Oil changes continue to be one of the most common DIY repairs performed on vehicles today. According to a recent Counterman P.A.R.T.S. report, changing the engine oil was the second-most popular DIY auto care job, behind only changing the wiper blades.
Changing the oil and filter is right in the sweet spot for do-it-yourself (DIY) vehicle owners: It’s a regular maintenance task that’s critical to the overall health and longevity of the engine, and it’s easy to perform. It’s the sort of basic maintenance that can be performed by someone who might not get their hands dirty otherwise. Chances are you’ve had a DIYer in your store asking how to get started. Let’s talk about some of the tips you can share with your DIY customers to help them change their own oil – and do it right.
Essential Tools vs. Non-Essential Tools
Tools are a long-term investment. They may cost more than they’ll save on the first oil change, but they pay for themselves in the long run!
Let’s start with the essential tools that every DIYer should have in their garage. At the top of this list, we find a jack and jack stands. Whenever you’re working underneath a vehicle, you need to make sure that it’s lifted up on level ground, and that it’s safely supported with jack stands. If you lift the vehicle up with a hydraulic jack, and don’t support it with jack stands, the jack can lose pressure and the vehicle will start to lower itself. If you’re underneath the vehicle when this happens, it can be deadly. Be safe, be smart and live to wrench another day. If any of the wheels are coming off, I place them underneath the vehicle for an added layer of protection. My thinking is simple: If something went wrong, having to replace a wheel and/or tire could be the least of my problems!
As a personal rule, I like to use jack stands that are rated for far more weight than I’ll ever put onto them. I have a number of 4-ton and 6-ton jack stands, and I prefer them over the less expensive 2-ton stands due to their increased footprint, and more robust construction.
Figure 1
Next on the list are the basic tools and supplies you’ll need to finish the job. You’ll need a basic set of sockets, wrenches and ratchets. You’ll also need some form of tool to remove the oil filter or filter housing cap (Figure 1). It’s worth mentioning that you may need to purchase specialty tools to remove the drain plug or filter housing on certain applications. For example, Volkswagen uses a proprietary tool to remove the plastic drain plugs from its modern four-cylinder engines. GM Ecotec engines require a special socket to remove the filter housing cap on its 1.4T and 1.8-liter four-cylinder engines. These are only two examples of many, so it’s best to do some online research before starting the job. Make sure you have all the tools you need on hand BEFORE you start to drain the oil.
You’ll need some form of drain pan or container to catch the oil as it drains out of the engine. It’s a good idea to have some old rags or towels on hand to clean up any spills or messes along the way, and I usually have a can of brake cleaner for added cleaning “umph.”
Finally, let’s talk about personal protective equipment (PPE). It’s a good idea to wear safety glasses to protect your eyes, and gloves to protect your skin.
Tips & Tricks
First and foremost, a DIY customer probably will have a lot of questions about what type of oil they need, how much oil their engine holds and more. While you may be able to lookup fluid specifications and capacities in your catalog, your DIY customers won’t have access to something like that. But a quick Google search should get them on the right track. I would always advise them to follow the OE maintenance guide and specifications, regardless of mileage or age.
There are a lot of things that you’ll learn through experience. Any tips, pointers or advice you can share with your DIY customers can go a long way toward helping them, and might just be the thing that gets them back to your store for the next repair. For example, some oil-drain plugs feature a gasket or crush washer that seals up against the oil pan. This type of gasket will need to be replaced at every oil change. A leaky drain plug can be a real pain, and could be really discouraging to a DIYer after their first oil change.
Then there are the little things that just make the whole job go a little bit smoother. I like to keep some old, cut-up cardboard boxes around the garage. In a pinch, they work great as a “poor man’s creeper.” Sometimes you don’t have enough room under the vehicle to slide around on a creeper, so the cardboard gives me something to lay on without having to lay directly on the cold, concrete floor.
When replacing a spin-on oil filters, always wipe off the mounting surface before installing the new filter. This ensures that any dirt or debris will be wiped away, AND if the gasket was stuck in place, you’ll either feel it, or you’ll knock it off of there. If you installed the new oil filter on top of the old gasket, it wouldn’t seal correctly. The result would be a massive blowout, leaving oil all over the garage floor. Not a great way to spend an afternoon!
Figure 2
The same applies to cartridge oil filters, but for different reasons. Cartridge oil filters are held in place by a filter housing cap. This cap will contain one or more O-rings that seal inside the housing. These O-rings need to be replaced with every oil change, and they’re almost always included with the new cartridge oil filter. Whatever you do, don’t double up these O-rings! This can lead to massive oil leaks, but it also can make the filter housing cap nearly impossible to remove (Figure 2).
Finally, always dispose of the used oil safely. If your store will take used oil, be sure to let your customers know. If your store cannot take in used oil, make a list of nearby shops that will. Some shops use oil-burning heaters, so they may take used oil without a charge to the customer.
      A Dynamic Kickoff
      Lucas Oil has announced the latest addition to its vehicle performance product lineup: Lucas Emissions Clear. The company said this fuel and exhaust system cleaner addresses the need for effective solutions to reduce vehicle emissions and improve catalytic converter performance, helping vehicle owners meet strict emissions regulations.
      In a news release announcing the product, the company explained that Lucas Emissions Clear Fuel and Exhaust System Cleaner targets the entire fuel delivery system, removing harmful deposits that contribute to excessive exhaust emissions. By reducing particulate matter before it reaches the catalytic converter, the product helps extend its lifespan, optimizes combustion and improves emissions catalyst effectiveness. Formulated for easy integration into routine vehicle maintenance or pre-emissions testing, Lucas Emissions Clear is a one-tank treatment that provides emissions control, promotes cleaner air quality and is compatible with any gasoline engine, the company said.
      “A cleaner engine means a more efficient, more reliable car, and Lucas Emissions Clear delivers exactly that for drivers,” said
      link hidden, please login to view CEO Morgan Lucas. “We take pride in helping our customers save money on repairs and maintenance. Cleaner emissions not only contribute to a healthier environment, but also extend the lifespan of exhaust systems, providing long-term financial benefits for drivers and helping to meet more stringent regulations. With this product, we are making it easier and more affordable to maintain optimal performance and compliance with emissions standards.” Designed for environmentally conscious vehicle owners, fleet managers, automotive enthusiasts and drivers seeking improved fuel efficiency and performance, Lucas Oil said its Emissions Clear can cut harmful pollutants by up to 90% while delivering up to 5% improvement in fuel economy.
      link hidden, please login to view, sustainable manufacturer serving the automotive and industrial markets in North America and Europe, announced its rebrand to link hidden, please login to view, which it said reflects the company’s continued focus on innovation and its mission to spread the power of sustainable manufacturing at scale. The rebrand will roll out globally over the coming months, beginning with updated brand assets and a suite of resources designed to empower employees to embrace the new identity, the company said. As part of this transformation, a newly redesigned website will be unveiled in the coming week.
      A news release announcing the rebranding explained that sustainable manufacturing lies at the core of TERREPOWER’s approach. Through advanced remanufacturing, reengineering and material recovery processes, the company said it minimizes waste, reduces reliance on raw materials, and enhances resource efficiency. This approach not only supports environmental responsibility but also provides cost-effective, high-quality solutions that help our customers operate more efficiently, TERREPOWER added.
      “This is an exciting milestone for us,” said Duncan Gillis,
      link hidden, please login to view CEO. “TERREPOWER is not just a new name, but a new chapter in our journey. It reflects our ongoing commitment to innovation and collaboration to deliver solutions that meet our customers’ evolving needs. This rebrand unites our teams under a shared identity and positions us well for future success.” TERREPOWER explained the name reflects the company’s continued commitment to innovation and its role in supporting a more efficient and resource-conscious future. Derived from the French word for “earth,” “Terre” signifies a dedication to preserving valuable resources, while “Power” reflects the company’s strength and drive to develop smarter, more efficient manufacturing solutions. Bringing those together, TERREPOWER represents the company’s focus on creating long-term value for customers by extending product life, optimizing material use and driving sustainable growth.
