As we brace for the worst this coming season has to offer, it’s time to get ahead of winter maintenance.
Snow tires are one of the more obvious seasonal upgrades, adding a little more stability and traction on slippery roads. Even if your customers don’t need to perform a seasonal tire changeover, they should be checking tread depths, overall tire condition and air pressures regularly.
As ambient temperatures drop, tire pressure drops with it. For every 10 degrees of change, you can expect to “lose” 1 pound of air pressure. TPMS sensors may trigger a warning light if these pressures drop below their preset thresholds, although the light may turn off after a few miles, as heat builds in the tire and the pressure increases. Some manufacturers even recommend increasing winter air pressure by 3 to 5 PSI to compensate for these temperature differences. Proper inflation also ensures that the tire has the optimal amount of contact with the road.
Steering, suspension and brake systems work together to help keep those tires firmly planted on the pavement. Worn shocks, struts and chassis parts can affect steering and handling in slippery conditions, while imbalanced braking can affect stopping distance and straight-line deceleration. Inoperative or defective ABS components also may disable traction control and lane assist, as well as other advanced driving-assistance systems (ADAS).
ADAS relies on information from the forward-facing camera(s) commonly found near the rear-view camera, so recommending a weatherproof winter or monobeam wiper of the correct size can help keep the camera view (and your own) clear and unobstructed.
Your own field of vision can be further expanded with fresh or upgraded head-lamp and fog-lamp bulbs. Brighter or whiter lamps (when properly aimed) will cast a pattern further and wider than old bulbs in a hazy, clouded housing. It also makes you more visible to oncoming drivers. While checking the lighting, be sure to cycle the hazard switch along with your high/low beams and turn signals. In the event that you DO find yourself stranded roadside, visibility becomes an even bigger safety concern!
It may seem strange to be concerned about checking over your A/C system before the mercury drops, but the windshield defroster/defogger function of the HVAC controls rely on the air conditioning to dehumidify the air inside the cabin. To defog your windshield quickly, turn OFF the recirculation feature, turn the fan to it highest setting and turn on the AC. Once it clears, you can turn down the fan, increase the temperature and enjoy a clearer view. Checking or changing your cabin filter now will also ensure optimum airflow through those vents.
Keeping the heat circulating all winter means checking the cooling system now. Flushing the cooling system (including the heater core), or at least checking the level and concentration of the coolant is the first step to a warm vehicle. Once the system is up to temperature, cycle the controls through each setting, checking for proper operation of door actuators and the blower motor to prevent surprises later.
Under the hood, check hoses and thermostat operation, along with any possible leaks from the radiator and water pump. Next, check belt and pulley condition while moving along to the starting and charging system.
Winter is one of the hardest seasons on a battery. Test all batteries for adequate cold-cranking amperage and resting voltage. Remember that many vehicles equipped with start-stop and diesel trucks have TWO batteries, and that even hybrids have a starting battery separate from the giant battery pack that provides power to the electric motor(s). Terminal connections and cables should be clean and secure.
A portable power pack/jump starter or a quality set of jumper cables make an excellent addition to your roadside emergency kit. Your emergency supplies also should include a first aid kit, a blanket or warm coat, flashlight, drinking water and non-perishable food. While you’re packing these supplies in the trunk, take the time to check the condition of your jack, lug wrench and spare tire (or inflator kit). With proper preventative maintenance, you and your customers can limit the potential for breakdowns, but still be well-prepared in the event of an emergency.
    • By GF4
      Please help!
      What vehicle did this taillight come from? It’s from a hit and run.
      thanks.
    • By ronaldgbrown84
      Upgrading or replacing your car engine is a significant decision that can enhance your vehicle's performance and extend its lifespan. If you’re searching for the best New Car Engine Dubai options, this guide will help you navigate the market, explore prices, and make an informed decision. Dubai offers a diverse range of high-quality car engines for sale, catering to various budgets and vehicle types.
      Why Invest in a New Car Engine?
      A new engine can breathe new life into your vehicle, ensuring improved performance, better fuel efficiency, and reduced emissions. It’s a cost-effective solution for vehicles experiencing recurring engine problems or those looking to upgrade their existing engine for enhanced capabilities.
      New Car Engine Dubai Price
      The new car engine Dubai price varies widely depending on factors such as the engine model, brand, and specifications. On average, you can expect prices to start from AED 15,000 for smaller engines and go up to AED 50,000 or more for high-performance engines. Luxury car engines or those with advanced technology typically cost on the higher end.
      When budgeting for a new engine, consider additional costs like installation, testing, and warranty packages. Opting for a reliable service center can ensure a hassle-free installation and long-term performance.
      New Car Engine Dubai for Sale
      When looking for new car engine Dubai for sale, Dubai’s automotive market offers plenty of options. You’ll find engines for all vehicle makes and models, including sedans, SUVs, sports cars, and commercial vehicles. Here’s where to look:
      Authorized Dealerships: Guarantee genuine parts and manufacturer support. Auto Parts Stores: Offer a wide variety of engines at competitive prices. Online Marketplaces: Allow you to compare multiple options conveniently. When purchasing a new car engine, always verify the authenticity of the product and request a warranty for peace of mind.
      Where to Find a New Car Engine Near Me?
      If you’re searching for a New Car Engine near me, Dubai is home to numerous reputable service centers and automotive shops. These providers offer personalized assistance, helping you choose the right engine based on your vehicle’s make and model. Look for experienced technicians who can guide you through the selection and installation process.
      Tips for Buying a New Car Engine
      Know Your Requirements: Understand your vehicle's engine specifications to find a compatible match. Check for Authenticity: Always purchase from trusted sellers to ensure genuine parts. Consider Installation Services: Choose a service center that offers professional installation and testing. Request a Warranty: Protect your investment by opting for engines with warranties. Conclusion
      Investing in a
      link hidden, please login to view is a smart move for anyone looking to enhance their vehicle’s performance and reliability. With a range of engines available at competitive prices, finding the perfect option for your needs has never been easier. For expert advice, high-quality engines, and professional installation services, Visit Service My Car and experience the benefits of a brand-new engine for your vehicle. Don’t wait—revitalize your ride today!
      When it comes to keeping your vehicle running smoothly and efficiently, investing in the right auto parts is crucial. Whether you're a car enthusiast, a professional mechanic, or simply a vehicle owner who takes pride in proper maintenance, the quality of your parts can make all the difference. At Clifford Auto Parts, we understand the importance of using high-quality automotive components, and that's why we're committed to providing the best products and services to our customers.
      The Importance of Using High-Quality Auto Parts
      Imagine this: You're driving down the highway, and suddenly your car begins to sputter and lose power. More often than not, this is caused by failing or low-quality parts that just couldn't handle the wear and tear. By choosing high-quality, durable parts, you’re not just maintaining your vehicle; you’re investing in its performance and longevity.
      Here’s why using premium auto parts is essential:
      ✓ Improved Fuel Efficiency: High-quality Engine Control Modules (ECMs) and Powertrain Control Modules (PCMs) ensure that your engine operates at optimal levels, helping to maintain fuel efficiency and reduce emissions.
      ✓ Extended Vehicle Lifespan: Investing in quality parts reduces the risk of sudden breakdowns and costly repairs. Regularly replacing worn-out components with durable ones can extend the life of your vehicle.
      ✓ Enhanced Safety: Faulty parts can compromise the safety of your vehicle. By using reliable components from trusted suppliers like Clifford Auto Parts, you ensure your car remains safe on the road.
      Why Choose Clifford Auto Parts?
      At Clifford Auto Parts, we specialize in providing a wide range of automotive components, including:
      Engine Control Modules (ECMs) Powertrain Control Modules (PCMs) Transmission Control Modules (TCMs) We cater to major brands like Chevrolet, Dodge, Ford, GMC, and Chrysler, and many more. ensuring that you get the exact parts you need for your vehicle. Here’s what sets us apart:
      1. Uncompromised Quality
      We understand that your vehicle deserves the best. All of our parts are rigorously tested to meet or exceed OEM standards. When you purchase from Clifford Auto Parts, you’re not just buying a product; you’re investing in quality that you can trust.
      2. Fast & Free Shipping Across the U.S.
      We know how important it is to get your car back on the road quickly. That’s why we offer fast, reliable shipping throughout the United States, free of charge. Order today, and we’ll have your parts at your doorstep in no time.
      3. Lifetime Warranty on All Parts
      We stand behind the quality of our products, which is why we offer a lifetime warranty on all parts. If something goes wrong, we’ve got you covered.
      4. Dedicated Customer Support
      Not sure which part you need? Our experienced team is here to assist you. Whether you have questions about compatibility or need help troubleshooting an issue, we’re just a call away.
      Top-Selling Products at Clifford Auto Parts
      Here’s a look at some of our best-selling products:
      🚗 Chevrolet Engine Control Modules (ECM)
      Ensure your Chevy runs smoothly with our top-rated ECMs, designed to optimize engine performance and fuel efficiency.
      🚚 Dodge Powertrain Control Modules (PCM)
      Experience smooth gear shifts and improved performance with our Dodge PCMs, specifically designed to enhance the driving experience.
      🚙 Ford Transmission Control Modules (TCM)
      Our Ford TCMs are engineered to provide precise control over your vehicle’s transmission, ensuring reliability and longevity.
      Customer Testimonials
      "Clifford Auto Parts has been a game-changer for me. The lifetime warranty and free shipping made it an easy decision to choose them over other suppliers. My car's performance has never been better!" – David S., New York
      "I was impressed by the fast shipping and the quality of the parts I received. The customer support team was very helpful in guiding me to the right ECM for my Dodge Ram." – Sarah P., California
      Join the Clifford Auto Parts Community
      Are you tired of dealing with subpar auto parts that leave you stranded on the side of the road? It's time to make the switch to Clifford Auto Parts. Our parts are designed to keep your vehicle performing at its best, ensuring you get the most out of every drive.
      Visit our website today at
      link hidden, please login to view to browse our full range of automotive components.
      Engage with Us We’re always here to help and love connecting with automotive enthusiasts. If you have any questions or need advice on choosing the right parts for your vehicle, don’t hesitate to reach out to us. Let's keep your car running smoothly!
      🔧 Clifford Auto Parts – Driving quality, performance, and satisfaction.
    • By Mighty Auto Parts
      link hidden, please login to view appeared first on link hidden, please login to view. Selecting the right maintenance schedule is imperative for the health of the engine in preventing major engine repairs or in extreme cases preventing a total engine replacement. Neglecting the required service interval can result in an accumulation of sludge and deposits that can restrict the flow of lubricant to vital engine components. Consider the following: […]
