Al Neal Joins Autologue Computer Systems
Auto-Wares Group of Companies announced that it has joined forces with Landon Auto Parts. Landon has five locations in lower Northern Michigan (Boyne City, Charlevoix, Cheboygan, Indian River and Onaway). They join the 42 locations currently operated by
link hidden, please login to view in the Northern and Upper Peninsula of Michigan. Landon Auto Parts and Auto-Wares officially joined operations on October 31, 2024. Landon Auto Parts stores will be rebranded to the Auto Value name and high-quality national-brand products will be available over the next weeks to replace some of the current private-brand products, according to a news release from
link hidden, please login to view. That same news release explained that the Landon family members, their team and their commitments to the Landon Auto Parts customers will stay intact. While the Landon family operates a hardware and lumber business alongside Landon Auto Parts, the partnership will impact only the Landon Auto Parts business—the Landon-owned hardware and lumber businesses will remain owned and operated by the Landon family.
link hidden, please login to view’s Executive Committee announced it welcoming Robert Roos, effective July 1, 2024, in a show of its focus on North America. Roos is the president & CEO of link hidden, please login to view – APSG and president of NEXUS North America. “With a robust career of over 40 years in the automotive industry, Robert has held key positions that underscore his expertise and leadership,” NEXUS said in a recent press announcement.
According to NEXUS, the appointment “aligns with the company’s increased ambitions in North America, aiming to accelerate the growth plans of N!’s OEM partners and gradually integrate a growing number of North American partners.”
This objective will be supported by a more active presence of the NEXUS team in Grapevine, Texas, at APSG’s headquarters. Besides its “growth accelerator” prime goal, this presence will enable the proactive deployment of NEXUS initiatives such as Mobilion, Marketparts and Smartparts, the company said.
Roos actively participates in multiple industry committees including the Education Committee within The Auto Care Association, The AWDA Board of Governors, and the University of the Aftermarket Foundation, demonstrating his commitment to advancing the automotive sector through collaborative efforts and industry-wide initiatives, NEXUS added.
“I am honored to take on this role at such a significant time for NEXUS. Together, we will continue to drive innovation and growth, ensuring that NEXUS remains at the forefront of the automotive aftermarket industry,” Roos said.
Gaël Escribe, NEXUS Automotive International CEO, said: “We are thrilled to welcome Robert to N!’s Executive Committee. Our focus on growth in this region is encapsulated by our new motto ‘Brightening our future’, which perfectly reflects our vision for growth and innovation in the coming decades.”
Electronic Shocks/Struts
Measuring Wheel Movement
Measuring Body Movement
