      Auto-Wares shared details of its Customer Cruise, Feb. 15-22, 2025. The Norwegian Bilss set sail from Miami and made stops in Mexico, Belize and the Bay Islands. Guests included customers, industry partners and friends. Auto-Wares described the cruise as more than just a vacation, calling the trip an opportunity to strengthen relationships and share ideas in a relaxed setting.
      link hidden, please login to view explained that for most of the trip, the weather was warm, sunny and ideal for cruising. Guests enjoyed blue skies and calm seas while relaxing on deck, exploring ports and soaking in the Caribbean views. By the final day, the weather took a turn, bringing some clouds and rougher seas. Despite that, Auto-Wares said everyone made the most of their last full day onboard, whether enjoying the ship’s indoor amenities, grabbing one last cocktail, or reminiscing.
    • By dwil4
