The popularity of turbocharged gasoline engines has surged over the past 20 years. According to the Department of Energy, approximately 1% of all 2000-model-year light-duty vehicles were turbocharged. Fast-forward to today, and more than one-third of all light-duty vehicles are turbocharged.
So, why the rapid change? That’s simple: fuel-economy standards. Current CAFE standards call for automakers to increase the average fuel economy of their lineups to 54.5 mpg by 2025. To meet these regulations, automakers have needed to innovate. This innovation has led to the advent of new technologies that have changed the entire industry.
Today, automakers are building vehicles that are safer than ever before, with more creature comforts. They’re more powerful despite the fact that the engines are smaller in displacement – yet the average customer doesn’t realize that anything has changed. Two of the key technologies that have helped to boost fuel economy and horsepower with less displacement are gasoline direct injection and turbocharging.
Direct Injection
These systems are able to measure and control the amount of fuel entering the combustion chamber more accurately, boosting fuel economy and maximizing power output.
The low-pressure fuel pump is mounted inside the fuel tank, and it sends fuel through the fuel lines and up to the high-pressure fuel pump. This pump is mounted on the engine and is driven by a special lobe on the camshaft. The fuel pressure then is increased to extremely high pressures; some applications may see 3,000 to 5,000 psi. The fuel then travels to the injectors that are mounted inside the cylinder head and injected directly into the combustion chamber.
Why does the fuel pressure need to be so high? Port fuel injectors spray fuel in a vacuum, and that vacuum draws the fuel vapors into the combustion chamber. Direct injectors need to be able to overcome the higher pressures seen inside the combustion chamber, so the fuel pressure needs to be much higher compared to port injection. The increased fuel pressure has another benefit: The fuel is able atomize much better compared to port fuel injection. The more atomized the fuel is, the better it burns, and the engine can run much more efficiently.
Turbocharging
Turbocharging allows automakers to build engines that produce more power with less displacement, and sometimes with fewer cylinders.
How does a turbocharger work? Let’s talk about it in simple terms. Gasoline engines burn a mixture of air and fuel. The engine can only draw in a fixed amount of air on its own, so the ECU controls the amount of fuel added to the combustion chamber to maintain the optimum air and fuel mixture. Turbochargers increase the air flow into the engine. This means that more fuel can be added, and the engine can make more power.
Inside the turbocharger you’ll see a shaft with a turbine wheel on one end, and a compressor wheel on the other. The turbine is driven by exhaust gasses leaving the engine. This spins the compressor wheel that forces more air into the intake manifold. This increased air flow and pressure is known as boost, or charge air. The charge air typically passes through an intercooler or heat exchanger; this removes some of the heat and makes the air denser. The air then travels to the combustion chamber.
A Winning Combination
GDI and turbocharging each have their advantages, but when combined, they offer even more. In many late-model vehicles, lower-displacement engines with GDI are able to produce 20% more power with 20% less displacement when compared to bigger engines from a decade ago.
Everywhere you look, it seems that engines have gotten smaller in displacement. Ford has its EcoBoost four-cylinder and V-6 engines, Nissan/Infiniti has its 3-liter VR engines and Chevrolet recently started offering a 2.7-liter turbo in the Silverado. Ford and Chevy also offer three-cylinder turbo engines in some of their smaller offerings. These smaller-displacement engines offer better fuel economy than the engines they’re replacing, but without turbocharging they wouldn’t be able to offer the same sort of power.
This is where smarter boost comes into play. Smaller-displacement engines can use smaller turbos to fill in gaps in the powerband. Smaller turbos are able to spool up faster, leading to better response and more predictable power delivery. Modern turbos are mounted closer to the engine than ever before. This means the exhaust gasses don’t have to travel as far once they leave the combustion chamber, and the turbo can spool up faster.
Add-On Sales Opportunities
As parts professionals, it’s our job to know how these systems work, and what our customers need to know whenever they’re replacing components in the system. Here are a few tips and tricks to be aware of next time you’re selling GDI or turbocharger parts.
The fuel system needs to be depressurized before starting a repair. There are a number of ways this can be achieved. Your customers could remove the relay for the supply pump inside the fuel tank and crank the engine. With no supply of fuel, the HPFP won’t have anything to pressurize. However, a better alternative is to use a scan tool to depressurize the system. This method typically redirects the fuel back to the fuel tank, so it won’t put any strain on the system. They can confirm that the fuel system has been depressurized by checking the reading from the fuel-pressure sensor.
Your customers should pay close attention to the seals on the injectors. In most applications, the seal ring that seals the injector to the combustion chamber cannot be reused. These seals often are made of materials such as Teflon and will require special tools to install them. The seal needs to be carefully and uniformly stretched as it slides into position. Then it’s resized to fit into the groove on the end of the injector. It’s best to check the OE service information whenever servicing the injectors.
The high-pressure fuel line is another component that may not be reusable during service. In many applications, the fittings on the ends of the line will have a sealant applied inside the threads, or the fitting may stretch or crush during install to form a tight seal. You also might see a yellow tag or sticker on the fuel line that says, “HIGH-PRESSURE FUEL LINE, DO NOT REUSE,” or something similar.
During turbocharger service, it’s important to avoid some of the most common installation errors. An example would be failing to properly clean gasket surfaces, neglecting to replace gaskets during service or failing to clear out debris from a previous failure. A restricted or blocked oil-supply line can quickly lead to oil starvation and turbocharger failure. Your customers always should clean the area where the engine-oil supply and return lines connect to the engine crankcase, being sure to prevent any debris from entering the engine oil or crankcase. Oil contamination can lead to additional engine damage. Always remove and inspect the engine-oil supply and return lines for blockage or restriction, or replace them entirely. Finally, always replace the crush seals on banjo-bolt connections.
    • By NAPA
      Brad Sweet and the
      link hidden, please login to view No. 49 team returned to action for the 2024 season in spectacular fashion, winning at the DIRTcar Nationals at Volusia Speedway Park in Florida.
      Four nights of racing began on Wednesday with the Big Cat showcasing his skills right from the start. The Kasey Kahne Racing driver qualified fourth in Flight A with a blistering time of 13.513 seconds. He continued the momentum in his heat race, securing a second-place finish and guaranteeing him a spot in the Fast Pass Dash. Sweet dominated the dash, picking up the win after starting on the pole. In the first main event o f 2024, the NAPA No. 49 machine proved unstoppable for 25 laps, earning the win and solidifying Sweet’s status as a giant of the sprint car world.
      On Thursday night, however, a different story unfolded for the five-time champion. Sweet qualified fifth in Flight B, posting a solid time of 13.430 seconds, but his heat race presented a challenge. He started third but slipped to fourth, relegating him to a 14th-place starting position in the feature. He ultimately finished 15th,  determined to bounce back on Friday night.
      On Friday, the NAPA team hit the reset button and prepared for another shot at a win. Sweet posted a time of 13.359 seconds in qualifying, securing the third spot in Flight B and setting a strong tone for the evening. During heat race action, competitor David Gravel ran Sweet up the track, forcing him over the cushion and into the brakes of the No. 49 machine. He regained momentum, though, and ultimately finished third after starting second. Friday’s feature race truly highlighted Sweet’s racing prowess as he battled his way through the field from a 10th-place start to finish on the podium in third.
      On the final night of the DIRTcar Nationals, the NAPA No. 49 team had one last shot at a $20,000 payday. The Big Cat hit the charts at 13.452 seconds in qualifying, placing him fifth. In his heat race, Sweet charged from third to second, placing him in the dash. Although he did not advance from his eighth-place starting spot in the dash, Sweet continued undeterred into the feature race. He stood out among the fierce competition, climbing from an eighth-place starting spot to another podium finish of third. Sweet and the NAPA team ended the weekend third in overall event points.
      Next up for the Sweet and the No. 49 team is the start of the High Limit Racing season at East Bay Raceway Park in Tampa.
      Start / Finish:
      Wednesday, Feb. 7: 1 / 1
      Thursday, Feb. 8: 14 /15
      Friday, Feb. 9: 10 / 3
      Saturday, Feb. 10: 8 / 3
      Next Race: Monday, February 12, East Bay Raceway Park, Tampa, FL
      How to Watch or Listen:
      link hidden, please login to view NAPA:
      link hidden, please login to viewBrad Sweet:  link hidden, please login to view
      Kasey Kahne Racing:  link hidden, please login to view The post
      GB Reman announced the release of 17 gasoline-direct-injection (GDI) part numbers including GDI injectors, seal kits, fuel lines and a premium GDI seal-replacement tool kit.
      The additional part numbers enhance GB Reman’s remanufactured GDI program with added coverage for more than 2,300 unique vehicle applications and more than 24 million vehicles in operation.
      “We are very proud of this release, especially with the highly anticipated expansion of our industry-leading GDI program,” said Joe Evert, director of engineering & operations. “Our commitment to quality is the cornerstone of our GDI program’s popularity. We take great pride in delivering top-notch products, rigorously tested to ensure superior performance and backed by a stellar warranty for peace of mind. Our team of experts and our dedication to excellence sets us apart, making GB Reman the trusted choice for those who demand the best in performance, reliability and customer service.”
      GDI Fuel Injectors & Seal Kit
      GB Reman’s line of remanufactured fuel injectors are remanufactured using a proven 15-step process at its state-of-the-art facilities in Long Beach, California, according to the company.
      All injectors include new external seals, O-rings and filters. In addition, all GDI injectors include pre-installed combustion fuel-inlet seals and necessary hardware to ensure a complete and trouble-free installation.
      Once remanufactured, each injector is 100% tested under multiple operating conditions to ensure it meets or exceeds OEM specifications for flow rate, spray pattern, coil resistance, form, fit and function.
      View the company’s
      link hidden, please login to view for a complete list of part numbers and application data. GDI Fuel Injector Multi-Packs
      GB Reman released two GDI fuel-injector multi-packs (PNs: 835-11156PK, 835-11158PK) covering 495 unique vehicle applications and more than 6 million vehicles in operation.
      Replacing GDI injectors in sets ensures balanced performance, consistent fuel atomization, and prevents drivability issues by maintaining uniformity across all cylinders. While it may involve a higher initial cost, replacing injectors in sets promotes cost-effectiveness in the long run by reducing the likelihood of future repairs and optimizing overall vehicle longevity.
      GDI Fuel Lines
      GB Reman released six GDI fuel lines (PNs: 892-001, 893-001, 893-002, 893-003, 895-001, 895-002) covering more than 1,000 unique vehicle applications and more than 9 million vehicles in operation.
      GDI fuel lines are responsible for delivering pressurized fuel from the fuel tank to the GDI injectors located near the combustion chamber of each cylinder. They play a crucial role in ensuring that the engine receives the right amount of fuel at the right pressure for efficient combustion. The fuel lines are designed to withstand the high operating pressures associated with GDI systems, which can be significantly higher than those in traditional port fuel-injection systems.
      Premium GDI Seal Tool Kit
      GB Reman released its new premium GDI seal tool kit (PN: GBTK-0001). The tool kit can be utilized to reseal more than 100 unique GDI injectors, covering more than 70 million vehicles in operation, according to the company.
      As part of any GDI injector replacement procedure, all injectors on the fuel rail must have their injector seals replaced. While replacing GDI combustion seals is not technically challenging, proper tools and procedures are necessary to ensure that the seals function properly. For
      link hidden, please login to view, visit the GB Reman link hidden, please login to view. The post
      For vehicles equipped with a gasoline direct injection (GDI) system, a buildup of carbon on the intake valves can cause problems ...
      Subscribe:
      link hidden, please login to view Facebook: link hidden, please login to view Instagram: ...
      Visit Garage Gurus
      link hidden, please login to view for more tips and information on diagnosing and troubleshooting engine problems in ...
