Volkswagen Adopts KYB Shock Absorbers for Various Models
By abiztime
Highlighted Part: Sliding Door Handle Repair Kit for Select Chrysler and Dodge Models
In the summer of 1974,
link hidden, please login to view introduced a limited line of MacPherson Strut replacement cartridges, Gas-a-Just and Premium Heavy Duty shock absorbers to North America. Celebrating the Past, Looking to the Future
Surviving the turbulent ‘70s, KYB took full advantage of the economically booming ‘80’s, building a new 500,000-square-foot North American manufacturing plant in Franklin, Indiana just outside Indianapolis. The Franklin plant has been building OE and aftermarket shocks and struts since 1986. It continues to grow with the addition of a research and development lab, “clean” room for assembling shock valving, and most recently, being honored as the 2019 Industrial Plant of the Year for Wastewater Quality for reducing wastewater discharge 40% to the City of Franklin, KYB said.
The next few decades saw growth, with a new office being opened in Addison, Illinois, in 1999, and the launch of highly popular MonoMax truck shock just after the Millenium, according to KYB. In 2008, the company debuted the Strut-Plus complete assembly, which it said helped to set the standard in aftermarket ride control.
2011 saw the opening of a 275,000-square-foot distribution center in Greenwood, Indiana, just up the road from the Franklin manufacturing plant. The close proximity of these two locations allowed for quicker development and manufacturing of new applications and product lines, as well as faster distribution to customers throughout North America. The Addison, Illinois, office was moved to the Greenwood facility in 2014, completing the consolidation of administration, distribution, and manufacturing.
As it celebrates the past and looks to the future, KYB said it continues to grow, with monthly announcements of additional applications and fitments, new product releases, such as KYB JAOS lift kit applications, and a new product line scheduled for release in 2025.
By shelitaauto
Source: Gasgoo
Image source: Scout
link hidden, please login to view Group’s Scout brand has received nearly $1.3 billion in incentives for its $2 billion plant in South Carolina. The state’s governor Henry McMaster signed the bill approving the incentives. South Carolina Commerce Secretary Harry Lightsey said Scout will also receive up to $180 million in tax credits based on hiring to promote job development. Vw recently revealed that Scout is expected to create 4,000 jobs in the region. Scout’s South Carolina plant will need workers in the body shop, paint shop and final assembly shop.
Scout’s new plant is expected to open by the end of 2026, a $2 billion, 1,600-acre facility that will focus on building electric trucks and durable SUV models.
Earlier this year, Scout CEO Scott Keogh said the company would launch its first all-electric SUV in the third quarter, with a starting price expected to be $40,000.
“I think the design is 85, 90, 95 percent done,” Keogh said. I call it a ‘big B-class SUV.’ We will also release a full-size pickup truck in the future. These are all models that we’re bringing to market, and when we’re ready for an official announcement, we’ll announce them.”
The Volkswagen Group is hoping the Scout brand will help it break through in the U.S. electric pickup market. The German automaker is aiming to increase its share of the U.S. auto market.
By garryhe
Explore Top-Quality Brake Pads for Toyota Models at Our Factory!
Hello everyone!
As a professional brake pad manufacturing factory, we are proud to announce that we cover over 98% of global automotive brands and have cataloged every model for easy reference by our customers.
We are excited to introduce our extensive range of brake pads for various Toyota models. You can effortlessly browse and purchase them through our website. Whether you need brake pads for the classic Camry, the stylish Corolla, or the robust Tacoma, we have you covered.
Our brake pads boast premium materials, and expert craftsmanship, and undergo rigorous quality control to ensure the highest levels of safety and performance. We guarantee that our products will exceed your expectations and provide you with confidence and peace of mind in your driving experience.
Whether you're a professional mechanic or an automotive enthusiast, we welcome you to explore our wide range of brake pad offerings at our factory. We are confident that you will be satisfied with the quality of our products and services.
Visit our website to discover more:
link hidden, please login to view and link hidden, please login to view Thank you for choosing us, and we look forward to collaborating with you!
Thank you!
