Polishing technology is widely used in precision machining field, It’s very important processing that no matter for precision machined parts or Mold Parts. With the wide application of hardware products, the appearance quality requirements for hardware is becoming more and more higher, then the requirements for surface polishing will also be higher, and the roughness requirements for mirrored and highlighted surface products is especially higher, so the requirements for polishing also becoming higher and higher. Polising Not only increases the beauty of the precision machined parts, but also can improve the Corrosion and wear resistance of the material surface for precision machining parts, it also Convenient to Injection molding processing such as making plastic products easy to demold, reduce the production of injection cycle etc.
A:Rough polishing and grinding: The surface was normally rough after processing of Lathe, Grinding, CNC, cutting or EDM, It need be polished by using oilstone, Use kerosene as the lubricant,the General order of use will be #180 ~ #240 ~ #320 ~ #400 ~ #600 ~ #800~ #1000.
Whetstone polishing is very important and difficult processing, According to the different specifications of processed products like automotive parts, Cross lapping was performed equably at an Angle of about 70 degrees, The optimal round trip range is about 40 ~ 70 mm. Whetstore processing will also be changed according to the material for machined parts, In order to save the time, they will choose #400 to start.
B: Normal Polishing mainly use sandpaper and kerosene.After Whetstone processing will be sanding paper, When sanding paper, pay attention to the round edges, sharp corners, round corners and orange peel appears. so the process of whestone should be done with high precision. The important point for Sanding paper: Sand paper is intersected with hard sticks for grinding like Whetstone processing , and the grinding frequency of one side of sand paper is about 10 ~ 15 times. If the grinding time is too long, the abrasive force of sand paper will be reduced, and then it will lead the surface finish be uneven( This is one of the reason for orange peel appears). sanding paper usually use bamboo piece to grind, Actually the optimal ways is use the wood bar with less elastic or aluminum bar with Low hardness to grind at a 45 degree angle. The grinding surface should not be rubber or highly elastic materials, it can be grind at Acute Angle if the shape can’t grind at 45 degree angle. The Numbers of sandpaper are #220~ #320~ #400 ~#600~ #800 ~#1000~#1200~#1500. In fact #1500 sandpaper is only suitable for hardened die steel (above 52HRC) and not for prehardened steel as this may cause surface burns to the prehardened steel.
C:Precision polishing mainly use diamond paste. If use polishing wheel that mixes diamond abrasive powder or paste to grinding, The paste and polishing wheel can remove the Grinding crack that remained by #1200 and # 1500 sand paper. and then polishing by using felt and diamond paste.It can use the clean polishing chamber in mold processing workshop directly if the polishing precision is Ra0.2, If the polishing precision is very high, then it must use an absolutely clean space to process. It will scrap the polishing surface in high precision if the space has Dust, smoke, dandruff and spittle.
Our Kanou Precision use these polishing technology to service the customer, and also provide kind of solution for customer’s project. We always provide the precision machining part, cnc machined part, CNC turned part, CNC millded part, Mechanical components, automotive spare part to customer, Especially for mass production auto part, these all need this polishing technology, and we received highly praise from customer. We will keep to learn more polishing skills, and bring more advanced polishing tool and meterial to provide more high precision spare parts to customer.
Do you want to know more knowledge about technical skills? pls check this link for more: www.kanouprecision.com/blog/
      As we enter a new year, many of us are still busy reviewing what we’ve done during the previous 12 months. From closing the books on 2024, to analyzing profitability and leveraging missed opportunities to increase those profits in the coming months, this is a busy time of year behind the scenes of any automotive business. Looking back is certainly important for gaining perspective on where we’ve been, but the upcoming year has the potential to bring a wide array of changes for consumers and business owners alike.
      Consumer buying trends are expected to continue shifting toward even more online purchasing as we navigate through 2025 and beyond. In the automotive aftermarket, we’ve already embraced the concept of providing an online shopping experience for our customers, but that experience is changing as consumers adopt new habits and more providers enter the marketplace. The increasing use of mobile devices (and the increasing variety of these devices) will continue to change the methods we use to connect with consumers. Not only are buyers using mobile devices for roughly 65% of their automotive e-commerce inquiries, they are accessing an increasing amount of entertainment and information content. The number of eyes on the traditional advertising mediums of broadcast television, local radio and print media have steadily declined, with more people turning to subscription services like streaming platforms and satellite radio. With fewer advertising opportunities, finding new ways to engage our customers on their preferred devices becomes ever more important in the digital marketplace.
      Software also is increasingly important to the vehicle itself. Connected cars have become part of a virtual network in recent years, commonly known as the “internet of things.” With onboard hardware and software capable of sending and receiving data, and the ability to interface with other connected devices, the automobile has officially joined the ranks of “mobile devices.” More than 70% of new vehicles are “connected,” with tech companies like Microsoft, Apple and Google often partnering with the OEMs to offer in-car infotainment, communications and vehicle health/maintenance data through a wireless 5G network infrastructure. For better or worse, this also has led to the ability of OEMs to offer “subscription” services for many features found in their SDVs (software defined vehicles). A monthly charge for access to your heated seats or remote start might rub some vehicle buyers the wrong way, but the acceptance rate for on-demand features like these is increasing as more people begin to view their vehicle in the same way they have come to utilize their other connected devices.
      The bi-directional transfer and analysis of vehicle data is one key to utilizing the AI technologies behind ADAS and autonomous vehicle capabilities. SAE International recognizes six varying levels of “self-driving” vehicle automation, from emergency braking and blind spot warning (Level 0) all the way to fully-autonomous control under all driving conditions (Level 5). AI has a critical role in these vehicles “learning” their environment and then responding to changes in their surroundings, all in real time. For these systems to work efficiently (and safely), data from cameras, RADAR and LIDAR sensors must be collected and transmitted, analyzed and used by the AI program to make “educated” decisions to mimic a human operator. Like EVs, autonomous vehicles require a level of networked infrastructure that still does not exist on the scale necessary for mass adoption.
      Data, in its many forms, is the cornerstone to improved technology. No matter if it takes the form of daily reports we generate to track sales, inventory and other KPIs, or a series of over-the-air communications that help keep a connected vehicle in its lane, the network of information that surrounds us is critical to our success in 2025 and beyond.
      Advance Auto Parts, Inc. announced it has appointed Shweta Bhatia as executive vice president and chief technology officer, effective immediately. According to the company, Bhatia brings more than 20 years of retail, technology and operational experience to
      link hidden, please login to view. Most recently, she served as senior vice president of technology at Dollar General, where she led a multi-year, end-to-end technology transformation and modernization to enhance the company’s operational efficiency. “Shweta’s history of successfully executing transformational programs that focus on speed, efficiency and providing quality solutions to customers will greatly contribute to the execution of our three-year financial plan,” said Shane O’Kelly, president and chief executive officer. “We welcome Shweta to our leadership team that is passionate about carrying out our decisive actions which will set up Advance for future growth and value creation.”
      Bhatia also served as vice president of technology at both Walmart International, where she led the company’s core retail technology portfolio, and Kohl’s Corporation, where she managed the strategy and implementation of solutions across multiple channels.
      link hidden, please login to view said her passion for modern technology transformation began as an entrepreneur, creating the tech startup, Wisdom Info Tech, an award-winning technology firm. Bhatia received her MBA from Amity Business School and a bachelor’s degree at IT College, both located in India.
      Sri Donthi, Advance’s current chief technology officer, will remain with the company for a period to assist in the transition. The company said it is grateful to Sri for his leadership and contributions over the last several years and wishes him well as he moves on to a new opportunity.
      RALEIGH, N.C.--(BUSINESS WIRE)-- Advance Auto Parts, Inc. (NYSE: AAP), a leading automotive aftermarket parts provider in North America that serves both professional installers and do-it-yourself customers, today announced that it has appointed Shweta Bhatia as executive vice president and chief technology officer, effective immediately.
      “Shweta’s history of successfully executing transformational programs that focus on speed, efficiency, and providing quality solutions to customers will greatly contribute to the execution of our three-year financial plan,” Shane O’Kelly, president and chief executive officer. “We welcome Shweta to our leadership team that is passionate about carrying out our decisive actions which will set up Advance for future growth and value creation.”
      Ms. Bhatia brings more than 20 years of retail, technology, and operational experience to Advance. Most recently, Ms. Bhatia served as senior vice president of technology at Dollar General where she led a multi-year, end-to-end technology transformation and modernization to enhance the company’s operational efficiency. Ms. Bhatia also served as the vice president of technology at both Walmart International, where she led the company’s core retail technology portfolio, and Kohl’s Corporation, where she managed the strategy and implementation of solutions across multiple channels. Her passion for modern technology transformation began as an entrepreneur, creating the tech startup, Wisdom Info Tech, an award-winning technology firm.
      Ms. Bhatia received her MBA at the Amity Business School and a bachelor's degree at IT College, both located in India.
      link hidden, please login to view is excited to introduce Technology Auto Parts, a new startup based in Plano, TX, as the newest TruStar member. Mohamad-Hadi Saeed, the owner and CEO, shared his enthusiasm for joining TruStar, stating, “After researching the organization and speaking with various APA shareholders like Edward Harake from Value Plus Auto Parts, it became apparent that joining will really help us and give us a good head start. I’ve got a lot of great, knowledgeable people helping me get started and 20 to 30 commercial customers on day one. TruStar will be the last piece of the puzzle.”
      The official opening of Technology Auto Parts is scheduled for early October.
      link hidden, please login to view, president of APA, expressed his satisfaction with Mohamad and Technology Auto Parts joining TruStar, saying, “We are delighted to welcome Mohamad and Technology Auto Parts to TruStar. We enjoy collaborating with startups and new ventures. It’s inspiring to witness someone like Mohamad, who previously handled accounting at another auto parts store, venture out on his own. We are eager to support his growth.” The post
      Westar Distribution LLC, a leading aftermarket supplier of engine & transmission mounts and air suspension components announces the release of 40 new Air Suspension Components, Engine & Transmission Mounts, Torque Strut Mounts, and Center Support Bushings servicing in excess of 35,000,000 vehicles in operation today in the US & Canada covering Acura, BMW, Dodge Truck, Ford Sport Utility, GMC Trucks, Honda, Hyundai, Jeep, Lexus, and Toyota vehicles. These newly released items are all in stock and ready for immediate shipment.
      link hidden, please login to view For more information contact sales@westarparts.com or visit
