Three Auto Repairs You Can Do at Home
Many drivers avoid working on their own vehicles out of fear that they don’t have the expertise or the time. Some vehicle owners imagine a sizable garage full of tools is required for a standard repair. But investing yourself in an at-home vehicle repair is rewarding and can ultimately save you time and money in the long run. You don’t need a bunch of fancy tools or a big garage to complete routine maintenance. All you need is NAPA.
The experts at NAPA Auto Parts can help you perform three straightforward vehicle repairs at home as part of your regular vehicle upkeep: replacing worn or
, rotating tires and changing your wiper blades. With the right tools and tips, adhering to a routine maintenance schedule prevents critical failures and expensive repairs plus keeps your ride on the road longer.
Find Your Spark: How to Change Spark Plugs
Replacing aging
is a critical part of vehicle maintenance as they are responsible for igniting the fuel that powers your engine. Most vehicle manufacturers recommend changing your spark plugs every 30,000 miles or so, depending on your year, make and model. If you notice your fuel efficiency decreasing or your vehicle is starting or idling rough, then it possibly time to
First, do your research. Refer to your vehicle’s manual for the information you need about the kind of spark plugs required and where they are located. Make sure you’re wearing gloves and eye protection to avoid injury. Clear any debris from around the plug with a brush and
to ensure no particulates get into the engine through the plug hole. Then, remove the old plugs (always pull from the wire boot, never pull the wire itself). Once you remove the plug, inspect it carefully for blistering or an abundance of soot. This could indicate your fuel mixture is incorrect or there are deeper issues in the engine.
Before you install the new plugs, refer to your owner’s manual for the proper spark plug gap measurement. Using a
or a
, set the gap by gently lifting or lowering the electrode to the proper width.
When installing the new plugs, make sure not to use anti-seize on the threads. Check the manufacturer’s recommended torque specs and tighten the plugs with a socket and ratchet accordingly. Simply reinstall your plugs in the proper order and that’s it! You’re officially a home mechanic.
A Good Rotation: How to Rotate Tires
Rotating your vehicle’s tires is another important part of vehicle maintenance, but an easy one you can do at home. As you drive, the rubber composite of your tires naturally wears down. When you steer your car, the front and back wheels move differently, so the tires wear down at different rates. To extend the life of your tires and maintain proper alignment, you should rotate your tires at least once a year. If you live in a colder climate, consider rotating them twice a year.
Before getting started, familiarize yourself with your vehicle’s drivetrain (Front Wheel Drive, Rear Wheel Drive, 4 Wheel Drive) and the kind of tires your vehicle uses (directional or non-directional). These factors affect the
. Once you’ve established the rotation pattern that works for your vehicle, put on your gloves and goggles and get to wrenching.
To perform a successful tire rotation, you’ll need
and a lug nut wrench. Make sure your vehicle’s parking brake is engaged, then:
  1. Loosen the lug nuts on each wheel before lifting your vehicle
  2. Use the jack and jack stands to lift your vehicle
  3. Remove the tires and reinstall them according to your vehicle’s ideal rotational pattern
  4. Hand-tighten lug nuts, and you’re done
No More Losing Streaks: How to Change Wiper Blades
You may not consider your windshield wiper blades a very important part of your routine vehicle maintenance. It’s easy to forget that these essential components can wear down, and no one wants to get caught in a rainstorm with windshield wipers that can’t do the job. If your wipers are leaving behind streaks or jumping and squealing over the glass, it’s time to
Do your research and figure out the correct length of wiper blades for your vehicle. Using the incorrect blade size can put undue strain on the wiper arms and wiper motor, which could mean they wear out faster. Consider the climate you in which you live and the time of year you use your wipers the most. In the winter, make sure your windshield is always deiced before engaging your wipers. Avoid engaging your wipers in the summer without moisture present on the windshield. NAPA Auto Parts carries a vast range of
for hundreds of vehicles and any weather condition. Shop all the best brands: NAPA Exact Fit, Proformer, Rain-X, Bosch and many more.
Once you have the correct blades for your vehicle, turn off the engine, then lift and secure the wiper arms. If your wiper arms are spring-loaded, lay a towel over your windshield while replacing the blades to avoid cracking your windshield if the arm springs back into place. Once replaced, test the wipers to make sure they work using a hose or your windshield washer function. While you’re replacing your wiper blades, check that the arms aren’t warped or cracked and clear out any leaves and debris that can collect in the air intake at the base of your windshield.
While acting as your own mechanic is a great way to give a little love back to your ride, it’s not always easy to get under the hood yourself. Whether your baby is a premium SUV, a reliable sedan or a beloved old jalopy, you can always trust the ASE-certified technicians at your local
to get the job done right. Now, you can use our handy
so you can budget for a repair job and know what to expect before you bring in your vehicle.
Featured image courtesy of
      Certain statements herein are “forward-looking statements” within the meaning of the Private Securities Litigation Reform Act of 1995. Forward-looking statements are usually identifiable by words such as “anticipate,” “believe,” “could,” “estimate,” “expect,” “forecast, “guidance,” “intend,” “likely,” “may,” “plan,” “position,” “possible,” “potential,” “probable,” “project,” “should,” “strategy,” “target,” “will,” or similar language. All statements other than statements of historical fact are forward-looking statements, including, but not limited to, statements about the Company’s strategic initiatives, restructuring and asset optimization plans, store and location opening plans, operational plans and objectives, and statements regarding expectations for future business and financial performance, as well as statements regarding underlying assumptions related thereto. Forward-looking statements reflect the Company’s views based on historical results, current information and assumptions related to future developments. Except as may be required by law, the Company undertakes no obligation to update any forward-looking statements made herein. Forward-looking statements are subject to a number of risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements. They include, among others, the Company’s ability to hire, train and retain qualified employees, the timing and implementation of strategic initiatives, risks associated with the Company’s restructuring and asset optimization plans, deterioration of general macroeconomic conditions, geopolitical factors including increased tariffs and trade restrictions, the highly competitive nature of the industry, demand for the Company’s products and services, risks relating to the impairment of assets, including intangible assets such as goodwill, access to financing on favorable terms, complexities in the Company’s inventory and supply chain and challenges with transforming and growing its business. Please refer to “Item 1A. Risk Factors” of the company’s most recent Annual Report on Form 10-K filed with the Securities and Exchange Commission (“SEC”), as updated by the company’s subsequent filings with the SEC, for a description of these and other risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements.
      Auto-Wares shared details of its Customer Cruise, Feb. 15-22, 2025. The Norwegian Bilss set sail from Miami and made stops in Mexico, Belize and the Bay Islands. Guests included customers, industry partners and friends. Auto-Wares described the cruise as more than just a vacation, calling the trip an opportunity to strengthen relationships and share ideas in a relaxed setting.
      link hidden, please login to view explained that for most of the trip, the weather was warm, sunny and ideal for cruising. Guests enjoyed blue skies and calm seas while relaxing on deck, exploring ports and soaking in the Caribbean views. By the final day, the weather took a turn, bringing some clouds and rougher seas. Despite that, Auto-Wares said everyone made the most of their last full day onboard, whether enjoying the ship’s indoor amenities, grabbing one last cocktail, or reminiscing.
