    • By Mypafway
      Mypafway
      https://mypafway.com/
      Mypafway is a marketplace for online distribution of automotive part information and one of the leading providers of online marketing services for manufacturers, suppliers and retailers. I'm looking for Economic and Strategic Buyers for Mypafway. You can hit me up via email at [email protected] or on social media. Thanks.
    • By Garage Gurus
      Garage Gurus | How to Use a Pressure Test to Find a Coolant Leak
      Rislone announced its new
      link hidden, please login to view (p/n 4400), which it said improves oil performance to eliminate dry starts, reduce friction and wear, prevent oil breakdown and extend engine life. “Its concentrated formula delivers legendary Rislone Hy-per Lube performance in a compact, easy-to-use, and shelf-friendly bottle,” the company added. Hy-per Lube Engine Supplement is a premium additive blend formulated to work with all motor oils, including conventional, high-mileage, and synthetic, to make older, high-mileage, and high-performance engines run better and last longer than they would with oil alone, according to
      link hidden, please login to view. It’s also suitable for use in manual transmissions, differentials and axles. Rislone said it previously offered the supplement in a one-quart bottle, making it easy to swap a quart of oil for a quart of Hy-per Lube at every oil change. Now that most consumers buy oil in larger jugs, Rislone added it took the opportunity to reduce the package size — and the price. Concentrating the formula enabled Rislone to package it in a 16.9 oz. bottle without diluting performance. The smaller bottle also reduces packaging waste and storage space.
      “Adding Hy-per Lube Engine Supplement to petroleum or synthetic oils turns them into hyper-performance lubricants that deliver heavy-duty protection for all driving demands across a wide range of engine and vehicle types,” said Clay Parks, Rislone vice president of development. “In these days of high prices, we’re proud to have found a way to lower ours. Our concentrated formula saves consumers money at the counter and in years to come by helping their engines last longer.”
      There is nothing simple about complex engine oil formulations. Effectively explaining to your customer how Valvoline’s Restore & Protect motor oil removes and prevents engine deposits may seem like a tough task.
          Dr. Michael Warholic, global technology director for Valvoline Global Operations, emphasizes the importance of visual evidence
      “Hey, look how this product performs,” said Warholic. “We have visuals showing that there’s a removal of deposits, that there is a reversing of the aging process in an engine. That’s a great case story to tell.”
          Warholic talks with Babcox Content Director Jason Morgan about the formulation process that sets Restore & Protect apart. The process involves a balance of various additives and components, tested rigorously in both laboratory and real-world conditions. It also involves combining base oils, viscosity modifiers, and a unique blend of additives. These additives include detergents to clean deposits, friction modifiers to reduce engine strain, and antioxidants to combat the breakdown of oil components. The goal was to create a motor oil that not only prevents the formation of new deposits but also removes existing ones, effectively rejuvenating the engine.
        “We wanted to do something different than everybody else,” said Warholic. “That’s what Restore and Protect does. It differentiates us from our competitors. It does something that no other oil does in the marketplace right now.”
           Restore & Protect could be considered a new category of motor oil that bridges the gap between conventional oils and high-mileage formulations. While high-mileage oils are designed for older engines, Restore & Protect is suitable for both new and aging engines. Its dual function of preventing new deposits and reversing existing ones makes it a versatile choice for a wide range of vehicles.
           This innovation is particularly valuable for engines operating under severe conditions, such as those used for towing or in high-traffic areas. The oil’s ability to handle these demanding environments while maintaining engine cleanliness offers a significant advantage over standard motor oils.
      “There’s always engine oil. Formulating is a little bit about give and take. The engine is a very complex machine. You have different temperatures, different pressures. It is really a very interesting field when you start digging into it.”
      “We do tons of data-driven testing. That’s what we live for.”
    • By Garage Gurus
      Garage Gurus | Using a Thermal Imaging Camera to Check Transmission Cooler Flow
