Garage Gurus | Ignition Coil System Testing
By Mighty Auto Parts
link hidden, please login to view appeared first on link hidden, please login to view. When performing engine maintenance, the coolant is seldom considered. While the freeze factor is usually the first consideration at the start of winter, few consider the corrosive inhibitors and lubricants that become depleted, promoting water pump failure. In addition, the accumulation of engine and radiator deposits can affect engine cooling. Coolant exchangers are highly recommended […]
By Dorman Products
Why testing modern sealed batteries takes more than hydrometers and refractometers
