      OTC said each suspension bushing kit features Hendrickson rear suspensions, including Primaax EX, Comfort Air and FCCC V-Ride Pivot and D-Pin suspension bushings, and freightliner rear suspensions, including double and single-wrapped FAS II Airliner rear suspension bushings. Both also include centering adapters to align tool and bushing for clean installation. Both are available through OTC distribution partners and resellers.
      Electronic Shocks/Struts
      Measuring Wheel Movement
      Measuring Body Movement
      Westar Distribution LLC, a leading aftermarket supplier of engine & transmission mounts and air suspension components announces the release of 40 new Air Suspension Components, Engine & Transmission Mounts, Torque Strut Mounts, and Center Support Bushings servicing in excess of 35,000,000 vehicles in operation today in the US & Canada covering Acura, BMW, Dodge Truck, Ford Sport Utility, GMC Trucks, Honda, Hyundai, Jeep, Lexus, and Toyota vehicles. These newly released items are all in stock and ready for immediate shipment.
      link hidden, please login to view For more information contact [email protected] or visit
    • By Esacivic
      Hey y’all I have a 1989 Honda civic hatch and I’m looking to build up a strong suspension but I’m unsure of some quality brands for them. I’m looking for anti roll bars that are beefier then stock, full control arms all around, camber kits front and rear, sway bar.
      any and all help is appreciated thank you
      Auto service inspection checklist?
