Mercedes R107 380SL 560SL 81-89 Auxiliary Heater Control Water Pump 0008355964
- 1,727 views
- 2,490 views
- 1,600 views
- 4,384 views
- 2 replies
- 2,272 views
Autel announced its tablets have been certified by the Auto Authentication Authority (AutoAuth) to access Mercedes-Benz vehicles’ Security Gateway (SGW). As a result, “Autel tablet users can now access more vehicle brands’ secure gateways than any aftermarket tool using the authentication service,” the company explained in a news release about the certification.
In addition, Autel negotiated with Volkswagen/Audi Group to add SGW access capability to its diagnostics and service tablets, and, last month, Autel added the functionality to its tablets. Users can purchase single VW/Audi VIN/24-hour sessions or unlimited VINs/full-year access plans.
“Increasingly, automakers are securing critical vehicle systems behind gateway modules. We have prioritized getting our tablets authorized to access these systems and enabling our technicians to service the vehicles they need to. Autel has consistently led the aftermarket in getting this functionality to our products and technicians,” said Maurice Miller,
link hidden, please login to view vice president of customer success. Once Autel tablet owners register their tool for Mercedes-Benz vehicle SGW access with AutoAuth, they can perform restricted functions, including clearing codes, active tests, special functions, service resets, coding and adaptations, and Advanced Driver Assistance System (ADAS) calibrations, according to
link hidden, please login to view. Mercedes-Benz vehicles with the SGW include 2021 and newer CLE (236), GLC (254), EQE (294), EQE (295), EQS (296), S (223), and C (206) models.
Mercedes-Benz is the latest automaker to authorize Autel tablets to access SGW-protected systems via AutoAuth. Technicians can also access Nissan and Stellantis (Chrysler, Dodge, Jeep, Ram, Fiat, Alfa Romeo and Maserati) vehicles with an SGW via an AutoAuth-registered Autel tablet, the company explained.
When it comes to modern vehicles, the performance and reliability we expect are largely due to the integration of sophisticated electronics and systems. One such essential component is the OEM (Original Equipment Manufacturer) Control Module. These modules play a critical role in the functionality of a vehicle, ensuring that everything from engine performance to safety features is operating at its best. But what exactly are OEM control modules, and why are they so important?
What Are OEM Control Modules?
OEM control modules are electronic units that control and monitor various functions within a vehicle. These modules are designed and produced by the vehicle’s original manufacturer, which ensures that they meet the highest standards for performance, durability, and compatibility. These modules are responsible for managing crucial systems in a vehicle, such as the engine control system (ECM), transmission control, and braking systems.
Unlike aftermarket parts, which are produced by third-party manufacturers, OEM control modules are specifically designed to match the vehicle’s make, model, and year. As a result, they offer a precise fit and functionality, ensuring the highest level of performance and reliability.
Why Are OEM Control Modules Important?
Enhanced Vehicle Performance: OEM control modules are engineered to interact seamlessly with the other systems in a vehicle. When these modules are working properly, they ensure that the vehicle runs at optimal efficiency, offering better fuel economy, smoother driving, and reduced emissions.
Guaranteed Compatibility: Since OEM control modules are made by the vehicle’s original manufacturer, they are guaranteed to be fully compatible with the vehicle’s systems. This eliminates concerns about compatibility issues that might arise with aftermarket parts, making the replacement or upgrade process much simpler and less risky.
Durability and Reliability: OEM control modules are built to last. They are designed using the same high-quality materials and manufacturing processes used for the original vehicle components, ensuring they offer long-lasting performance. When you choose an OEM module, you're investing in quality that won't let you down.
Warranty and Support: Many OEM control modules come with a warranty, providing peace of mind that any defects or issues will be covered. Additionally, support from the vehicle’s manufacturer ensures that if there is an issue with the part, you have access to reliable customer service and troubleshooting.
Improved Safety: OEM control modules are directly connected to critical safety features in your vehicle, such as airbags, antilock braking systems (ABS), and traction control. Ensuring these modules are in top working order is essential to maintaining the safety of the vehicle.
The Role of OEM Control Modules in Modern Vehicles
Modern vehicles rely on multiple control modules to ensure that everything from the engine to the infotainment system is functioning correctly. Some of the most common OEM control modules include:
Engine Control Module (ECM): This module manages engine functions such as fuel injection, ignition timing, and emissions control, ensuring that the engine operates efficiently. Transmission Control Module (TCM): The TCM controls the vehicle’s transmission system, adjusting shifting patterns for smoother performance. Body Control Module (BCM): This module is responsible for non-powertrain functions, such as lighting, door locks, and interior comfort features. ABS Control Module: This module manages the anti-lock braking system, preventing wheel lockup during heavy braking and improving vehicle stability. These are just a few examples, but in today’s vehicles, the integration of electronics in the form of OEM control modules is essential for ensuring everything functions smoothly.
Choosing the Right OEM Control Module
When it comes to replacing or upgrading an OEM control module, it's essential to choose one that fits your specific vehicle model and requirements. Working with trusted auto parts suppliers, like Clifford Auto Parts, ensures that you get a quality OEM control module at a competitive price. It’s always a good idea to check with an expert to ensure you're selecting the right part to suit your vehicle’s needs.
OEM control modules are integral components of modern vehicles, offering superior performance, reliability, and compatibility. Whether you're replacing a faulty module or upgrading your vehicle, choosing OEM parts is the best way to ensure your car or truck continues to run at its best. With their long-lasting durability and guaranteed fit, OEM control modules are a wise investment in the future of your vehicle. Always choose quality and reliability by opting for OEM when upgrading or replacing essential control modules.
By understanding the importance of OEM control modules, vehicle owners can make informed decisions that ensure their vehicle performs optimally for years to come.
link hidden, please login to view announced its new USMW professional series link hidden, please login to view are now available. The new fuel pump modules provide application coverage for several Toyota, BMW, RAM and Nissan vehicles.
Visit
link hidden, please login to view for detailed applications, or contact customer service for further information.
