Create an account
Register a new account
Sign in
Sign In Now
      While constant velocity (CV) joints are the most popular type of driveline joint in use today, universal or “U” joints are still in use on the driveshaft of many larger SUVs, trucks and vans. U-joints can handle a lot of torque, making them popular for these applications, but why did the CV joint rise in popularity? The question can be answered by looking at the operational aspects of a U-joint.
      The basics are this: U-joints are located on the ends of a driveshaft, mounted between the driveshaft and a front and rear yoke. The front yoke attaches to the transmission and the rear yoke attaches to rear differential. As the engine moves from the effects of torque and as the suspension of a vehicle travels up and down, the angle of the driveshaft changes.
      A U-joint does two things. First, it transfers the motion between the yoke(s) and driveshaft and, second, it does this at different angles, allowing for driveline movement. Here’s where the fun begins. When a yoke and the driveshaft are in perfect alignment, the velocity from one is transferred to the other at the same rate. However, when there is an angle between the two, the velocity of the driven member fluctuates continuously during rotation.
      It can be hard to visualize, but the reason this happens is that as the angle of the U-joint changes, the two halves of the U-joint cross are forced to rotate on a different axis. The drive axis remains at a constant velocity, and the ends of the U-joint connected to it rotate in a consistent circular path at the same velocity.
      The driven axis, however, rotates in a path which causes the distance of travel at the outer ends of the U-joint cross to increase or decrease in relation to the consistent points of the drive axis.
      This effect results in the continuous fluctuation of velocity between the input and output sides of the U-joint. While the input remains at a consistent speed, the output speeds up and slows down as the points of the driven axis continuously alter between a long and short path of travel.
      So, why don’t we feel that on a vehicle with a traditional driveshaft? Because there are two U-joints and the fluctuation on each end balances out, effectively allowing the driveshaft to provide a consistent output speed to the rear differential. The angle of the two joints must be the same, however, and it doesn’t take much wear in one for the angles to differ, and subsequently cause a vibration.
      U-joints are known for their propensity to cause vibration, and an inherent disadvantage they have is the greater the angle of the U-joint, the greater the fluctuation in velocity. Anything over 30 degrees and the fluctuation dramatically increases.
      The driveshaft I’ve described here represents the majority, but U-joints have also been used frequently in the past on the end of the front axles for a 4WD vehicle, and in the rear of independent rear suspension vehicles on the ends of short driveshafts, known as half-shafts.  Have you ever noticed how jittery an old 4WD truck feels in the front when the hubs are locked, and you turn a corner? Now that you understand how the fluctuation in velocity of a U-joint changes as the angle increases, you know why.
      You may have heard of a Double-Cardan U-joint. It is basically two joints side-by side with a common link-yoke in between. This is one of the original concepts for a true CV joint, and they are often referred to as this. The advantage they have is they offer smoother operation at greater angles, and they are common on 4WD trucks, and a common upgrade for lifted trucks where the driveshaft angle is altered considerably.
      The drawback to a Double-Cardan joint is they are bulky, and they can still suffer from limitations due to operating angle. The operating limitations of a U-joint ultimately brought about the popularity of the modern CV joint, but the durability of U-joints means we’ll still be seeing them in certain applications.
      Why you shouldn’t throw out zip tie tails after a project
      Upgraded tie rod end kit for Ford Broncos!
      Should you use antiseize when installing spark plugs?
    • By NAPA
      It’s no surprise that electrification has spread into every corner of the automotive world. From humble local delivery vans to high-voltage track monsters, the gamut of EVs on the road is impressive. So, it is no shock that manufacturers recognized the inherent benefit electric motors have in delivering a ton of torque at initial startup. That gives an EV tremendous power for launching off the line, something enthusiast drivers appreciate. Here’s the top hot rod electric cars that are guaranteed to get your blood pumping in 2024.
      Porsche Taycan – 750 Horsepower
      Porsche launched the
      link hidden, please login to viewin 2019 as its first dedicated electric car. Keeping with Porsche naming conventions, the highest output version, Taycan Turbo S, is the top-of-the-line in terms of performance. No, there is not a “turbo” in the traditional sense, but the Turbo and Turbo S models do get a nice first bump of recognition with the powerful name. Driver’s get a 2.6 second 0–60 mph launch and a 161 mph top speed for track days. Mercedes-AMG EQS – 751 Horsepower
      It should come as no surprise that the in-house hot rod division of Mercedes-Benz would get its insulated-gloved hands into the EV market. While the
      link hidden, please login to view is not the first electric AMG vehicle (the 2013 Mercedes-Benz SLS AMG Electric Drive gets that nod), it is the first on a dedicated electric vehicle chassis. Mercedes claims a 3.4 second 0–60 mph time, which is .1 second faster than the combustion-engine Camaro ZL1 Coupe from the same year.  Rivian R1T – 835 Horsepower
      link hidden, please login to view may only sell one vehicle (the SUV is pretty much identical to the truck), but sales show the payoff of extreme product focus. link hidden, please login to view buyers can select the quad motor version for combined 835 horsepower and a 3.0 second 0–60 mph time. That’s faster than a Dodge Challenger Hellcat Redeye, plus it has enough room to pick up a load of mulch from the local garden center. GMC Hummer EV – 1,000 Horsepower
      It feels kind of silly labeling the hulking
      link hidden, please login to view as an EV hot rod, but stay with us. When the spec sheet shows three motors with a total of up to 1,000 horsepower and a 0–60 mph time of 3.0 seconds flat, that’s hustling. And when that hustle is brought by something the size of a tiny house, it is even more impressive. Sure “Watts to Freedom” mode sounds silly, but it is akin to a tank getting shot out of a cannon, so it matches. Tesla Model S Plaid – 1,020 Horsepower
      When it comes to drag racing electric cars,
      link hidden, please login to view was likely the first manufacturer to grab driver’s attention. Fans of the 1987 movie “Spaceballs” should get Tesla’s name reference — setting light speed to Plaid. Three motors with a combined 1,020 peak horsepower rocket this sedan to 60 mph in just 1.99 seconds. That’s a full second faster than a new Corvette. It also rips the quarter mile in 9.23 seconds at 155 mph. Just how quick is that? If you want to race your Tesla link hidden, please login to view Plaid at a sanctioned NHRA drag race, it will need a roll cage and a parachute! Tesla Model X Plaid – 1,020 Horsepower
      Tesla took the same drivetrain as the already insane Model S Plaid and put it in an SUV, thus creating the
      link hidden, please login to view Plaid. The added size and weight took a toll as 0–60 mph now takes 2.5 seconds, but the quarter mile time is just a touch slower at 9.9 seconds. That’s two seconds faster than a Dodge Durango SRT Hellcat. Plus, it has cool gullwing doors and can tow 5,000 pounds. Lucid Air – 1,234 Horsepower
      Now we’re getting into ridiculous territory. Dropping $250k on a
      link hidden, please login to view Sapphire gets you 1,234 horsepower and a top speed of 205 mph. That money also gets you to 60 mph in 1.89 seconds and an 8.95 second quarter mile time. All this in a four-door sedan that can go more than 400 miles on a single charge. Sure, a Bugatti Veyron will outrun it on the top end, but the Lucid Air Sapphire will make it claw for every inch on the way to 200 mph. Rimac Nevera – 1,914 Horsepower
      For our pick of the baddest electric hot rod, we have the Rimac Nevara. This is beyond simply an electric sports car and ventures into pure hypercar territory with a sleek body to match. Its 1.74 second 0–60 mph time set a
      link hidden, please login to view in May of 2023 along with a slew of other acceleration world records. It can hit 249 mph in just 21 seconds. It can also go from a dead stop to 249 mph and back to a dead stop in just less than 30 seconds. And, just for silliness, Rimac set a world record for the fastest driving…in reverse (171 mph). Now, for the big downside, that mind bending speed will set you back $2.2 million dollars. NAPA Is Your One-Stop EV Shop link hidden, please login to view
      So, there you have it. Electric hot rod options from tame to insane. Rumors still surround a possible electric muscle car from Dodge in the form of the Charger Daytona SRT Banshee, but no official production date is set. Looking to build your own EV muscle car?
      link hidden, please login to view is an electric motor swap kit that you should find available to the public soon.  Thinking of upgrading to the electric vehicle lifestyle, but you need a complete at-home charging station setup? NAPA has you covered thanks to a partnership with
      link hidden, please login to view, which can assist you in purchasing the link hidden, please login to view for your needs, and correctly link hidden, please login to view in your garage. And remember, NAPA Auto Parts has a long history of supplying quality parts for at-home mechanics restoring muscle cars. Tackle your
      link hidden, please login to view with the best cooling fans, cold air intakes, control modules and more. Simply shop link hidden, please login to view or head over to your local link hidden, please login to view store. Sign up for link hidden, please login to view now to start earning Points—earn 100 Points, and you get $5 off your next purchase automatically! Photo courtesy of
