Brake Job Tip - Cleaning Brake Caliper Brackets
5, Pallet
The top OEM brake disc manufacturer in China: link hidden, please login to view
In 2008, the company expanded and registered the Rongdi trademark, and the company began to go abroad.
In 2015, the company established the domestic market department and "Longzhu" brand has launched focusing on serving the domestic auto parts aftermarket. In 2021, Longzhu brand won the prize of "Most Competitive Brake Disc Brand"
With the expansion of domestic market business, the company registered Yichen trademark. In 2021, Yichen brand was honored "Annual Breakthrough Brand"
