The Features for Precision Machining
- 2,137 views
- 1 reply
- 1,631 views
Whenever a shopper finds a product they need on DormanProducts.com, they now instantly can see which nearby stores have that part in stock, using a new real-time inventory tool announced by Dorman Products.
To use the new functionality, visitors to
link hidden, please login to view can search for a product using either vehicle year, make and model; keywords; VIN; OE number; or visual-hardware drilldown. When they find what they need, they can scroll down on that product description’s page to the updated “Where to Buy” section. There they can view on a map what stores near them have that part available, as well as get directions and click to call. “We are always looking for ways to make it easier for repair shops and DIYers to finish a job. With this new capability, it’s now incredibly easy to find our full range of products,” said Steve Gisondi, Dorman’s vice president of marketing. “You can quickly search our tens of thousands of parts and components on a computer or smartphone, and find where they’re available near you, without the hassle of having to call around to multiple locations.”
This industry-first capability is made possible through a strategic relationship between Dorman and Epicor, a global leader of industry-specific enterprise software. By leveraging Epicor channel connectivity among leading parts-distribution businesses across North America, the Dorman website now connects directly with store-inventory systems at a variety of retailers and distributors to let users know if parts are in stock at specific locations, according to the company.
“Dorman is one of the automotive aftermarket’s most innovative suppliers, so it’s no surprise they are on the leading edge of solutions that bring increased access and convenience to the industry’s end-users,” said Tim Hardin, senior vice president and general manager of Automotive at Epicor. “We are very proud to have played a role in enabling this important new solution for Dorman and the many parts distribution businesses that offer Dorman’s products.”
Dorman parts and components are stocked by hundreds of retailers and distributors throughout North America. Real-time inventory is available now on DormanProducts.com for most of Dorman’s largest retail partners, and new partners and locations are continuously being added.
For more information,
By Jerry Zhang
CNC lathe machining is a procedure for change the workpiece’s dimensions. There are two categories according to the difference of processing method, One is CNC lathe machining, the other is press working.
What is CNC lathe machining
1. CNC lathe machining definition
CNC lathe machining is a procedure for change the workpiece’s dimensions. There are two categories according to the difference of processing method, One is CNC lathe machining, the other is press working. Name:
CNC lathe machining Function: Change the workpiece’s dimensions Category:
CNC lathe machining, Press working Technics Process: Casting, Forging, Stamping, welding 2. Catalog:
(1) Fundamental process
(1.1) Productive Process
(1.2) Productive Category
(1.3) Process Planning
(2) The instruction for benchmark
(2.1) Definition
(2.2) Category
(3) CNC lathe machining Processing Cushion
(4) Scope of application
(5) Types of equipment
(6) China CNC lathe machining manufacturers
3. CNC lathe machining fundamental process
(i) Productive Process
Types of equipment productive processes are the process for making the products from raw material (unfinished blanks).
Types of equipment productive process include raw material transit and storage,
CNC lathe machining production preparing, unfinished blank making,
Precision parts’ CNC lathe machining and heat treatment, precision parts’ assembling, test, painting, and package, etc.
Technics process
In the productive process, there is a technical process.
Technics process is the process to change the workpiece’s shape, dimensions, positions, and character, etc, and make the workpiece to finished precision parts or unfinished blanks.
Technics process is a key part of the productive process.
Technics process includes casting, forging, stamping, welding, CNC lathe machining, assembling, etc.
Types of equipment production technics process include precision parts’ equipment production technics process and types of equipment assembling technics process.
Auxiliary processes
Others are auxiliary processes, for example, transit, storage, power supply, equipment repair, etc.
Technics process also consists of one or several tactic processes, one process consists of several steps.
A process is an elementary unit for types of equipment production technics process.
Process definition
Process definition is the technics process, that one worker (several workers) finish production continuously on one machine (or one position) for the same workpiece (or several workpieces).
The main characteristic of the process is that it doesn’t change the workpiece, types of equipment, or operator, and continuously.
The step is based on the same CNC lathe machining surface, the same CNC lathe machining tools and the same volume of feed
The Feed is a working process, which is a step for production finish on the workpiece’s surface by tools.
Technics flow
When making the types of equipment’s technics process, you have to make sure how many steps the workpiece needs and the sequence.
Technics flow is a simple process of key processes and sequences.
Technics flow is very important for making technics process,
Its function is to select the correct processing method for each surface, make sure the sequence of each surface, and the number of processes.
(ii) Productive Category
Productive Categories are usually divided into three categories,
a. Single workpiece production:
Manufacture different structures’ and dimensions’ workpiece separately, and seldom repeat. b. Batch production:
Manufacture the same structure and dimensions’ workpiece among one year, there is some repeatability in the manufacturing process. c. Mass production:
The quantity is huge, manufacture the same process in the same place. (iii) Process planning
Planning principle
1. Every technological procedure is planned to make sure the quality of precision parts (types of equipment assembling), And reaches all the specifications as the drawing requests. 2. The technological procedure should have high productivity, The products made by technological procedures should be launched as fast as possible. 3. Try our best to decrease the production cost 4. Pay attention to reduce the intensity of labor to ensure production safety. Raw data
1.Assembling drawing, precision parts drawings
2.Inspection quality standard
3.Yearly production program
4.Conditions of manufacture, including types of equipment and specification, performance and current status, workers’ technological level, power and water supply, etc.
5.Process planning, manual, and standard.
6.Advanced manufacture data
Content
1. Analysis product’s assembling drawing and precision parts’drawings.
2. Confirm the blank
3. Make technics flow and ensure the position reference surface
4. Prepare the types of equipment according to each preocess
5. Prepare the blades, jigs, measuring implement, and auxiliary tools
6. Ensure the specification and inspection method for each process
7. Ensure the allowance for CNC lathe machining, calculate the size and tolerance
8. Ensure the cutting parameters
9. Ensure the production time
4. The instruction for benchmark of CNC lathe machining
(i) Definition
Precision part consists of several surfaces,
When analyzing the relative relation of the surfaces, you must confirm a benchmark.
Benchmark is a dot, line, and surface to confirm the part’s dot, line, and surface.
According to the different functions of the benchmarks, there two categories,
One is the design benchmark, the other is the technical benchmark.
(ii) Category
1. Design benchmark:
The benchmark to confirm the dots, lines, and surfaces on the drawings 2. Technics benchmark:
The benchmark for production and assembling. 3. Assembling benchmark:
The benchmark for confirming the parts’ position in the products when assembling 4. Measure benchmark:
The benchmark for inspecting the sizes and position 5. Locate benchmark:
The benchmark for CNC lathe machining. 5. CNC lathe machining Processing Cushion
Definition
When the blank is made to finish the product, you will be machining out the metal layer,
The total of the metal layer is called the total processing cushion.
The metal layer of every process is called process cushion.
As to the circle and hole, the processing cushion is on the diameter, called symmetry cushion.
Why
The reason, why the workpiece has the processing cushion, is to CNC lathe machining out the tolerance or defect on the workpiece from the last process, for example,
The cold layer of casting parts, bubble hole of casting parts, the sand layer of casting parts.Oxide skin of forging parts, surface crack of forging parts, decarburized layer of forging parts.
The surface roughness of CNC lathe machining, etc.
Precision
The processing cushion can increase the precision and roughness of workpieces.
The volume of processing cushion will affect the product quality and production efficiency.
If the processing cushion is too big, it will increase the CNC lathe machining sum of labor,
Decrease the production efficiency, increase the loss for raw material, tools and power,
And increase the production cost.
Selection
If the processing cushion is too small, the tolerances and defects from the last process cannot be removed,
The tolerances for loading and unloading cannot be removed too.
The principle is selecting the smallest processing cushion based on high quality.
1. Different metal parts CNC lathe machining
2. Fabrication, box structure, metal structure
3. Titanium, high-temperature alloy, nonmetal CNC lathe machining
4. Design and manufacture of wind tunnel combustion chamber
5. Design and manufacture of non-standard types of equipment
6. Design and manufacture of molds
Types of equipment
CNC mill CNC grinding machine CNC machine CNC center Laser welding
Electric discharge machining (EDM) Universal grinder WEDM-MS WEDM Cylindrical grinder Internal grinder Precision lathe China CNC lathe machining manufacturers
3 Levels of manufacturers in China
During the development of more than 50 years, there are 3 levels of manufacturers in China,
10% is a top-quality manufacturer, 20% middle quality manufacturer, and 70% low quality & cheap price manufacturer.
The global markets
At present, many markets are growing all over the world, such as Poland, Czech, Turkey in Europe, Thailand, Vietnam, the Philippines, India in Asian, Brazil in South America.
Compared to these new growing markets, China has many advantages based on high quality.
China CNC lathe machining market developing
In the past, everybody think made in China is for cheap and low quality,
It’s because China doesn’t have high precision types of equipment and skilled workers,
It looks like these new growing markets very much.
But now, 10% top quality manufacturer is fully changed,
Their core advantage is high quality, they compete with European and North American famous factories.
Introduction of Sinster
Ningbo Sinster Machine Co., Ltd is one of 10% top quality manufacturer,
You have no risk to cooperate with Sinster,
As many famous brands already choose Sinster and cooperate for long-term,
Such as Supernova, Pelican, ELKA, Cal-van Tools, Firepro, Tecflo, SEB, Keyence, MAUL, RTS, etc.
You can visit the website at
link hidden, please login to view to find more information,
Don’t forget to send inquiry to [email protected] -
By Jerry Zhang
The Guide of Finding Steel Machining Suppliers Suppliers
If you source steel machining parts or stainless steel machining parts for your types of equipment, developments, or system, You have to check the China steel machining parts market. For company owners
You can save quite a lot of money when you buy CNC steel parts for your types of equipment or system. For the designers
You find a lot of quality rapid prototype metal machining suppliers in the China market for your new innovative developments.
For metal machining parts importers,
You can collect a lot of trustable mass production manufacturers in the China market.
China steel machining markets mainly consist of 4 parts
One is the Guangdong market
One is the Zhejiang market
One is the Jiangsu market
The other is the Shandong market
This article is a guide to help you learn everything about the Chinese market, keep reading, and starting to save your money now. Micro or small steel machining
In the Guangdong market
You are easy to find a quality manufacturer in Shenzhen, Foshan, Dongguan.
They don’t have big workshops, many advanced CNC machines, or many workers.
However, they have a lot of experience in making micro or small steel parts or stainless steel parts, as well as metal cutting.
You can input metal machined manufacturers & Shenzhen (Foshan or Dongguan) in the google or Alibaba B2B platform, then you will find many results, choose one and ask them how to keep the quality, you will find a good supplier after you get satisfying answers.
In Zhejiang Market
Zhejiang market is very important for micro or small advance CNC machining parts.
Machining services are most important for local economics.
Each place has its advantage
Taizhou and Zhuji are specialized in brass CNC machining services,
Wenzhou and Jiaxing are specialized in steel CNC machining services,
Ningbo is specialized in stainless steel CNC machining services and aluminum CNC machining services.
If you source brass parts, please go to input brass machining parts & Taizhou (Zhuji).
If you source steel parts, please go to input steel machined parts & Wenzhou (Jiaxing).
If you source stainless steel or aluminum parts, please go to input stainless steel machined parts (aluminum machining parts) & Ningbo.
I recommend Ningbo
As stainless steel and aluminum are most popular everywhere due to environmental protection, human health, and food safety.
Ningbo Sinster Machine Co., Ltd is the best supplier for you,
Please visit its website at
It will let your source easily and guaranteed. Big steel machining parts
In Jiangsu market
Jiangsu market is specialized in stainless steel parts only.
Their advantages are not only micro or small metal machining parts but also big metal machining parts.
Suzhou, Wuxi, and Changzhou are specialized in micro or small machining parts.
Taizhou is specialized in big machining parts, especially stainless steel lost wax casting parts.
If you need big parts, please input stainless steel machined parts & Taizhou.
In Shangdong market
The last market is Shandong, which is specialized in big steel parts only.
Qingdao is the most important part of the Shandong market.
If you need big parts, Please input big machined parts & Qingdao.
Summary for steel machining markets
Above are the 4 important markets for steel machining parts in China.
You can easily find a good supplier according to the above guide.
High-end market
If you are in the high-end market, need high-end performance or surface machining steel parts, stainless steel machined parts, or aluminum machined parts.
Please contact Ningbo Sinster Machine Co., Ltd, who is specialized in high-end parts and have rich experience.
Please click the contact us, and send us an inquiry.
You will get the feedback or quotation in seconds.
Email: [email protected]
By Sunny Tang
Kanou Precision participate in Mfair Bangkok 2019 On 19-21 June, We have many representative samples on the show. Welcome you to visit our Booth (5A24 EH105 Hall).
By Sunny Tang
The quotation of precision machinery parts is mainly composed of three points: First one is Machining material, second is precision machining cost, and the third one is management cost. Every point will affect the price. Kanou Precision keep to take “Creat benefits to the customer” as the cause of action, and constantly to increase the benefits and reduce the cost for the customer.
The customer sends as attachment drawing to Kanou Precision for quotation, This Precision Machined component is a plate. Customer required material is tin bronze, and it has several positions with High precision. Tin bronze material is relatively soft, The machining cost will be higher to sure these high precision sizes. and it will use electrical discharge machining, it will take a long time to do this processing. But we still gave the quotation on time according to the customer's requirements, the cost is relatively high.
link hidden, please login to view At the same time, We tried to ask the customer about the purpose of choosing tin bronze as the material, and what requirements he wants. His main request has two points: One is the precision machined part must be Completely nonmagnetic, secondly, it must be wear-resisting. After understanding the customer's quality requirements, Kanou Precision’s sales and technical engineer have the meeting to discuss this project immediately.
After much thought, we thought of replacing the material as tungsten copper. The tungsten copper can meet all character that tin bronze have. Even though the cost is higher than tin bronze, but tungsten copper can reach more high precision on processing, and the machining cost is much lower. the hardness and toughness of tungsten copper are better than tin bronze, and the wear-resisting is also better.
so it will be a good proposal to change the material as tungsten copper. then we put this proposal to the customer immediately , and also make new quotation to him to compare. It saved 600RMB/piece compared with the first quotation. Customer full of praise for us after checking this suggestion, as this proposal not only solved all requirements and have better quality, it also reduced much cost for them.
Kanou Precision not only provide precision machining service, but also provide a better solution. No matter you have precision machining request, or machining solution request, we can meet all of your requirements. If you have any question or inquiry, please feel free to contact us. We will do our best to serve you.
