When rebuilding engines i've always used Lucas assembly lube never had any problems, but it runs easy, and i want something that will stay on cam lobes better so when i coat a flat tappet cam, i want something more tacky that will stick the cam lobes, any reccomendations?
Edited by MCT
    • By ctplg
      How To: Replace a Tail Light Assembly in a 2009 to 2015 Toyota Tacoma
