Reliable replacements and upgrades for active, semi-active and adaptive suspension systems
OTC said each suspension bushing kit features Hendrickson rear suspensions, including Primaax EX, Comfort Air and FCCC V-Ride Pivot and D-Pin suspension bushings, and freightliner rear suspensions, including double and single-wrapped FAS II Airliner rear suspension bushings. Both also include centering adapters to align tool and bushing for clean installation. Both are available through OTC distribution partners and resellers.
Electronic Shocks/Struts
Measuring Wheel Movement
Measuring Body Movement
Westar Distribution LLC, a leading aftermarket supplier of engine & transmission mounts and air suspension components announces the release of 40 new Air Suspension Components, Engine & Transmission Mounts, Torque Strut Mounts, and Center Support Bushings servicing in excess of 35,000,000 vehicles in operation today in the US & Canada covering Acura, BMW, Dodge Truck, Ford Sport Utility, GMC Trucks, Honda, Hyundai, Jeep, Lexus, and Toyota vehicles. These newly released items are all in stock and ready for immediate shipment.
link hidden, please login to view For more information contact [email protected] or visit
