When you fix cars for a long time, you hear some crazy stuff – like putting cornmeal in the radiator to stop a leak. It’s true. That used to be one of the “backyard” remedies floating around. I hate to earn the “Captain Obvious” nickname, but I’m willing to take the chance. So just in case, before I go any further, let me be clear: Do NOT do that.
Another old falsity that used to float around was that if your thermostat was stuck, causing engine overheating, all you had to do was simply remove it. In an emergency, this would at least get you home, but again, not an acceptable repair. This one, however, is at least understandable as we get into the evolution of thermostats.
The majority of early automobiles utilized a cooling system known as a thermosyphon system. There was no thermostat or water pump. The hot coolant would rise upward through the engine, out through the upper radiator hose and into the upper radiator tank. Water becomes denser as it cools, and as it did, it would fall downward through the radiator, into the lower tank and then back into the engine.
This type of system worked fairly well for the time, but heavy use often caused overheating, and the use of a thermostat and water pump was a necessary advancement as cars got heavier and more powerful.
Bellows-Style Thermostats
Leaving out a few obscure short-lived designs, early thermostats utilized a bellows system (see Figure 1). Inside the bellows was a liquid that, when heated, would change into a gas. As the liquid boiled and changed to gas, the bellows would expand, opening the valve to allow coolant to flow. These were susceptible to failure, and they also were affected by pressure changes. This was not a problem early on, because early cooling systems were not pressurized. Once we began to utilize pressurized cooling systems, the pressure built in the system sometimes would force these shut and cause overheating.
Figure 1
The solution was the wax-style of thermostat (see Figure 2) in which the wax changed from a solid state to a liquid, eliminating the pressure effect on the previous liquid-to-gas style. A piston in the wax pushed a rod that opened the valve. A spring was utilized to force the valve shut as the wax cooled and returned to a solid. This style of thermostat became the standard thermostat of the time, and by the 1960s was the primary thermostat in use for new cars, as well as direct replacement for any that still had a bellows-style.
Figure 2
Double-Valve Thermostats
While this overall design stood the test of time, there was one evolutionary change to it with the double-valve thermostat (see Figure 3). The double-valve thermostat, in conjunction with cooling system design, allowed more precise temperature control. To understand this, you first have to understand thermostat bypass. It is beneficial for coolant to flow through the engine when the thermostat is closed – to eliminate hot spots, allow the engine to warm up evenly, improve fuel vaporization and allow sufficient warm coolant to flow past the thermostat so it opens when needed.
Figure 3
Although various different bypass designs were used on early thermostat-controlled systems, most American cars in the 1960s utilized an open bypass (a whole other article) along with the traditional wax thermostat in Figure 2.
Fuel injection, fuel economy and reduced emissions demanded more precise temperature control, and that’s where the double-valve thermostat came into place. When the thermostat is closed, it allows all the coolant to circulate back through the engine to provide an even warm up. As the thermostat begins to open, it allows some coolant to flow to the radiator, yet some to circulate back into the engine. When the temperature rises above a certain point, the thermostat opens fully, blocking the bypass and sending all coolant to the radiator. This overall operation allows the engine to remain at a very consistent operating temperature by preventing a drastic hot/cold change each time the thermostat opens.
A review of what a thermostat does is the best way to understand why they’re so important on today’s engines. By blocking coolant flow to the radiator, it allows the engine to warm up quickly, which is important for drivability, heater performance and emissions. The thermostat opens fully at a specified temperature to allow coolant to flow into the radiator. A thermostat rating is part of cooling-system design because they also must give the coolant enough time in the radiator to cool off. Installing a cooler thermostat doesn’t always mean the engine will run cooler. Even more critical as engine-management technology continues to advance, extremely precise control of engine temperature is necessary to maximize fuel economy and minimize emissions.
Electronically Controlled Thermostats
This need for this precision brought about the latest thermostat in the evolutionary chain: the electronically controlled thermostat (Figure 3). Fuel economy, power output and emissions all are affected by engine rpm, load and temperature, and to obtain the highest efficiency possible under all operating conditions, we must have infinite control over temperature. With the electronically controlled thermostat, the vehicle computer now has that control.
Their operation is almost exactly what we’re already used to. They’re still wax-operated but designed to open at a failsafe temperature to keep the engine from overheating. The electronic part is a heater that heats the wax to cause the thermostat to open or close exactly as needed. If the electronic circuit fails, the thermostat still will open in time to prevent overheating. An electronic thermostat requires a scan tool for circuit monitoring and control during diagnosis. Coupled with other cooling-system advancements such as electric fan control, variable-flow coolant pumps and active grille shutters, it’s safe to say modern cooling systems are dialed in. It’s a far cry from throwing the thermostat out and dumping in some cornmeal.
      Hahn Automotive Warehouse announced the passing of General Manager Bobby Scheer, a key member of the founding Scheer family, former owners of Prime Automotive. The company said he passed away peacefully on April 2, 2025, leaving behind a legacy of dedication, hard work and a passion for both family and business that inspired all who knew him.
      The company added that Scheer was a successful entrepreneur, but, more importantly, he was a loving husband, father and grandfather. He was a pillar of the automotive aftermarket industry and a beloved member of the Hahn Automotive family. Over the years, his unwavering commitment to Prime Automotive and his support for employees and customers helped establish Prime as a leading supplier in the Tri-State area. His continued involvement with the company after the Hahn acquisition was a testament to his enduring love for the business and industry, Hahn said.
      Danny Chessin and Eli N. Futerman, co-presidents of Hahn Automotive Warehouse, shared the following statement:
      “The Hahn family, along with all those whose lives were touched by Bobby’s leadership, friendship and generosity, will miss him dearly. We find comfort in knowing that his core values will continue to guide us, and that the foundation he built will serve as a lasting tribute to his remarkable life and career.”
      Hahn added that Scheer’s memory will live on as a blessing to his family, colleagues and all who had the privilege of knowing him.
      SPRINGFIELD, Mo., April 01, 2025 (GLOBE NEWSWIRE) -- O’Reilly Automotive, Inc. (the “Company” or “O’Reilly”) (Nasdaq: ORLY), a leading retailer in the automotive aftermarket industry, announces the release date for its first quarter 2025 results as Wednesday, April 23, 2025, with a conference call to follow on Thursday, April 24, 2025.
      link hidden, please login to view (NMG) announced it is celebrating 50 years of aftermarket innovation, marking the journey that began with the founding of Transtar Aftermarket Solutions on April 1, 1975. As NexaMotion looks ahead to the next 50 years, it now has 125 locations and over 1,500 team members, representing the industry’s leading brands in transmission and general repair, the company said. “Our commitment to supporting repair shops goes beyond being a supplier of products,” said Neil Sethi, CEO of
      link hidden, please login to view. “We look to develop innovative solutions to help simplify complex vehicle repairs. This requires more than just auto parts; it requires a dedicated partner. Today, as we look ahead to our next 50 years, we will continue to innovate and expand our parts selection, network and new solutions to help our customers evolve and advance in an increasingly complex industry.” NexaMotion Group said it has been on an aggressive growth and expansion plan over the last two years, acquiring five different businesses that align with the company’s long-term strategic plan, growth trajectory and goals. The company continues to invest in state-of-the-art tools, platforms and technologies like
      link hidden, please login to view to help drive the success of auto repair shops. According to Sethi, connected vehicles are poised to transform how vehicles are diagnosed and repaired. “Technology is reshaping the future of automotive repair,” he said. “We’ll be able to leverage AI tools and platforms to streamline the process for repair shops from diagnostics to parts ordering and all the way through to vehicle programming.” He added, “As an innovation-driven company, we will remain at the forefront of developing trends by being a solutions provider.”
      As NexaMotion Group looks ahead to the next 50 years, connected vehicles are set to transform the repair shop ecosystem. The company’s products and services will be an integral part of this evolving landscape. Staying closely aligned with customer needs, NexaMotion Group said it remains committed to its mission: simplifying complex vehicle repair to keep the world moving.
      Holley Performance Brands announced an expansion of its automotive chemicals portfolio with three new products: NOS Octane Booster, Holley Carburetor Cleaner and Baer Spray Brake Cleaner. Holley said the new product lineup will deliver solutions for automotive enthusiasts and racers seeking improved power output, superior cleaning and enhanced system efficiency. The announcement follows the news of Holley’s new agreement to be the exclusive developer and distributor of Cataclean products in North America.
      “The expansion of our chemicals portfolio reflects our ongoing commitment to delivering high-performance solutions that our customers trust,” said Matthew Stevenson, president & CEO, Holley Performance Brands. “By leveraging our iconic brands in this market, we are equipping drivers with the tools to enhance their vehicles’ performance, safety and reliability and strengthening our role as a global leader in the automotive aftermarket.”
      Boosting Power and Cleaning with Confidence
      link hidden, please login to view said the Octane Booster from NOS is designed to raise octane levels of fuel by up to five numbers for high-compression sport and race engines. The company added that it delivers improved horsepower, reduces NOX emissions and promotes better engine knock protection. The sensor-safe, made in the USA formulation fills a critical role of preventing pre-ignition and damage and its significant octane-boosting capabilities make it exclusive for off-road, race-only enthusiasts looking for maximum power, Holley said. The company also said the Holley Carburetor Cleaner is formulated to be tough on deposits and carbon buildup while remaining safe for sensors, plastics and metal components. Engineered for carburetors and throttle bodies, its versatility extends to a variety of engine types to restore responsiveness and ensure smoother operation. Made in the USA, this professional-grade product is designed for both performance enthusiasts and everyday drivers, the company said.
      link hidden, please login to view added that the Baer Spray Brake Cleaner is designed to optimize brake system performance. Made in the USA, Baer Spray’s low-VOC formula removes machining oils, factory coatings, dirt and grease, ensuring a proper break-in for new pads and rotors. Baer Spray helps reduce brake noise, enhance brake bite and improve overall braking efficiency – making it an essential tool for both professional mechanics and DIY enthusiasts. Holley said the NOS Octane Booster and Baer Spray Brake Cleaner are now available, while the Holley Carburetor Cleaner is available for pre-order.
      link hidden, please login to view announced the creation of NEXUS Automotive Turkey, which it said will increase development opportunities within the N! Community in the country. The new entity is based in Ürmaniye, Instanbul. With a presence in 145 countries, with 523 members, 2,319 WDs, 96 suppliers and close to 10,000 retail stores, NEXUS said it is equipped to strengthen its efforts in Turkey.
      A news release from NEXUS announcing the development said NEXUS Automotive Turkey will strive to become a leading force in the Turkish aftermarket, based on turnover, product range and distribution capacity. The new structure will play a critical role in enhancing NEXUS positioning, developing next-generation collaborations, smart supply solutions and the digital transformation shaping the future of the industry with its key stakeholders. “With NEXUS Automotive International’s global strength, extensive supply network and innovative solutions, NEXUS Automotive Turkey’s ambition is to unlock the full potential of the Turkish automotive aftermarket,”
      link hidden, please login to view explained. The founding shareholders of NEXUS Automotive Turkey include NEXUS Automotive International, Dinamik and Genckaya, demonstrating the intent of striking a balance between international support and the expertise in the local automotive aftermarket. NEXUS said the initiative aims to satisfy the Turkish market demand for new solutions of leaner supply chains, digital transformation and alternative sourcing strategies. Turkey is also a very important region of the aftermarket, with over 30 million cars with an average age of
      link hidden, please login to view. “We are very excited to launch NEXUS Automotive Turkey. Its role will be crucial in strengthening our position as leader in a market with great potential. The structure will also help with aligning more closely with both our suppliers’ and members’ expectations. Developing the Turkish automotive aftermarket will be instrumental to our next chapter,” said CEO Gaël Escribe.
