Diagnosing Brake Drag
By LEarn492
Hi i have a 2006 g35x that i just got. i put sport pads in the front becuase i used them on my old car and loved the extra power that they gave me. i need new rear pads too, my question is will putting sport pads in the rear mess up my car's handling or braking? like it won't mess with the brake bias, the system that alters brake pressure to each wheel, make my car more likely to fishtail or anything like that when i hit the brakes in a corner right? it'll just give me more stopping power? i'm thinking this as all the companies sell sport pads for rear too. anyone here done this before? any tips? thanks. -
By abiztime
