      Ideal kit for Chevy/GMC alignment issues
    • By Mighty Auto Parts
      link hidden, please login to view appeared first on link hidden, please login to view. Nothing is more frustrating for the vehicle owner than a puddle of oil on their carport fl oor or the stench of oil on a hot engine or exhaust system following a lube service. It is equally frustrating for the lube shop asthey must correct the problem, losing billable labor time. We have seen customers […]
      Evercoat will host a free webinar titled, “Body Filler Troubleshooting”, on June 11, 2024 at 4 p.m. The webinar will be presented by ASE, with Evercoat’s Tim McKinney.
      This webinar will review some common issues when it comes to body filler applications and some of the common questions and problems when things don’t go as planned.
      Attendees will learn more about the problems, causes and cures for what went wrong and steps they can take to avoid those issues in the future.
      Not sure you can attend? Register anyway to receive a follow-up email with details on how to attend a recorded session, if available. Access to recorded sessions is reserved for those who register for the live event.
      To register for the webinar, click
      link hidden, please login to view appeared first on link hidden, please login to view. Pinpointing the reason for a crank but no-start, extended cranking, rough idle or misfi re symptoms can be a challenge that can consume a lot of diagnostic time to resolve the complaint. Often the Malfunction Indicator Light (MIL) will be illuminated and a PO300 random misfire code may be stored in memory. If you are […]
      How To: Change the Thermostat in a 2002 to 2008 Dodge Ram 2500
