The wheel bearings are the backbone of the vehicle suspension. They support the weight of the vehicle, help to keep the wheels in alignment and allow the wheels to rotate with as little friction as possible. But wheel bearings can’t do their job without a strong mounting point, and that’s the knuckle.
What Is the Knuckle?
The knuckle, also known as the spindle, is the suspension component that houses the wheel bearing, and the connection between the wheel and the suspension system. In the past, knuckles typically were made of steel, but today they’re more commonly made of aluminum or another lightweight alloy to save weight.
On the front of the vehicle, the knuckle will pivot on upper and lower pivot points as the driver turns the steering wheel, changing the direction the vehicle is traveling in. In the rear suspension, the knuckle won’t pivot, but instead will travel up and down. Any time you’re removing or replacing a wheel bearing, ball joint, tie-rod end or control arm, you’ll be working on a knuckle.
Since the wheel bearings and the knuckles work together, sometimes it will make more sense to replace them together. This type of assembly is referred to as a “loaded knuckle.” Why would a customer decide to install a loaded knuckle? In most cases, it comes down to one of two reasons: damage or time.
What Can Damage a Knuckle?
They can be damaged during a crash or a collision, or from violently striking a curb or a deep pothole. This type of damage can change the geometry of the suspension, causing a crooked steering wheel, wandering steering feel while travelling straight, or steering bind. If left alone long enough, it even can result in abnormal tire wear down the road.
A knuckle also can be damaged due to a failed CV axle or wheel bearing. In this case, I’m talking about a scenario in which a driver ignores the grinding, metal-on-metal noises from a failing wheel bearing, and continues to drive for a long, long time. I’ve seen this exact scenario in the shop before, and it usually isn’t pretty. Eventually, the wheel-bearing bore becomes deformed thanks to the added stress, and the entire knuckle is only good for scrap.
There’s one more thing that could damage a knuckle: overtightening a ball joint or tie-rod end. Ball joints and tie-rod ends usually feature a tapered seat, which becomes tighter as the fastener is tightened. In older knuckles that were made of steel, that tapered bore would hold up pretty well, even if the fastener was a bit overtightened. But the modern aluminum or alloy knuckles are much softer, and they’re susceptible to damage from over-tightening. If the joint is tightened down but it’s still loose inside the tapered bore, the bore is damaged and the entire knuckle will need to be replaced.
What About Time?
So, we know why a customer might replace a damaged knuckle, but what does time have to do with it? That’s easy: Time is money. This applies to both DIY and DIFM customers. DIY customers are trying to get their vehicle fixed and back on the road as quickly as possible, especially if it’s their one and only vehicle. DIFM customers are trying to maximize their efficiency, and keep the shop running smoothly. In either case, if the customer runs into trouble, the results can be costly.
This is especially prevalent with press-in wheel bearings. This type of bearing is quite labor-intensive to remove and replace. After years of exposure to road debris, grit and salt, they can become stuck in place inside the knuckle. In extreme cases, it could take more time and labor to remove and replace a press-in bearing versus simply replacing the whole thing with a loaded knuckle.
On vehicles with aluminum knuckles, you may find that corrosion will form around a pinch bolt, axle nut or snap ring. This corrosion can make it extremely difficult, if not impossible, to remove that fastener. At some point, it makes more sense from a time and money standpoint to simply replace the entire knuckle, rather than get bogged down trying to remove a stubborn fastener.
Advantages of Loaded Knuckles
First and foremost, the nicest thing about a loaded knuckle is that it comes to you pre-pressed, so there’s no need to press out the old bearing, clean everything up and press in the new bearing. There’s no second-guessing if you set the bearing or the hub to the correct depth, or if you inadvertently damaged something by applying too much force with the shop press. That is a huge advantage to the DIY customer who might not have the necessary tools for this type of repair. It’s also helpful to the DIFM customer as it allows them to manage their time much more efficiently.
Customers might think that they can save a little bit of money by only replacing a wheel bearing and reusing the steering knuckle. But those savings can go right out the window if they run into unforeseen troubles during the repair. If they end up damaging other components, or they spend more time than expected simply trying to remove the old bearing, it can spell disaster. DIY customers can end up being without their vehicle for longer than anticipated, and DIFM customers can lose out on other business if the vehicle is stuck on a lift for longer than anticipated.
Replacing the entire knuckle and bearing assembly at the same time reduces the likelihood of a customer comeback, and increases the chances of the repair being completed correctly the first time. Installing a loaded knuckle can reduce installation time by up to 75% depending on the application. Just like a loaded strut, a loaded knuckle can help to take the hassle and guesswork out of a potentially troublesome repair.
    • By Garage Gurus
      Garage Gurus | 2014 Kia Soul Steering Angle Sensor Calibration
      If you’ve ever looked into car engine management systems, you’ve probably come across the terms ECM (Engine Control Module) and ECU (Engine Control Unit). While these terms are often used interchangeably, they are not exactly the same. Understanding the difference between ECM and ECU can help you diagnose vehicle issues, make informed repair decisions, and ensure your car runs efficiently.
      At Clifford Auto Parts, we specialize in high-quality ECMs and ECUs, providing affordable replacements with free shipping across the USA. In this blog, we’ll break down the key differences between ECMs and ECUs, their roles in vehicle performance, and how to know when it’s time to replace them.
      ✅ What is an ECU (Engine Control Unit)?
      The Engine Control Unit (ECU) is a broad term referring to any electronic module that controls various aspects of a vehicle's operation. Modern cars often have multiple ECUs that manage different systems in the vehicle, such as:
      ✔️ Engine Management (ECM) – Controls fuel injection, ignition timing, and emissions.
      ✔️ Transmission Control (TCM) – Regulates automatic gear shifting.
      ✔️ Brake Control (ABS Module) – Manages anti-lock braking systems.
      ✔️ Body Control (BCM) – Controls lighting, windows, and climate systems.
      The ECU acts like the brain of the car, receiving signals from sensors and making real-time adjustments to optimize performance, efficiency, and safety.
      ✅ What is an ECM (Engine Control Module)?
      The Engine Control Module (ECM) is a specific type of ECU dedicated to managing the engine’s performance. It ensures the correct amount of fuel, air, and spark is delivered to keep the engine running smoothly.
      A faulty ECM can cause serious performance issues, including:
      ✔️ Check Engine Light Staying On
      ✔️ Engine Stalling or Misfiring
      ✔️ Poor Fuel Efficiency
      ✔️ Starting Problems
      At Clifford Auto Parts, we offer tested and warrantied ECM replacements for Ford, Dodge, Jeep, Chrysler, and more, ensuring a plug-and-play experience for vehicle owners across the USA.
      ✅ How Do ECM and ECU Work Together?
      While the ECM specifically controls the engine, it still communicates with other ECUs in the car. For example:
      ✔️ The ECM and TCM (Transmission Control Module) work together to ensure smooth gear shifting.
      ✔️ The ECM and BCM (Body Control Module) coordinate engine start functions with security and lighting systems.
      ✔️ The ECM interacts with the ABS Module to adjust power delivery during emergency braking situations.
      Modern cars rely on these interconnected systems to provide seamless driving performance.
      ✅ When Should You Replace Your ECM or ECU?
      If your vehicle is experiencing engine trouble, transmission issues, or persistent warning lights, you may need to replace the ECM or a specific ECU. Some warning signs include:
      ✔️ Check Engine Light stays on, even after repairs
      ✔️ Sudden drops in fuel efficiency
      ✔️ Rough idling, stalling, or misfires
      ✔️ Transmission shifts erratically or gets stuck in a gear
      ✔️ Car fails to start despite a working battery
      Ignoring these symptoms can lead to costly repairs. The best way to diagnose the problem is to use an OBD-II scanner to check for ECU or ECM-related fault codes.
      ✅ Why Choose Clifford Auto Parts for ECM & ECU Replacements?
      At Clifford Auto Parts, we specialize in providing high-quality, reliable ECM and ECU replacements that fit seamlessly into your vehicle. Here’s why thousands of vehicle owners trust us:
      ✔️ Wide Selection: We offer ECMs & ECUs for Ford, Jeep, Dodge, Chrysler, and more.
      ✔️ Lifetime Warranty: All our ECMs come with a lifetime guarantee for peace of mind.
      ✔️ Fast & Free Shipping: Get your replacement within 3 business days, anywhere in the USA.
      ✔️ Affordable Pricing: Save hundreds of dollars compared to dealership prices.
      ✔️ Plug-and-Play Compatibility: Our ECMs are programmed and ready to install.
      Don't let a failing ECM or ECU slow you down! Shop today at link hidden, please login to view for top-quality replacements.
      ✅ Final Thoughts
      Understanding the difference between ECM and ECU helps car owners diagnose vehicle problems, make informed repair decisions, and ensure long-term performance. While ECUs control multiple car functions, ECMs specifically manage the engine’s performance.
      If you're facing engine issues, poor fuel efficiency, or transmission troubles, it may be time to replace your ECM or another ECU module. At Clifford Auto Parts, we provide tested, warrantied, and affordable ECMs and ECUs to keep your vehicle running like new.
      🚗 Need an ECM replacement? Visit link hidden, please login to view today!
      📞 Questions? Call (516) 494-7838 for expert assistance.
      When it comes to modern vehicles, the performance and reliability we expect are largely due to the integration of sophisticated electronics and systems. One such essential component is the OEM (Original Equipment Manufacturer) Control Module. These modules play a critical role in the functionality of a vehicle, ensuring that everything from engine performance to safety features is operating at its best. But what exactly are OEM control modules, and why are they so important?
      What Are OEM Control Modules?
      OEM control modules are electronic units that control and monitor various functions within a vehicle. These modules are designed and produced by the vehicle’s original manufacturer, which ensures that they meet the highest standards for performance, durability, and compatibility. These modules are responsible for managing crucial systems in a vehicle, such as the engine control system (ECM), transmission control, and braking systems.
      Unlike aftermarket parts, which are produced by third-party manufacturers, OEM control modules are specifically designed to match the vehicle’s make, model, and year. As a result, they offer a precise fit and functionality, ensuring the highest level of performance and reliability.
      Why Are OEM Control Modules Important?
      Enhanced Vehicle Performance: OEM control modules are engineered to interact seamlessly with the other systems in a vehicle. When these modules are working properly, they ensure that the vehicle runs at optimal efficiency, offering better fuel economy, smoother driving, and reduced emissions.
      Guaranteed Compatibility: Since OEM control modules are made by the vehicle’s original manufacturer, they are guaranteed to be fully compatible with the vehicle’s systems. This eliminates concerns about compatibility issues that might arise with aftermarket parts, making the replacement or upgrade process much simpler and less risky.
      Durability and Reliability: OEM control modules are built to last. They are designed using the same high-quality materials and manufacturing processes used for the original vehicle components, ensuring they offer long-lasting performance. When you choose an OEM module, you're investing in quality that won't let you down.
      Warranty and Support: Many OEM control modules come with a warranty, providing peace of mind that any defects or issues will be covered. Additionally, support from the vehicle’s manufacturer ensures that if there is an issue with the part, you have access to reliable customer service and troubleshooting.
      Improved Safety: OEM control modules are directly connected to critical safety features in your vehicle, such as airbags, antilock braking systems (ABS), and traction control. Ensuring these modules are in top working order is essential to maintaining the safety of the vehicle.
      The Role of OEM Control Modules in Modern Vehicles
      Modern vehicles rely on multiple control modules to ensure that everything from the engine to the infotainment system is functioning correctly. Some of the most common OEM control modules include:
      Engine Control Module (ECM): This module manages engine functions such as fuel injection, ignition timing, and emissions control, ensuring that the engine operates efficiently. Transmission Control Module (TCM): The TCM controls the vehicle’s transmission system, adjusting shifting patterns for smoother performance. Body Control Module (BCM): This module is responsible for non-powertrain functions, such as lighting, door locks, and interior comfort features. ABS Control Module: This module manages the anti-lock braking system, preventing wheel lockup during heavy braking and improving vehicle stability. These are just a few examples, but in today’s vehicles, the integration of electronics in the form of OEM control modules is essential for ensuring everything functions smoothly.
      Choosing the Right OEM Control Module
      When it comes to replacing or upgrading an OEM control module, it's essential to choose one that fits your specific vehicle model and requirements. Working with trusted auto parts suppliers, like Clifford Auto Parts, ensures that you get a quality OEM control module at a competitive price. It’s always a good idea to check with an expert to ensure you're selecting the right part to suit your vehicle’s needs.
      OEM control modules are integral components of modern vehicles, offering superior performance, reliability, and compatibility. Whether you're replacing a faulty module or upgrading your vehicle, choosing OEM parts is the best way to ensure your car or truck continues to run at its best. With their long-lasting durability and guaranteed fit, OEM control modules are a wise investment in the future of your vehicle. Always choose quality and reliability by opting for OEM when upgrading or replacing essential control modules.
      By understanding the importance of OEM control modules, vehicle owners can make informed decisions that ensure their vehicle performs optimally for years to come.
      The easy fix for Ram trucks with electronic power steering problems | Dorman 601-903
      Destructive testing: OE power steering coolers vs. Dorman OE FIX
