The very first automobiles needed a way to transmit power to the wheels. Early methods of accomplishing this were comprised of exposed belts and pulleys, effectively creating a single-speed transmission. There were many different variations, but to get both acceleration and speed, more than one gear was needed. It wasn’t long before multiple-gear setups were invented.
The next step was enclosing multiple gears in a sealed case, which effectively became the first true manual transmission in the context we think of them today. These first units were non-synchronized, meaning when you shifted gears, you had to match the speed of the input, or driven gear, to the speed of the output gear. Since the speed of the input gear was directly related to the speed of the engine, you did this by adjusting the throttle to attain the matching speed and shifting the gears at just the right moment. Shifting was no picnic, and often a noisy and difficult process.
The affect that different-sized gears have on acceleration and speed is easy to understand (think different-size sprockets on a bicycle), making this type of manual transmission a natural first step of evolution. Surprisingly, one of the lowest rungs on the evolutionary ladder is the planetary gearset, which is normally associated with an automatic transmission (a much later invention) instead of a manual.
I think it’s always fun to look at planetary gearsets, and in this case, it also makes evolution a much more interesting topic, since they play such an integral part.
The planetary gearset was somewhat of an engineering marvel. It’s a set of gears (see Figure 1) whose name only makes sense when you see what they look like. The fascinating part about a planetary gearset is its ability to provide different gear ratios as well as reversing direction based upon the specific components that are held or driven. Note that the planet gears are mounted and rotate on pins that are affixed to the planet carrier.
Figure 2 shows the action of the gearset in a neutral position. The sun gear is the input for the gearset. As the sun gear rotates, it transfers motion into the planet gears. As the planet gears rotate on their pins, they in turn transfer motion into the ring gear. The input is from the sun gear, but since the ring gear isn’t engaged to anything for this position, there is no output.
Figure 3 shows the action of the gearset in low gear. The ring gear is held stationary, and the sun gear is the input. Power transfers from the sun gear into the planet gears. The planet gears rotate on their pins, but since the ring gear is held, the planet gears are forced to “walk” around the ring gear, which causes the planet carrier to turn. The planet carrier is utilized as the output.
Figure 4 shows the action of the gearset in high gear. The ring gear is the input, and the sun gear is held. The ring gear transfers motion into the planet gears, which rotate on their pins. Since the sun gear is held, the planet gears are forced to “walk” around the sun gear, which causes the planet carrier to turn. The planet carrier is the output, but at a higher speed than in Figure 3.
Figure 5 shows the action of the gearset in reverse. The sun gear is the input, and the planet carrier is held. The planet gears rotate on their pins, and motion is transferred from the sun gear to the planet gears, then to the ring gear. The ring gear is the output.
The key to making a planetary gearset work is the ability to hold and drive different components of it at different times. And in order to expand the capabilities of different gear ratios, multiple gearsets can be used together, referred to as compound planetary gearsets. I think you might see where we’re going, but first let’s get back to evolution.
If Only It Was That Easy
The easiest thing to say would be: The manual transmission was first and the automatic came second. End of article. Well, that’s true … sort of. The earliest “transmissions” were a way of transmitting power from the engine to the wheels. Then came the first non-synchronized multiple-gear manual transmissions. But shifting was a chore, and thanks to the planetary gearset, there was another style of transmission to join the game.
This new transmission utilized the advantages of a planetary gearset for multiple forward speeds, neutral and reverse. And it utilized “brake bands” for holding the various members of the gearset to obtain the desired output. Planetary gearsets and brake bands, again, are almost always immediately associated with automatic transmissions, but this was a manual transmission.
It was shifted through the use of levers and pedals, and proficiency took practice, but gone was the grinding and fighting associated with an unsynchronized gear-type of manual. Though not the first to utilize the design, the first mass-produced automobile to use this type of transmission was, well, the first mass-produced automobile: the Ford Model T.
It was very successful for many years, but certain design aspects such as the band linings being made of cotton or wood weren’t destined for the future. By the time the Model T was ready to step down in 1927, the “traditional” manual transmission with gears lined up along the mainshaft and coupled to an input through a countershaft had become the “standard” type of transmission in almost every automobile.
Most of them were still unsynchronized at this point, but gear and shifter design as well as throttle control had improved considerably, making them much easier to shift, and then came a huge evolutionary leap with the development of the synchromesh manual transmission in the late 1920s. These transmissions utilized a synchronizer between second and third gears (most transmissions of the time had only three speeds) primarily to aid down shifting. With the clutch disengaged, the synchronizer was able to match the speed of the input shaft to that of the output, allowing the driver to easily shift gears with no noise or grinding. To shift into first or reverse, the car had to be stopped.
Unrivaled in performance and durability, the manual transmission remained the standard for the automotive industry for many decades, and the early 1950s brought the development of the first unit with all forward gears fully synchronized. Three-speed manual transmissions were the most common, with four-speeds usually only optioned on performance-oriented cars. In the 1980s, most manual transmissions were either four or five speeds, and eventually production cars saw as high as seven-speed manual transmissions.
Manual transmissions were coupled to the engine through a clutch – a purely mechanical friction device that allowed the driver to slowly engage the engine to the transmission, in order to get the vehicle moving without stalling the engine. Clutch control was achieved primarily through mechanical linkages, but eventually cables offered a more efficient alternative, and finally hydraulically controlled clutches proved to be the smoothest and easiest
to operate.
The Planets Finally Align
Undoubtedly a cosmic event for the motoring public, by the late 1930s, technology was ready for the planetary gearset once again, and they were back for good in the first mass-production automatic transmission: the GM Hydramatic four-speed. Many automatic designs and attempts preceded it, but this design and the use of hydraulic fluid not only proved successful and dependable, but also set the bar for the future of automatic transmissions.
Compound planetary gearsets were controlled by brake bands and clutch packs to control the automatic shifting and gear ratios, and a fluid coupling was the more notable aspect that eliminated the need for a clutch and made driving easier. A fluid coupling utilizes an impeller and turbine housed together in a sealed unit. Fluid is pumped into it and as it spins, the impeller (fixed to the engine) throws the liquid into the blades of the turbine (fixed to the transmission input), causing them to rotate. To visualize this, picture what happens when you spray a direct stream of water onto a fan blade: It rotates.
A fluid coupling provides the ability to transfer the power from the engine into the transmission, yet at low speeds it will slip, allowing the vehicle to be stopped and remain in gear without stalling
the engine.
As the automatic transmission itself evolved, the standard fluid coupling was replaced by the torque converter. The difference and advantage of a torque converter is that it has an additional component installed – the stator – which redirects the flow of the fluid exiting the turbine into the direction that the impeller is already spinning, effectively increasing the torque that’s transferred into the transmission.
Cruising Along
OK, so now the automobile is cruising right along through the decades of the 20th century with manual transmissions being “standard” equipment and automatic transmissions always an additional cost option. All of a sudden, we have emissions and fuel-economy regulations, and we have to start squeezing efficiency out of every inch of an automobile.
Torque converters don’t initially have the ability for a direct coupling, so there’s an efficiency loss in their operation. “Lock-up” converters are developed to physically connect the impeller and turbine above a certain speed, eliminating any loss.
Computers and electronics hone automatic transmission shifting and efficiency into an art form, and now we’ll see as many as eight speeds. The automatic transmission has become so popular, efficient and dependable that manual transmissions have almost completely disappeared from availability on new cars. The automatic transmission is now the new “standard.”
Continuing Evolution
A continuously variable transmission (CVT) is one that operates exactly as the name would indicate and is able to provide changing gear ratios in a smooth, continuous operation. Gaining popularity in the auto industry in the 1990s, CVTs actually have been around longer than the automobile in multiple different industries, and used by many early automakers as well. But they didn’t see popular widespread use in this industry until the 1990s.
There are multiple different designs, from pulleys and belts/chains to discs and rollers. The basic idea of operation is the relationship of conical-shaped pulleys and the point at which they drive or are driven.
CVTs have the advantage of smooth operation, and their ability to constantly adjust gear ratios allows them to keep engine rpm lower during operation, which adds to fuel economy. They are traditionally less expensive to manufacture because they have fewer components than an automatic transmission.
The Automatic Manual
Direct-shift gearboxes (DSG) also are referred to as dual-clutch transmissions (DCT) and often mistakenly called automatic transmissions by vehicle owners and salespeople alike. A DSG internally is a manual transmission with gears and synchronizers that we’ve been familiar with for years. The difference, however, is that they have two clutches and two input shafts – one set for odd-numbered gears, one for even-numbered gears.
Clutch and internal gear changing is generally controlled by servos (there’s no clutch pedal or traditional linkage-style of shifter), which in turn are commanded to operate through the logic of an electronic control unit that responds to inputs from a slew of sensors and switches. When driving in one gear, the transmission already has shifted into the next gear, but the clutch for that corresponding mainshaft is disengaged. At the point when shifting occurs, that clutch engages as the other simultaneously disengages, and the process continues in this manner.
The advantage of this type of transmission is that it can shift much quicker than any other transmission, and they provide better fuel economy by eliminating any slippage or lag time associated with an automatic. They also are extremely popular for performance and racing due to their quick, precise shifting, which means quicker acceleration and no driver error. Shifting can be controlled by a driver in manual mode, or the vehicle can simply be placed in automatic mode.
When these transmissions first came out, they were frequently misrepresented as automatic transmissions, because with no clutch pedal and a shifter that looked like a traditional automatic shifter, it was easy not to know the difference. There are some characteristics such as the feel of a downshift that tell you it’s a manual transmission, and as a technician, I spent a lot of time explaining that nothing was wrong with somebody’s “automatic” transmission, and it felt the way it did because it wasn’t really an automatic.
Oddballs
Over the years, there have been a few oddball transmission concepts in the evolutionary chain. For example, a lesser-known model was Volkswagen’s AutoStick, which was available from 1969 to 1976. It was a manual transmission with a vacuum-operated clutch servo that disengaged the clutch when a hand was placed on the shifter. It also had a torque converter installed, so even with the clutch engaged, the engine would idle in gear.
And here’s another one: From 1984 to 1988, the Chevrolet Corvette featured a 4+3 manual transmission, which was a basic four-speed manual with an overdrive unit on the end. When driving the car in second, third or fourth gears, if you let off the gas, it would automatically engage the overdrive in the interest of saving gas. My own personal thought: It was just weird, and a little annoying.
Nicknames
Over the years, many transmissions have earned nicknames, lovingly or otherwise. Manual transmissions were referred to by the number of gears they had. For example, some called a three- or four-speed “three- or four-gear” transmissions. They also were often simply called “standards,” because they were the standard for many years. They’re also commonly called “stick shifts,” and in the early days, often referred to as “crash boxes” due to the noise they made shifting because of the non-synchronized gears. Specific models like the Muncie M-22 with straight-cut gears earned the name “rock crusher” because of the loud noise from the gears. Today, manual transmissions have become so uncommon that fewer people learn to drive them, and they’re often referred to as a “millennial anti-theft device.”
Automatics didn’t get as many names, but the most common was “slushbox,” due to their characteristics of slow shifting, which today’s technology has eliminated. Regardless of the number of speeds, if you had an automatic, you still just had an automatic. I hate to say it, but in many ways, this is only scratching the surface of transmission evolution. Probably the most important factor in all of it is that transmission fluid has evolved right alongside, and it’s more critical than ever to only use the correct fluid that’s specified for each and every transmission, regardless of what it is.
      link hidden, please login to view announces the promotion of Mike Maleski and Brandi Gangel to co-presidents, as well as the addition of Sam Littman as director of finance & operations. These strategic leadership changes underscore the company’s commitment to growth, innovation and operational excellence, while continuing its long-standing tradition of delivering impactful media solutions to the transportation industry. Babcox Media CEO, Bill Babcox, emphasized that Maleski’s and Gangel’s leadership, along with Littman’s financial and operational expertise, will be key to running effective and efficient operations while staying focused on creativity and growth.
      “In today’s complex and ever-changing media landscape, having co-presidents allows us to maximize the unique strengths that both Mike and Brandi bring to the company,” Babcox said. “Their combined expertise in digital product development, data and marketing creates a winning combination for us. Additionally, we’re excited to welcome Sam Littman, whose fresh perspective and strategic consulting experience will support our ongoing evolution as we grow our business.”
      Maleski joined Babcox Media in 2016 after a successful career in media and sports, including leadership roles at The Cleveland Plain Dealer and the Cleveland Cavaliers. With 30 years of experience in sales, digital marketing and media innovation, he has led Babcox Media’s digital transformation, developing ROI-driven strategies for advertisers and sponsors. As co-president, he will continue to build on these successes and lead the company’s sales and business development efforts.
      “I am excited to step into this role alongside Brandi. Together, we’ll deliver forward-thinking media solutions for the markets we serve,” Maleski said. “Our focus on innovation, paired with the incredible talent across the company, positions Babcox Media as a leader in this space.”
      Gangel, who joined Babcox Media in 2014, has been instrumental in the company’s audience data and marketing initiatives. With more than two decades of experience across the hospitality, retail and media industries, Gangel has proven expertise in data acquisition, development and integrated multimedia strategies. As co-president, she will spearhead the company’s audience-driven and customer-success strategies, leveraging data to implement informed and creative solutions.
      “I’m honored to partner with Mike,” Gangel said. “Our industry is at an exciting crossroads, and I look forward to further developing our audience intelligence, content creation and marketing capabilities to drive results for our clients. I’m excited to tap into the strengths of our team and build upon our success.”
      As director of finance & operations, Littman brings experience from Ernst & Young, where he worked as a management consultant. With a strong financial acumen and expertise in business process optimization and operational efficiency, he will play a critical role in supporting Babcox Media’s continued success.
      “I’m thrilled to return to Northeast Ohio and join Babcox Media,” Littman said. “I look forward to working with the team to strengthen our operations and support the company’s ambitious growth plans.”
      Babcox Media remains committed to evolving with the needs of its audience while staying true to its roots as a leading provider of innovative content and data solutions for the transportation industry.
      For more information, visit babcox.com or contact Bill Babcox at 330.670.1234 x217 or [email protected].
      The fuel system, as a whole, is responsible for delivering fuel from the tank to the engine, then metering it into the combustion chamber. It consists of the tank, the lines, the pump and the metering device. If only it was as simple as it sounds. The challenge lies in the continual changes over the last century, and how the frequency of changes has increased over recent decades.
      The heart and identity of any fuel system is the metering device or system that controls the flow of fuel into an engine. As a counter professional, you’re going to hear it all, and you’ll have to answer it all, so here’s a rundown on the major changes and differences over the years.
      Carburetion Systems
      A carburetor is a basic mechanical device, and the primary metering device used on the earliest automobiles. Carburetors held their ground until the late 1980s, when the last examples were eventually replaced by fuel injection. The job of a carburetor is to not only meter the fuel but also to properly mix it with the air flowing into the engine through the process of atomization.
      As the automotive industry began to migrate to fuel injection, a knee-jerk reaction opposing fuel injection ensued. We were familiar with carburetors, and liked the fact that they were mechanical devices that could be repaired and rebuilt using basic hand tools, and there were no electronics involved. Regardless of who made the carburetor or what style it was, an experienced technician could diagnose and repair a problem without the need for service information, scan tools or electronics.
      Though considered “simple,” carburetors are more complicated than they seem, with multiple different circuits to manage all aspects of engine operation. “Tuning” a carburetor – the art of balancing performance, efficiency and drivability – takes a considerable knowledge of engine operating principles, and the patience and precision to get it right.
      The majority of carbureted vehicles utilize mechanical fuel pumps, driven off the engine. This too adds to the attraction of these vehicles, as again there were no electronics involved. The drawback to carburetors came in their lack of ability for precise fuel control. They simply couldn’t keep up with the tightening noose of emission and fuel-economy standards that was in full force by the 1970s. As the end of their use in production automobiles came near, some electronics were incorporated into them, but ultimately proved ineffective.
      Today, any professional will admit – regardless of complexity – that fuel injection is simply superior and necessary. However, carburetion is still popular on old vehicles, partly because of its relative simplicity, but also due to the popularity of restoring old cars to their original state. While far from commonplace, carburetor rebuild kits aren’t going away anytime soon.
      Fuel-Injection Systems
      The advantage of fuel injection is the ability to precisely control fuel delivery under all operating conditions. Not only is this a necessity for emissions and fuel economy, but it also has a major advantage in drivability – an operational attribute that goes hand in hand with efficiency and performance.
      Attempts at fuel injection are as old as the internal combustion engine itself, but in the early days, too many bugs made it undependable. By the 1950s, substantial engineering efforts were applied to develop fuel injection, both in the United States and Europe. One of the more well-known systems was the original Rochester fuel injection developed by Chevrolet for the 1957 Chevrolet and Corvette.
      The idea behind developing this fuel injection wasn’t in the interest of horsepower or emission control. It was drivability, with the goal to eliminate the undesirable and unavoidable attributes of a carburetor, including fuel slosh in the fuel bowl and the transition between primary and secondary circuits. As you may expect, racers played a substantial part in all this, and the best part is they were very successful, and it unlocked horsepower as well!
      The Rochester fuel-injection system was available from 1957 through 1965, but it ultimately failed for only one reason: cost. It was an expensive option, and with the muscle-car wars in full force and much higher-horsepower carbureted engines available for a fraction of the cost, nobody was buying.
      By the late 1970s, fuel injection was better-developed, and this time emissions and fuel economy played a strong part. It began its rise to the top, and thanks to the advancements in electronic and computer technology, it got there quick. By the early 1990s, carburetion was all but gone from production automobiles.
      Fuel-injection systems can be separated into multiple categories and types, and since you’ll hear multiple terms, here’s how to tell them apart.
      Mechanical Fuel Injection
      Early gasoline fuel-injection systems were mechanical. The pumps were mechanical, and fuel was delivered directly to nozzles located in the intake manifold. The pressure of the fuel caused the fuel injectors to open. A type of air meter was necessary, but early systems relied primarily on vacuum signals or mechanical linkage between the air meter and fuel-distribution meter to determine the proper amount of fuel. Very minimal if any electronics were involved in these systems.
      Early diesel fuel-injection systems were purely mechanical as well, but the difference was the required fuel pressure. It doesn’t require much pressure to inject fuel into an intake manifold, but it requires extremely high pressure to inject fuel directly into a cylinder (such as is necessary for a diesel). Diesel-injection pumps housed a mechanical high-pressure pump to feed the fuel to the injectors.
      One of the most common gasoline fuel-injection systems to become popular beginning in the late 1970s was the Bosch Continuous Injection System (CIS). This, too, was overall a mechanical system, but an electric pump supplied the fuel, and minor electronics played a part in cold-start functions as well as fuel-mixture control.
      Electronic Fuel Injection
      Electronic fuel injection was a terminology that became well-known in the 1980s and was often indicated by the letters “EFI” on the back of a car. It seemed revolutionary at the time, and it indicated that the systems were now completely electronically controlled. It was this point in time when fuel pumps found their way into the gas tank; injectors were basically solenoids that opened the injector upon command from a computer; and the computer – along with a myriad of sensors – controlled everything surrounding the operation of the system.
      Even though EFI was an early term that would now be as redundant as saying you have antilock brakes on a new car, it’s technically still an accurate term. It’s just not used often because it’s assumed – and correctly – that everything on a new car is tied to electronics. EFI is a term that can include many different types of fuel injection.
      Throttle-Body Injection
      Throttle-body injection (TBI) refers to the fuel injector(s) being located in a throttle body that looks almost like a carburetor at a glance. This was done by design, as it was the most efficient and quickest way for auto manufacturers to make the change to fuel injection, while utilizing many of the same components they already had such as the same intake manifolds and air cleaners. TBI was most common in the 1980s and early 1990s.
      We’ve always loved fancy names. Have you ever heard of cross-fire injection? It was two throttle bodies at opposite corners of the intake manifold.
      Port Fuel Injection
      TBI was at a disadvantage because airflow was interrupted by the injector, and port injection was the next advancement in line. Port, or multi-point injection injects fuel into the intake runner just before the intake valve for each cylinder. The advantage is the ability to precisely control the fuel delivery and balance the airflow into each cylinder, leading to increased power output and improved fuel economy.
      Early mechanical fuel-injection systems were port-injection systems, sans electronic control. Seem confusing? Many fuel-injection terms cross over from new to old technology. There are just so many manufacturer-specific names that it can be confusing! Like EFI, port injection was widely advertised as the latest greatest advancement, with tuned port injection topping the performance charts. Port injection still is the most common type of fuel injection used today, but when was the last time you saw it called out? Nobody really says it anymore because it’s not new. But there’s another technology that we’re not done talking about, and that’s direct injection.
      Direct Injection
      Direct means the fuel is injected directly into the combustion chamber. Direct injection has been around for years in the diesel world, but it’s still relatively new for gasoline engines. The challenge with this type of injection is injecting the fuel into the high compression of the combustion chamber. Just like a diesel, it requires extremely high fuel pressure, and gasoline direct injection utilizes a typical electric pump to supply fuel to the rail, plus a mechanically driven high-pressure fuel pump to supply the necessary pressure for injection.
      The primary advantage of direct injection is that there’s less time for the air/fuel mixture to heat up since the fuel isn’t injected in the cylinder until immediately before combustion. This reduces the chance of detonation, or the fuel igniting from the heat and pressure in the cylinder. This allows a direct-injected engine to have higher compression, which itself lends to higher performance.
      There are additional advantages of reduced emissions and better fuel economy, but there also are some now-familiar drawbacks, including carbon buildup on the backs of the intake valves, low speed pre-ignition and limited high-rpm performance. For this reason, many manufacturers are combining both direct- and port-injection systems.
      Dana Incorporated now offers genuine Spicer automatic-transmission end yokes specifically designed for replacement on Allison transmission applications.
      “With a high volume of Allison transmissions currently in service with yokes approaching the end of their product lifespan, Dana is ready to meet the demand by offering an OE-quality replacement option for Allison transmission applications,” said Bill Nunnery, senior director, sales and marketing, global aftermarket for Dana.
      The new Spicer commercial-vehicle automatic-transmission end yokes are precision-engineered and manufactured by Dana specifically for Allison transmission applications. The end yokes are designed to help minimize noise and vibration and keep drivelines running smoothly.
      “There is a real need in the marketplace for quality automatic transmission end yokes, and Spicer is the answer,” continued Nunnery.  “Dana customers know that by installing genuine Spicer heavy-duty end yokes, they will be getting OE-quality parts and a cost-efficient solution that boosts uptime and makes repair jobs easier.”
      To help service technicians quickly and easily measure yokes so they can determine the series of the driveshaft needed,
      link hidden, please login to view is available. To obtain a Spicer yoke ruler, co link hidden, please login to view. To learn more about the new Spicer replacement
      link hidden, please login to view for Allison transmissions and other quality Spicer commercial vehicle products, visit link hidden, please login to view.  To check inventory and order directly, visit link hidden, please login to view. The post
