      MAHLE Lifecycle and Mobility (formerly MAHLE Aftermarket) announced the addition of its latest MAHLE Manifold Installation Set (MIS) – MIS19945. Available for GM 5.3L and 6.2L engines in various models of Cadillac, Chevrolet and GMC-branded vehicles, the set includes all the gaskets and seals for a technician to properly re-install the intake manifold, the company said.
      The MAHLE gasket MIS portfolio represents the most complete gasket kits available on the market today, covering more than 5 million applications in operation across North America,
      link hidden, please login to view announced said in news release. “When a technician invests in one of our MAHLE gasket kits, they can trust that every part needed for the job from beginning to end is packed nicely in the blue MAHLE box,” said Ron McCrum, gasket team product manager, MAHLE Lifecycle and Mobility, North America. “True to OE Form, Fit & Function, customers never have to look elsewhere for a missing component and our easy- to-follow instructions make the installation process simple and convenient.”
      Each
      link hidden, please login to view gasket MIS set includes everything from valve cover gaskets, plenum gaskets and coolant gaskets to injector O-rings, water and emissions connections, and other miscellaneous gaskets. The post
    • By abiztime
      Best practices for cartridge oil filter changes | Oil change tips part 2
    • By austinbearing
      Hello, everyone
      We are a leading automotive bearing manufacturer from China
      We produce Peugeot Renault and some other automotive bearings
      We also produce rear axle shafts for Peugeot cars
      You can contact me if you're interested
      This is our company website
      WhatsApp: +8613775640157
      E-mail: [email protected]
    • By austinbearing
      Hello, everyone
      http://www.yxjcbearing.com/
      catalogue.docx
