A major part of the diagnostic process is identifying an issue from a normal characteristic. Following are some examples of customer complaints that could be mistaken as a problem when they may be a normal occurrence for the application. DIESEL ENGINES AND NOISE-RELATED SYMPTOMS Customer complaints of ticking, clicking, or cycling noises on 2017–2022 GM […]
    • By Moores95
      hope this kind of post is allowed, feel free to tell me to get out if not.
      im just hoping for some help identifying some car body parts, I work in a garage and all of this has been lying around for months, needs to be shifted.
      if anyone knows ANY info on any of these images it would be met with the highest praise
    • By Mighty Auto Parts
      link hidden, please login to view appeared first on link hidden, please login to view. When dealing with oil consumption complaints, how much should be considered as too excessive? Is the engine consuming an excessive amount of oil or should the amount consumed be considered a normal characteristic? This is especially a concern with the extended service intervals, which may result in the vehicle being driven twice the mileage when […]
      link hidden, please login to view appeared first on link hidden, please login to view. GM TRANSFER CASE NOISES Customer complaints involving howling, whining, shudder or grinding noises during parking lot maneuvers in Auto Mode or highway speeds in 4HI or Auto may occur on four wheel drive GM trucks and SUV vehicles. Vehicles affected range from 2014–2023 year models. Specific applications can be identified in GM Service Bulletin 19-NA-136. […]
      link hidden, please login to view appeared first on link hidden, please login to view. Scheduled vehicle maintenance makes good business sense, especially when compared to costly engine repairs or an engine replacement. Many vehicle owners unknowingly select a service interval that is not healthy for the engine or recommended by the vehicle manufacturer. Most vehicle manufacturers offer two service schedules…Normal and Severe Service. These options have created much controversy […]
      link hidden, please login to view appeared first on link hidden, please login to view. Failure to provide timely maintenance on a turbo-charged diesel engine can result in some expensive repairs, especially if it involves replacing a turbocharger or engine. The inexperienced may not realize how important some of the basic services are when servicing these applications. The turbo-diesel engines require a greater volume of air compared to a normal […]
