How to dealing with Chinese tire suppliers? how can you tell if sales person is good or not ?
To Importers in the Global Tire Industry:
Please read this  as it might inspire you. Many international friends have been perplexed about how to import tires manufactured in China and sell them in their home countries. China's tire industry has experienced rapid growth over the past decade, marking a period of significant dividends. Many early investments in large factories have yielded substantial returns. However, with an increasing number of factories and brands, the competition has intensified. For those who wish to enter this industry but are unsure about how to proceed, please follow my website. I will periodically update it with information about China's tire industry for your reference.
please follow:
  • 2 months later...
Your website updates will surely be a helpful resource for those looking to navigate the complexities of importing and selling Chinese-manufactured tires in their respective countries.
Edited by Howard Jones
      “Show and tell” | Tips from mechanics #automobile #carrepair #truckrepair #autorepairtips
      Frenkit, a European brake hardware supplier, is expanding coverage for the North American aftermarket. Featuring proprietary rubber components manufactured at its facilities in Spain and India, the company said it now offers U.S. customers nearly 4,500 different brake hardware kits, covering 95% of U.S. aftermarket sales.
      link hidden, please login to view said its program includes hardware kits for both disc and drum brakes, caliper pistons, brake caliper repair kits, electronic parking brake kits and more. The company said its portfolio is comprised of more than 12,000 different components covering 50,000 parts cross-referenced to OE. Frenkit added that its catalog is fully ACES and PIES compliant and FMSI-indexed. The post
    • By AutoZone
      MEMPHIS, Tenn. , March 04, 2025 (GLOBE NEWSWIRE) -- AutoZone, Inc. (NYSE: AZO) today reported net sales of $4.0 billion for its second quarter (12 weeks) ended February 15, 2025 , an increase of 2.4% from the second quarter of fiscal 2024 (12 weeks). Same store sales, or sales for our domestic and
