A Difficult Diagnosis: When Multiple Conditions Create Similar Symptoms
By Mighty Auto Parts
link hidden, please login to view appeared first on link hidden, please login to view. When filters bulge, gaskets blow, or filters dislodge from their mounted position on the engine, the oil filter is almost always blamed. Some install the second or third filter still convinced the filter is the cause. The filter is the victim, as over pressurization is the reason for the event and these issues have plagued […]
By NAPA
Some automotive issues make themselves known instantly and in a big way. But signs of a bad water pump aren’t always so brash. A bad water pump can wreak havoc on your engine and should not be taken lightly. But how does a water pump go bad? Here’s a few bad water pump symptoms that can help you deduce if repairs are in order.
Leaking Coolant
One of the most common symptoms of a bad water pump is a link hidden, please login to view from the water pump itself. Many water pumps are constructed with a weep hole below the pump drive shaft. Normally this weep hole is dry as the pump drive shaft seals keep the coolant at bay and away from the water pump bearings. But if the seal fails coolant can then seep past harming the water pump bearings and dripping out of the weep hole. The driver may notice a sweet smell of coolant cooking off the hot engine or a small puddle of coolant under the vehicle when parked. If the coolant is dripping on the accessory drive belt system there may be damp areas under the hood. If your vehicle develops a coolant leak or you find yourself adding coolant to keep it filled, check the area around the water pump just in case.
Overheating
One of the common signs of bad water pump functionality is link hidden, please login to view. The pump may not leak coolant, but the pump mechanism itself may have failed. Over time the fins of the pump can actually wear down to the point where they are no longer moving coolant. Cavitation can eat away at the metal pump vanes and pump surfaces. Plastic water pump vanes can disintegrate over time as the plastic ages. This all adds up to coolant that is no longer moved through the engine block and into the radiator to be cooled, leading to overheating.
Bad Noises
Water pumps have bearings that have to stand up to not only engine heat but also tension from the drive pulley. If you start to hear a grinding noise or high pitch squealing from the front of the engine, the water pump may be trying to tell you something. Try and rule out squealing belts by double checking belt condition and belt tension. Once you are sure the belt isn’t the cause try to pinpoint the source of the bad water pump noise. Be careful to not place any body parts near that rotating accessory drive system or the engine cooling fan. Simply stand in front of the running engine with the hood open and observe for a few minutes.
Oil Contamination
How to tell if water pump is bad can sometimes depend on the design of the engine. Some water pumps are buried inside the engine which makes it difficult to observe any problems. For example Ford Duratec V6 engines have the water pump located behind the timing cover. A leak from the water pump will allow coolant to mix with oil around the timing chains but the leak will not be visible on the outside of the engine. Checking the engine oil regularly and looking for an increase in oil level (due to coolant collecting in the oil pan) or a milkshake-like oil appearance are signs of possible symptoms of a bad water pump. Unfortunately these can also be signs of a bad cylinder head gasket, so further investigation will be required.
Any of these symptoms should be taken seriously and further investigation as to the source of the problem. If a bad water pump is diagnosed, it should be link hidden, please login to view. Don’t risk ruining an engine by putting off a repair that is relatively minor.
Check out all the
link hidden, please login to view on link hidden, please login to viewor trust one of our 17,000 link hidden, please login to view for routine maintenance and repairs. For more information on how to know tell if your water pump is bad, chat with a knowledgeable expert at your link hidden, please login to view The post
link hidden, please login to view appeared first on link hidden, please login to view. Low voltage conditions or the integrity of an electrical connection can pose some challenging events for the technician attempting to make an accurate diagnosis. In the world of automotive diagnostics, electrical problems have proven to be the most challenging, especially intermittent problems. Intermittent performance problems can be affected by connection-relate conditions and the presence of […]
link hidden, please login to view appeared first on link hidden, please login to view. Vehicles today incorporate a complex radio frequency system that controls many features such as Keyless Entry, Keyless Start/Stop, Remote Start and other electrical accessory components. Vehicle owners cherish these creature comforts as they eliminate the frustration of dealing with keys to control the same functions as the frequency-controlled devices. Often, they have a change of […]
AASA’s president and CEO, Paul McCarthy, recently announced multiple promotions within the association in recognition of hard work, professional development and dedication to the automotive aftermarket.
Ben Brucato, a 20-year industry veteran, has been promoted to vice president of engagement. Brucato has led multiple teams, including marketing, sponsorships and membership, during his time with AASA. He is lead over the Overseas Automotive Council, Modern Industry eXpertise Council and Marketing Executives Council, and specializes in member acquisition, engagement and retention.
Megan Gardner, with more than two decades of marketing and automotive-industry experience, has been promoted to senior director of sales and marketing. Gardner oversees the AASA marketing team, is lead over the OE Service Council, owns sponsorship and marketing responsibilities and supports government advocacy efforts.
Elizabeth Goad, with more than 10 years of tenure with AASA, has been promoted to senior director of events and meetings. Goad executes more than 90 events annually, including conferences, webinars and council meetings, and leads AASA and MEMA‘s activities as co-owner of AAPEX, which is one of the world’s largest aftermarket gatherings.
“We are honored to announce these promotions to kickoff 2022,” McCarthy said. “These three team members continuously exude qualities of strong leaders that contribute to a healthy and successful organization. Ben, Megan and Liz have worked diligently to connect members to what matters and have helped make AASA and the automotive aftermarket a better place for all of our members.”
For more information on AASA,
