Whenever somebody asks me what’s new, I usually respond by saying, “Nothing really.” And that’s the same response I get when I ask the question of others. Why, I’m not sure, because there’s almost always something new. But in my case, it’s probably because it’s not exciting enough to talk about.
So, when I got the question “what’s new with spark plugs?” I knew my standard answer wouldn’t fly. Then I thought: It’s a fair question. What IS new with spark plugs? They do what they do, right? Is it possible for them to change? Copper, platinum or iridium are the main choices we have, and heat ranges differ between applications. But aside from that, have they changed much at all since they were invented?
The answer to that question is yes, and it makes the whole topic a little more interesting. With all the advancements the internal combustion engine has seen over the years, spark plugs are the components that always have had to bridge the gap (no pun intended) between the old and new, and advancements can be tracked throughout the entire existence of the automobile.
Did you know that early spark plugs could be taken apart for cleaning, and that you could buy replacement porcelain insulators and electrodes to effectively rebuild the spark plug? And that they sealed in the cylinder head by pipe threads and the plug wires were held on by a screw?
Here’s another interesting fact: Have you heard of primer plugs? In the early days of the automobile, fuel systems left a lot to be desired with the use of updraft carburetors, and it was often difficult to start a car on cold days due to the lack of fuel getting to the cylinders. Primer plugs had a small cup attached, in which you would put a few drops of gasoline, then open the valve to allow it to flow into the cylinder. The engine then would have fuel to ignite for starting.
We haven’t seen plugs like that in years, and at a glance, today’s plugs look like those from 50 years ago. However, the reality is that they’ve remained in constant evolution. Copper plugs were the standard up through the 1970s, but the need for reduced emissions and leaner-running engines required a stronger spark. The advancements of electronic ignition provided this change, and spark plug technology kept pace with the introduction of platinum precious-metal plugs.
Not too long after, with the introduction of distributorless ignition, the continued development of precious metals led to double-platinum and iridium plugs, as well as fine-wire iridium, allowing precise ignition control and design to maximize combustion efficiency.
Now as we roll through the first part of the 21st century, engineering never slows down for the internal combustion engine, and four valves per cylinder along with direct injection are squeezing the real estate in an engine – and spark plugs have had to get smaller and smaller to fit. This also has opened additional upsell opportunities for tools because the once combination of 13/16-inch and 5/8-inch spark plug sockets that covered every vehicle made is no longer the case. Now we frequently need 9/16-inch and 14-millimeter sockets as well as 12-point variations.
In the world of high performance, smaller plugs are lighter weight and provide room for larger valves, and the smaller hole in the cylinder head provides increased cylinder-head strength as well as improvements in cooling-passage design.
Smaller plugs also mean smaller ceramic insulators, which in turn means engineering improvements to design these smaller insulators so they can retain their high dielectric strength.
Just when you thought there couldn’t be any more advancements, a new precious metal stepped into the game: ruthenium. My first thought was whowhatenium? But I checked: It’s on the periodic table. I must not have paid enough attention in science class. The bottom line is that ruthenium is an incredibly tough and durable metal. When used as the center-electrode material in spark plugs, it offers increased durability and is more resistant to corrosion and oxidation than iridium or platinum.
Ruthenium plugs also have brought new electrode designs in a double fine electrode that maximizes ignitability, designed for normally aspirated engines, and a projected square platinum electrode that provides the best ignitability, designed for turbocharged and supercharged applications.
Ruthenium plugs are generally known for improved cold starting and fuel efficiency, but reportedly don’t perform as well under extreme conditions such as high-speed engine operation or in vehicles hauling heavy loads. They can be a great upgrade for most applications, but be aware of the situations in which they may not perform as well. So, it turns out there IS something new with spark plugs, and at the rate of today’s technology, there most likely always will be.
      Standard Motor Products, Inc. (SMP) announced it released a total of 170 new part numbers in the first quarter of 2025, including introductions from
      link hidden, please login to view’s Vehicle Control and Temperature Control divisions. New coverage for late-model import and domestic vehicles was added across multiple powertrains, the company said. Ignition Coils have been added for Hyundai cars and SUVs, including the 2024-21 Elantra and 2024-22 Kona, and multiple new applications have been added to Standard’s Advanced Driver Assistance Systems (ADAS) Program. New coverage in this category includes Park Assist Cameras for import and domestic vehicles like the 2024-18 Chrysler Pacifica and 2024-20 Voyager, as well as Nissan, Toyota and Honda vehicles. Seven new ABS Speed Sensors were added, offering coverage for over one million Hyundai vehicles through the 2025 model-year, as well as the 2023-20 Kia Soul and General Motors vans through 2024. Also included in the release were Collision Repair components such as Hood Latch Assemblies, Tailgate Latch Assemblies, and Multi-Function Connectors for over one hundred million vehicles, according to
      link hidden, please login to view. Four Seasons New Numbers
      New numbers from Four Seasons include nearly 70 Hose Assemblies, adding coverage for over nine million import and domestic vehicles. This new offering includes Liquid Lines for the 2023-19 Subaru Forester, Discharge Lines for the 2024-21 Kia Sorento and 2023-21 Hyundai Santa Fe, and Suction and Liquid Lines for the 2023-21 Toyota Tacoma. Air Door Actuators were introduced for over three million General Motors trucks, as well as the 2021-19 Nissan Altima and 2020-19 Infiniti QX50. Four Seasons’ Reman and New Compressor programs have expanded as well, offering coverage for popular vehicles like the 2022-18 Honda Accord and 2023 Honda Civic. Additional categories that see expansion include Electric Coolant Pumps, Water Inlets, Thermal Management Modules, Heater Cores, Engine Coolant Auxiliary Pumps and more.
      Certain statements herein are “forward-looking statements” within the meaning of the Private Securities Litigation Reform Act of 1995. Forward-looking statements are usually identifiable by words such as “anticipate,” “believe,” “could,” “estimate,” “expect,” “forecast, “guidance,” “intend,” “likely,” “may,” “plan,” “position,” “possible,” “potential,” “probable,” “project,” “should,” “strategy,” “target,” “will,” or similar language. All statements other than statements of historical fact are forward-looking statements, including, but not limited to, statements about the Company’s strategic initiatives, restructuring and asset optimization plans, store and location opening plans, operational plans and objectives, and statements regarding expectations for future business and financial performance, as well as statements regarding underlying assumptions related thereto. Forward-looking statements reflect the Company’s views based on historical results, current information and assumptions related to future developments. Except as may be required by law, the Company undertakes no obligation to update any forward-looking statements made herein. Forward-looking statements are subject to a number of risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements. They include, among others, the Company’s ability to hire, train and retain qualified employees, the timing and implementation of strategic initiatives, risks associated with the Company’s restructuring and asset optimization plans, deterioration of general macroeconomic conditions, geopolitical factors including increased tariffs and trade restrictions, the highly competitive nature of the industry, demand for the Company’s products and services, risks relating to the impairment of assets, including intangible assets such as goodwill, access to financing on favorable terms, complexities in the Company’s inventory and supply chain and challenges with transforming and growing its business. Please refer to “Item 1A. Risk Factors” of the company’s most recent Annual Report on Form 10-K filed with the Securities and Exchange Commission (“SEC”), as updated by the company’s subsequent filings with the SEC, for a description of these and other risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements.
