The thermostat is a crucial component in your car's engine system, playing a vital role in regulating the engine temperature. Contrary to common beliefs, removing your car's thermostat can lead to severe consequences, affecting fuel efficiency and engine lifespan. In this article, we will explore the benefits of retaining the thermostat and explain why removing it should be avoided.
      Wiper blades keep your windshield clear, but since they’re made of rubber, they wear out with time and need to be swapped out regularly.  How long they last really depends on how often you use them, where you drive, and whether you take care of them. Watch for these signs that indicate it's time for new wipers:
      Streaking or Noise
      Visible Damage
      Age Considerations
    • By Teddy
    • By Jacky Xine
      How would you love to modify your pickup? I will show mine first.
      I have changed the grille, headlight, and the side steps. How about it now?
      How car wiper works
      Wiper Blades
      Wiper Arms
      Wiper Motor
      Linkage
      Wiper Pivot
      Wiper Switch
      Wiper Relay
      How It All Works Together
      Intermittent Wiping
      Washer System
