Pick a parking lot, any parking lot, and you can tell what spaces get used the most by the number of oil spots. It’s easy to think of it as just a mess, but the unfortunate reality is it’s a bigger cause of pollution than meets the eye.
Who remembers the Exxon Valdez? It was huge news in 1989 as the damaged oil tanker spilled almost 11 million gallons of oil into the ocean. If that seems terrible, think of this: It’s estimated that in America alone, we contaminate our water supply with approximately 180 million gallons of oil every year, and it comes out of our cars!
When an engine is running, oil is everywhere inside. It splashes and runs all over the place, so just like a rainstorm will find a leak in your roof, if oil can find even the tiniest of holes, it will seep out. Aside from the environmental affects, it tends to coat the outside of the engine and the engine compartment, making it difficult to pinpoint the source.
Most of the time, oil leaks aren’t discovered until there are drops in the driveway, or when a look under the hood discovers the problem – which means it’s already had plenty of time to make a mess. Professionally, they sometimes can be hard to find, but generally speaking, there are only a few common causes that make up the majority of the leaks “on the road.”
Starting From the Top
Valve-cover gaskets are one of the most common leaks. They’re on the top of an engine (the majority of the time), and when they leak, the oil runs down over everything. The big problem with this is if there’s another source of an oil leak, it will be hard to identify because it will be overrun by the oil from the cover gasket.
In addition, oil can be very damaging and when it comes from the top down, it gets on hoses, wiring and other components that can slowly degrade from continuous exposure. This leads me to another point.
Often, cleaning is the first step to finding a leak and to prevent it from damaging other components. Engine degreaser, cleaning brushes, shop towels and some form of oil-dry are excellent upsells.
Valve-cover gaskets also are a common culprit for causing hidden leaks. A vast majority of the vehicles on the road feature a combustion-chamber design that locates the spark plug in the center of the combustion chamber, meaning access is through the valve cover. This requires spark plug tube seals to prevent oil from getting into the plug well and on the plug-wire boots. Regardless of the type of ignition, the plug-wire boots will be damaged if oil gets on them.
If someone is replacing this style of valve-cover gasket, it’s a perfect time to sell plugs and wires while they’re in there, or if they’re doing plugs, why not sell a new cover-gasket set to prevent these leaks before they happen?
Pressurized Leaks
Most leaks are oil that simply finds a way out due to an aged gasket or seal, but some have a little extra help. Pressurized leaks (at least that’s what I call them) originate from a component that is directly connected to the oil-pressure circuit, such as an oil-pressure switch or the oil filter itself. Filters are easy to see, but switches, oil-galley plugs and filter flanges often are buried. An indication of a pressurized leak is one that starts to drip shortly after the engine is started and continues dripping at a consistent pace.
Common Mistakes
One of the most common service mistakes in general is not replacing the oil-pan drain-plug gasket during an oil change. Sure, you might get away with it once, but they’re designed to be replaced every time, and the telltale drop of oil that always hangs off the bottom of the drain plug is the giveaway. Who knows how many gallons a year this mistake alone could add up to!
When replacing the oil filter, it should be routine to clean the filter flange and make sure the old seal isn’t stuck to it. But many people still ignore the practice. A dirty flange will prevent a good seal, and if the old seal is stuck to it, you’ll be faced with a major leak.
Another common cause of leaks originates from using the incorrect gasket. There’s something to be said for quality, but there’s something to be said for the original design of a gasket too. Cork and cork-rubber gaskets are old news and old technology, but in many cases, they’re still the best for their application. This generally is a reference to vintage automobiles. The easiest way to know is to look up what the original style of gasket was.
If a cork variation was original, and the engine still features original components, then stick with cork. Many of these engines featured rough cast surfaces on which a cork gasket would conform. In some cases, a rubber replacement will work, but generally, many new rubber seals are designed to work with smooth, machined surfaces. I’ve seen the most advanced gaskets in the world leak like a sieve, only to have an original cork seal it up in an instant. If you stick with the OE style of gaskets, it’s an easy way to ensure success.
Shaft Seals
Shaft seals, referring to crankshaft, camshaft and/or intermediate shaft seals, are common leak sources when an engine starts to get some miles on it. These seals see a lot of abuse due to the fact that the shaft is continuously rotating inside it when the engine is running. A thin film of oil keeps the shaft from instantly gripping the lip of the seal and ripping it to shreds, and on most seals, a small spring on the inside keeps the lip tensioned against the shaft.
When these begin to leak, the oil has a tendency to get on the timing belt, if equipped, which can spell disaster. Often, the leaks can be seen originating from the area of the shaft, and if oil is present after removing the timing-belt cover, you can bet one or more is leaking. These seals can harden and leak with age, but lack of oil changes creates acidity in the oil that will damage them and shorten their life. This is yet another reason that regular oil changes are important.
Installation
Any gasket or seal is only as good as the installation. Many gaskets or seals are designed for low-torque applications, and some have very specific spots to apply a sealant. Following manufacturer instructions is the only way to do it. Too high or too low a torque can ruin the job, and “more is better” is not the slogan of any sealant company I know of. Since many gaskets call for small amounts of sealant, this also is another great upsell.
When it comes to shaft seals with a spring-tensioned lip, a common practice is to use a small amount of grease to hold the spring in place, preventing it from falling out during seal installation. A good engine assembly grease should be used for this, since it will dissolve in engine oil. Fixing oil leaks is good for business. You sell parts. But it’s even better for the world and future generations.
      link hidden, please login to view. While that might sound like just another specification in a long line of upgrades, for professional parts counter pros selling to independent repair shops, it’s a moment that carries real-world impact. Understanding what’s new—and how to help shop owners explain it to their customers—could be the difference between a routine oil sale and a value-driven recommendation.  First, What Is GF-7?
      link hidden, please login to view. “The caveat is that GF-7B category. Some engines don’t like thin oil because they’re just not made to operate that way. You have to be careful about misapplication.   “The OEMs identified that and developed a shield icon with 0W-16 label to make it easy to identify it versus 0W-20 or heavier oil,” he said.
      Selling the Upgrade
      Bottom Line for Counter Pros
      Are you adding engine oil the wrong way?
      SPRINGFIELD, Mo., March 13, 2025 (GLOBE NEWSWIRE) -- O’Reilly Automotive, Inc. (the “Company” or “O’Reilly”) (Nasdaq: ORLY), a leading retailer in the automotive aftermarket industry, today announced that its Board of Directors (the “Board”) approved a 15-for-1 split of its common stock, to be effected in the form of a one-time special stock dividend.
      Purolator announced the launch of its 20K Premium Oil Filter. Designed for high-performance driving conditions, the 20K Premium Oil Filter provides superior engine protection for up to 20,000 miles and is geared toward drivers who demand reliability and durability alongside affordability, Purolator said.
      A news release announcing the product explained that the
      link hidden, please login to view is engineered with high-density, synthetic blend media that captures more than 99% of dirt and contaminants. Purolator added that it is optimized for vehicles that experience frequent towing, off-roading, and stop-and-go traffic. Additional features include a silicone anti-drainback valve to prevent dry starts, a PuroSEAL gasket for superior leak protection, and a PuroSTEEL casing that withstands extreme pressure. “We are thrilled to introduce the Purolator 20K Premium Oil Filter exclusively at Walmart,” said Daryl Benton, vice president of sales and marketing for the automotive aftermarket with MANN+HUMMEL. “The Purolator 20K represents the next level of filtration technology, delivering long-lasting performance and durability for today’s most demanding drivers.”
      Customers can find the Purolator 20K Premium Oil Filter exclusively on Walmart.com, or in select Walmart stores nationwide.
      A Dynamic Kickoff
      The Purolator 20K Premium Oil Filter was officially unveiled at Purolator’s state-of-the-art manufacturing facility in Fayetteville, North Carolina. Attendees, including automotive media, influencers and industry professionals, witnessed firsthand how the Purolator 20K Premium Oil Filter (and all Purolator filters) is tested and manufactured to the highest standards,
      link hidden, please login to view said. Interactive experiences allowed guests to explore the technology behind the Purolator 20K. Education and perspective came in the form of a panel discussion and production tour led by industry experts who played crucial roles in developing and bringing to market the Purolator 20K. Subject matter experts included Purolator’s lead product engineer and Walmart automotive merchants. “Purolator’s commitment to innovation and quality aligns perfectly with Walmart’s mission to provide customers with great products at an incredible value,” said Scott Bayles, vice president of merchandise – automotive, Walmart US. “The Purolator 20K Premium Oil Filter is a game-changer for drivers looking for long-lasting performance, and we’re proud to offer it only at Walmart.”
      Purolator added that the Purolator 20K and Purolator air filtration will be used on more than 1,000 horsepower Formula Drift cars driven by Odi Bakchis, Dan Burkett, Rome Charpentier and Ryan Tureck for the 2025 season. Those drivers also attended the launch event and challenged guests to a special drift driving experience.
      Lucas Oil has announced the latest addition to its vehicle performance product lineup: Lucas Emissions Clear. The company said this fuel and exhaust system cleaner addresses the need for effective solutions to reduce vehicle emissions and improve catalytic converter performance, helping vehicle owners meet strict emissions regulations.
      In a news release announcing the product, the company explained that Lucas Emissions Clear Fuel and Exhaust System Cleaner targets the entire fuel delivery system, removing harmful deposits that contribute to excessive exhaust emissions. By reducing particulate matter before it reaches the catalytic converter, the product helps extend its lifespan, optimizes combustion and improves emissions catalyst effectiveness. Formulated for easy integration into routine vehicle maintenance or pre-emissions testing, Lucas Emissions Clear is a one-tank treatment that provides emissions control, promotes cleaner air quality and is compatible with any gasoline engine, the company said.
      “A cleaner engine means a more efficient, more reliable car, and Lucas Emissions Clear delivers exactly that for drivers,” said
      link hidden, please login to view CEO Morgan Lucas. “We take pride in helping our customers save money on repairs and maintenance. Cleaner emissions not only contribute to a healthier environment, but also extend the lifespan of exhaust systems, providing long-term financial benefits for drivers and helping to meet more stringent regulations. With this product, we are making it easier and more affordable to maintain optimal performance and compliance with emissions standards.” Designed for environmentally conscious vehicle owners, fleet managers, automotive enthusiasts and drivers seeking improved fuel efficiency and performance, Lucas Oil said its Emissions Clear can cut harmful pollutants by up to 90% while delivering up to 5% improvement in fuel economy.
