You’ve Got the Power to Clear the Powder
is a great way to get inches or even feet of snow cleared out of your way when you need without waiting around for a municipal or private service to arrive. People who live in snowier parts of the country know that the saying is correct: “If you want something done, do it yourself!” It’s especially beneficial for those who live in rural areas or may need a clear route in an emergency. Many truck owners with added-on aftermarket snow plows also choose to offer their services to neighbors or set up small businesses during wintertime.
Let’s face it, many truck, SUV and Jeep owners forego installing and operating
because of the risk to their vehicles. But most of those snow-laden horror stories usually originate from poor maintenance and improper installation. Fortunately, the experts at NAPA Auto Parts have all the right
and
to ensure your rig can handle the next big blizzard or nor’easter.
How to Use a Snow Plow on a Truck
Before getting your rig out in the downy flakes, it’s important to consider a few things:
  1. How much snow will you plow and where? Will you install the plow mechanism only once or twice every winter? Will you focus on a driveway or will you clear larger areas? What kind of terrain will you clear? Roads? Fields? Answering these questions can help you determine
    : a  for light-duty snow clearing, a v-plow for breaching large drifts and depositing snow on either side or a box plow for moving large amounts of snow.
  2. Once you find the right plow, you need to install it correctly. Carefully study your vehicle owner’s manual, as well as the manual for the plow, so you know the right tools to use and what precautions to take.
  3. Get familiar! Study the terrain prior to a snow event and never plow unfamiliar terrain. Hidden boulders, ditches, stumps and retaining ponds can spell disaster for a truck, so make sure you know where you’re going and what’s below the snow.
To minimize the chances of engine trouble while you’re plowing, set aside some time to do a full tune-up on your rig before you start. Check your tire pressure and fluid levels, change the oil and the oil filter. Replace any headlights or taillights that are dim or out completely. Replace wiper blades if they are worn and consider upgrading to a model that’s suited for winter use like the
or
Transmission issues are common problems that can arise from plowing with a truck, but you can avoid undue stress to your gearbox by doing your research and adhering to a mindful maintenance schedule during the winter months. Check your transmission fluid frequently. Smell it for a burning odor that could indicate overheating. Consider installing a
and pause plowing if the temperature goes above 250 degrees Fahrenheit.
Putting Safety First Comes with Rewards
Winter driving can get risky, especially when you’re plowing with your truck, SUV or Jeep, so make sure you are prepared for any possible emergency situations. Along with keeping your truck stocked with a good
, keep a
, energy bars and bottled water in case you become stranded overnight.
Retrieval equipment like
and  can come in handy in case you come across a stranded driver. Visibility on the road is always important, but the bleak, dim days of winter make visibility crucial. Equip your rig with a fully-functional
before you begin so that everyone else on the road can see you and you can see them.
From windblown drifts to a few inches in the driveway, let NAPA Auto Parts help you prepare for the powder this winter! We also offer a great selection of smaller plowing options if you want to plow with something other than your pickup. Turn your UTV,
or even your  into a small plow so you can leave your ride in the garage.
Start reeling in the points when you join the
program this winter—sign up now and get $5 automatically!
Featured image courtesy of
