking a ride with all these systems, engineers realized there were too many wires and too many sensors. There was no choice but to get aboard the CAN bus. CAN stands for controller area network, and a CAN bus, simply put, is a common communication line that can be used by all ECUs on the network.
The various control units on a modern vehicle need to communicate and share information over this network. Here’s an example of how and why. Years ago, when you turned on the air conditioning, a simple switch sent power to the compressor clutch. Today, the HVAC control module may need to communicate with the body control module (BCM) to notify it that A/C has been requested.
The BCM in turn sends a request to the engine control module (ECM) to “ask permission” if it can energize the A/C-compressor relay. The ECM looks at current engine operating parameters and sends a response signal to the BCM, which, in turn, sends a signal to the A/C relay.
The technological features on today’s cars are nothing short of impressive. Advanced driver-assistance systems (ADAS) include features such as adaptive cruise control, forward collision warnings, high-beam safety, lane-departure warnings, traffic-signal recognition, lane-keep assistance, automatic emergency braking and traction control.
All of the associated control units are in constant communication with each other, and since many of them must utilize information from the same sensors, through the CAN bus network this is possible. Instead of an ambient-temperature sensor for the ECM, the HVAC control unit and the instrument cluster, one sensor can share its data over the network.
Some high-end vehicles have a feature called automatic brake wiping, or brake disc wiping. This feature utilizes information from a rain sensor (also used by automatic windshield wipers) that’s sent over the CAN bus to the ABS control unit. In programmed intervals, the ABS control unit lightly applies the brakes in a manner that the driver won’t notice, to clear water and moisture away from the rotors and provide maximum braking when needed. All of this is only possible thanks to the communication available over the CAN bus.
Developing the CAN bus system was no simple feat, and it took many years to complete. The requirements for automotive CAN bus communication are standardized as part of the OBD II vehicle communication standard. There have been many changes over the years related to CAN communication, primarily affecting the speed and manner in which data is transmitted. The easiest way to think about it is to relate it to the changes over the years in USB design we’re all familiar with. It’s for the same reason. They transmit data quicker.
From a service standpoint, technicians have had to become familiar with CAN bus systems. U-codes that indicate a loss of communication between modules or on a specific bus are a tool designed to help technicians diagnose CAN bus problems.
Electrical wiring diagrams reflect the CAN bus network, and there are three different types of networks – loop, star and loop/star hybrid – referred to as CAN bus topology. Being able to recognize the type of topology can help a technician diagnose CAN bus errors quicker. In today’s world, we all have to get aboard the CAN bus.
      Inexpensive OBD-II code readers can be both helpful and harmful
      Simple trick to get all the oil in the pan | Oil change tips part 7
      When it comes to keeping your vehicle running smoothly and efficiently, investing in the right auto parts is crucial. Whether you're a car enthusiast, a professional mechanic, or simply a vehicle owner who takes pride in proper maintenance, the quality of your parts can make all the difference. At Clifford Auto Parts, we understand the importance of using high-quality automotive components, and that's why we're committed to providing the best products and services to our customers.
      The Importance of Using High-Quality Auto Parts
      Imagine this: You're driving down the highway, and suddenly your car begins to sputter and lose power. More often than not, this is caused by failing or low-quality parts that just couldn't handle the wear and tear. By choosing high-quality, durable parts, you’re not just maintaining your vehicle; you’re investing in its performance and longevity.
      Here’s why using premium auto parts is essential:
      ✓ Improved Fuel Efficiency: High-quality Engine Control Modules (ECMs) and Powertrain Control Modules (PCMs) ensure that your engine operates at optimal levels, helping to maintain fuel efficiency and reduce emissions.
      ✓ Extended Vehicle Lifespan: Investing in quality parts reduces the risk of sudden breakdowns and costly repairs. Regularly replacing worn-out components with durable ones can extend the life of your vehicle.
      ✓ Enhanced Safety: Faulty parts can compromise the safety of your vehicle. By using reliable components from trusted suppliers like Clifford Auto Parts, you ensure your car remains safe on the road.
      Why Choose Clifford Auto Parts?
      At Clifford Auto Parts, we specialize in providing a wide range of automotive components, including:
      Engine Control Modules (ECMs) Powertrain Control Modules (PCMs) Transmission Control Modules (TCMs) We cater to major brands like Chevrolet, Dodge, Ford, GMC, and Chrysler, and many more. ensuring that you get the exact parts you need for your vehicle. Here’s what sets us apart:
      1. Uncompromised Quality
      We understand that your vehicle deserves the best. All of our parts are rigorously tested to meet or exceed OEM standards. When you purchase from Clifford Auto Parts, you’re not just buying a product; you’re investing in quality that you can trust.
      2. Fast & Free Shipping Across the U.S.
      We know how important it is to get your car back on the road quickly. That’s why we offer fast, reliable shipping throughout the United States, free of charge. Order today, and we’ll have your parts at your doorstep in no time.
      3. Lifetime Warranty on All Parts
      We stand behind the quality of our products, which is why we offer a lifetime warranty on all parts. If something goes wrong, we’ve got you covered.
      4. Dedicated Customer Support
      Not sure which part you need? Our experienced team is here to assist you. Whether you have questions about compatibility or need help troubleshooting an issue, we’re just a call away.
      Top-Selling Products at Clifford Auto Parts
      Here’s a look at some of our best-selling products:
      🚗 Chevrolet Engine Control Modules (ECM)
      Ensure your Chevy runs smoothly with our top-rated ECMs, designed to optimize engine performance and fuel efficiency.
      🚚 Dodge Powertrain Control Modules (PCM)
      Experience smooth gear shifts and improved performance with our Dodge PCMs, specifically designed to enhance the driving experience.
      🚙 Ford Transmission Control Modules (TCM)
      Our Ford TCMs are engineered to provide precise control over your vehicle’s transmission, ensuring reliability and longevity.
      Customer Testimonials
      "Clifford Auto Parts has been a game-changer for me. The lifetime warranty and free shipping made it an easy decision to choose them over other suppliers. My car's performance has never been better!" – David S., New York
      "I was impressed by the fast shipping and the quality of the parts I received. The customer support team was very helpful in guiding me to the right ECM for my Dodge Ram." – Sarah P., California
      Join the Clifford Auto Parts Community
      Are you tired of dealing with subpar auto parts that leave you stranded on the side of the road? It's time to make the switch to Clifford Auto Parts. Our parts are designed to keep your vehicle performing at its best, ensuring you get the most out of every drive.
      Visit our website today at
      link hidden, please login to view to browse our full range of automotive components.
      Engage with Us We’re always here to help and love connecting with automotive enthusiasts. If you have any questions or need advice on choosing the right parts for your vehicle, don’t hesitate to reach out to us. Let's keep your car running smoothly!
      🔧 Clifford Auto Parts – Driving quality, performance, and satisfaction.
      Why “topping off” a gas tank can be an expensive mistake
