      link hidden, please login to view proudly shares the story of its recent NTN Bearing Community Engagement event. This event took place at link hidden, please login to view in Lake Bluff, Illinois. On Tuesday, March 25, 2025, a dedicated group of NTN employees volunteered for the charitable organization. The organization sources and distributes new and gently used books to children in the Chicagoland area. Volunteers Pack and Inspect Books
      With the help of volunteers, Bernie’s Book Bank has provided over 23 million books. These books went to families without children’s books at home since 2009. During this event, NTN volunteers packed eight books into bags for distribution. They also inspected donated used books to ensure their good condition. In total, NTN employees assembled 1,852 bags with 14,816 books for distribution.
      NTN Bearing Community Engagement: Supporting Local Communities
      “Over the past two years, we have formed a great relationship with Bernie’s Book Bank,” said Pete Eich, president of NTN Bearing Corporation of America. “For many of our employees who participated, including myself, we believe there is no better feeling than to reach out and help kids. Many of us have children or grandkids who love to have books read to them before taking a nap or going to bed at night. Unfortunately, there are kids in the Chicagoland area who do not have this same opportunity. Our involvement with Bernie’s Book Bank helps address this issue and brings the joy of reading to many children.”
      NTN’s Community Spirit & Engagement Program
      link hidden, please login to view launched its Community Spirit & Engagement Program in January 2023. This program focuses on managing the company responsibly and ethically. It also makes positive contributions to the community and builds partnerships with other organizations. The program encourages employees to take an active role in community service. This reflects NTN’s commitment to corporate citizenship. Looking Ahead to Future Community Outreach
      “I am looking forward to strengthening our relationship with our established community partners during quarterly community outreach programs in 2025,” said Eich. “We also look forward to creating new partnerships.”
      Each
    • By abiztime
      Best practices for cartridge oil filter changes | Oil change tips part 2
    • By austinbearing
      Hello, everyone
      This is our company website
      WhatsApp: +8613775640157
      E-mail: [email protected]
