Create an account
Register a new account
Sign in
Sign In Now
      How To: Change the Cabin Air Filter in a 2013 to 2018 Toyota RAV4
      Keep some fuel hose with your spark plug socket for easy installation
      link hidden, please login to view and Motorcraft announced a partnership on two new Motorcraft® Fuel System Cleaning products for Ford and Lincoln vehicles using approved Motorcraft fuel products, equipment and services at Ford locations throughout the United States. The companies said the goal of the Motorcraft Enhanced Maintenance Fuel Service Program is to diminish the adverse impacts of lost combustion chamber efficiency and restore fuel economy, power, and performance. The program recently moved to a nationwide launch for Ford & Lincoln dealerships across the U.S. “BG Products is extremely excited to partner with Motorcraft to offer the new Motorcraft Enhanced Maintenance Fuel Service Program,” said Darin Greseth, president, CEO, and chairman of BG Products, Inc. “This new program will assist Ford and Lincoln customers in keeping their fuel injectors and intake system clean to ensure like-new performance and fuel economy.”
      Below are the approved Motorcraft and BG co-branded products, part numbers and mileage recommendations for enhanced service. The new Motorcraft Program is recommended at oil change intervals. More information is available at Ford and Lincoln dealers.
      How To: Change the Cabin Air Filter in a 2003 to 2007 Honda Accord
    • By CALEPH Auto Parts
      Steps to clean your car's air filter:
      1. Find the location of the air filter: It is usually located in the engine compartment, near the side of the engine.
      2. Make sure the engine is cool: Before checking or cleaning the air filter, make sure the engine has cooled down completely to avoid burns.
      3. Open the hood: Find and open the hood so that you can access the air filter.
      3. Locate the air filter box: The air filter is usually located in a black plastic or metal box.
      4. Remove the air filter box: Unscrew or unfasten the screws or clips that secure the air filter box.
      5. Remove the old filter: Remove the old air filter from the box, being careful not to damage the filter box.
      6. Check the condition of the filter: If there is only a small amount of dust on the filter, you can clean it. If the filter is already very dirty or damaged, it is recommended to replace it.
      7. Clean the filter: If you decide to clean the filter, you can blow it from the inside out with compressed air to remove dust. Do not use water or liquid cleaners as they may damage the filter.
      8. Check the integrity of the filter: After cleaning, check the filter for tears or holes that may affect its performance.
      9. Reinstall the filter: If the filter is in good condition, put it back into the filter box and make sure it is properly seated.
      10. Reinstall the filter box: Replace the filter box cover, making sure all screws and clips are secure.
      11. Close the hood: After cleaning or replacing, close the hood.
      Click the link to learn more:
