Hey there!
My name is Nelson and I'm looking for a new Knock Sensor for my Mazda MX-5 2004 NB Model.
There are two Knock Sensors available, one is from PremierAutoTrades and one is from Tridon.
The Tridon model is a TKS110 and the PAT model is KNS-078.
I've been looking everywhere online for differences and found nothing!
The reason I need to know so badly is because the Tridon is $509 and the PAT is $148.
What I'm looking to find out is if there is a better one or if they are pretty much the same.
Aany comments on lifetime or quality / response would be helpful!
Thank you, very much.
All yours mate.
    • By Cody Hart
      Hey gang looking for this part. It attaches to my Honda Odyssey gas cap sensor. Went to local auto parts stores to see if they carry it. I just need to know what it’s called so I can find it online. Any and all help is appreciated .
      How To: Use An Oxygen Sensor Socket Set
      Engine Knock | ASE Test Practice Question 9
    • By celvampire
      I found what looks to be an unused O2 sensor found in a thrift store, there are no marking anywhere on the part. Can anyone tell just by looking at it, what car/truck it might fit? Thank you.
