Both ceramic and metallic brake pads have their own advantages and disadvantages, and which one is better depends on your specific driving needs and preferences.
are usually quieter and produce less dust than metallic brake pads. They also tend to last longer and provide better stopping power when the brakes are applied. However, ceramic brake pads can be more expensive than metallic brake pads and they may not perform as well as metallic brake pads in extreme driving conditions, such as high-speed driving or racing.
, on the other hand, are typically less expensive than ceramic brake pads and are better suited for high-performance driving situations. They also tend to provide better stopping power when the brakes are hot. However, metallic brake pads can be noisier and produce more dust than ceramic brake pads. They also tend to wear down brake rotors more quickly.
Ultimately, the decision between ceramic and metallic brake pads comes down to your individual driving needs and preferences. If you prioritize quietness and low dust production, ceramic brake pads may be the better choice. If you need better performance in high-speed or extreme driving conditions, metallic brake pads may be the better choice.
    • By abiztime
    • By abiztime
      5, Pallet
    • By abiztime
