Folks, have you checked out our NEW arrival yet?
👉Ford 2200W Fuel Gas Powered Parallel Ready Portable Inverter Generator👈
🔥Order it now with a 10% off code: generator10🔥
✔️Light-weight compact design.
✔️Capable of up to 6 Hours of Operation at Half Load on 1.18 Gallons of Fuel.
✔️2,2000 Peak Watts/ 2,000 Rated Watts
✔️Compact Suitcase Design, Weighing Less than 47 lbs for Easy Handling
✔️Quiet Operation (59 dB) make it Virtually Silent from just 10 feet away
✔️Stable Sine Wave Technology provides pure, safe electrical power for powering and charging laptops, cell phones, and other sensitive electronic devices
✔️Parallel Capability allows you to easily connect 2 FG2200iS units together for increased power output
✔️Featuring (2) 120V 15A AC Outlets, (1) 12V DC 8A Outlet, (1) 5V DC USB Outlet so you can charge and power multiple devices at once
✔️80cc OHV Carb Compliant Engine
🚢ALWAYS FREE SHIPPING🚢
HERE IS THE LINK:
FG2200IS-1_750x_crop_center.jpg?v=157048FG2200IS-4.jpg?v=1570488264
FG2200IS-5.jpg?v=1570488264FG2200IS-6.jpg?v=1570488264FG2200IS-7.jpg?v=1570488264FG2200IS-8.jpg?v=1570488264
      To kick off its yearlong
      link hidden, please login to view celebration, Federated has brought back the Federated Free Fuel Fridays contest. This time, there will be a total of 40 winners of gift cards that can be used for free fuel. Each Friday through April 11, Federated will announce four randomly selected winners on its link hidden, please login to view and link hidden, please login to view Facebook pages. A $50 gift card will be sent to each of the lucky winners. “As we celebrate 40 years of Federated, we knew we had to bring back one of our most popular contests for those who follow Federated on Facebook,” said John Marcum, director of marketing for Federated Auto Parts. “It’s easy to enter Federated Free Fuel Fridays. With a total of 40 lucky winners, a lot of free fuel will be awarded in recognition of this major milestone.”
      To enter, visit Federated on Facebook or click on the special
      link hidden, please login to view or link hidden, please login to view contest links and fill in the entry form. Extra entries can be earned by sharing the contest with Facebook friends. Winners will be announced each Friday starting Feb. 7, with the final four winners announced April 11, 2025. The post
      Series Supplier
      Visit
      How To: Use a Fuel Pressure Test Kit
