A long time ago headlight bulb options were pretty straight forward. You had round or rectangular headlight bulbs in just a few sizes that were used by pretty much every automaker. Basically you just had to match the bulb to the hole in the grille and make sure it was high or low beam (or a combination of the two). But in the early 1980s the Lincoln Mark VII introduced the idea of a headlight assembly where the bulb could be replaced like a flashlight, while the lens and housing stayed on the car. While this made service simpler, it didn’t exactly make finding the correct type of headlight bulb at the parts store easier. Let’s take a look at the different types of headlight bulbs available and where you might find them.
Sealed Beam Headlight Bulbs
We’ll start with the
. These bulbs are large and usually round or rectangular. The lens, reflector, and filament are one non-serviceable assembly. The lens is usually glass. Most passenger vehicles moved away from sealed beam bulbs in the 1990s, but there are plenty of vehicles still on the road that use them. In particular the fleet vehicle industry stuck with sealed beam bulbs thanks to cheap replacement costs and ease of service.
Today unless you have a vintage car or work truck you probably won’t be buying a sealed beam headlight bulb. But if you do happen to have one of these vehicles and want to move into the modern age there are actually
versions of sealed beam assemblies on the market. Just remove your old halogen bulb and update your headlights to the 21st century.
Halogen Headlight Bulbs
By far the most common type of headlight bulb is the
. If you are wondering “what headlight bulb do i need” the likely answer is a halogen bulb. These bulbs give off a nice bright long lasting light thanks to the presence of one of the
of gasses sealed inside. Their design makes for a much hotter bulb though, so the headlamp assembly has to be designed to handle the high heat output.
Here’s a few common sizes and common vehicles where you might find them:
  • H11 headlight bulb – 2007-2020
    , 2005-2017 Ford Mustang, 2006-2021 Honda Civic
  • 9003 headlight bulb – 2007-2020 Honda Fit, Harley Davidson motorcycles, Kawasaki motorcycles
  • 9005 headlight bulb – 1987-2005 Buick LeSabre, 2001-2016 Toyota Corolla
  • 9006 headlight bulb – 1995-2007
    , 2000-2014 Subaru Impreza
  • 9007 headlight bulb – 1996-2003 Dodge Grand Caravan, 1996-2006 Chrysler Sebring
  • 9012 headlight bulb – 2011-2015
    , 2004-2007 Nissan Maxima
Some halogen bulbs work as fog light bulbs as well, so one bulb can be used for a myriad of applications.
High-Intensity Discharge (HID) Headlight Bulbs
You probably heard about
years ago when talking about luxury cars. While these
were once the realm of the high end market, now you can find all kinds of normal vehicles with the option for HID headlights. These lights don’t use a filament like a normal bulb, but use extremely high voltage to strike an electrical arc inside a sealed glass bulb. A separate ballast is used to get the lighting arc started, so this system is slightly more complicated. If your vehicle is equipped with higher end options then HID lighting is likely among those features. If your HID lights stop working, make sure to check the ballast as well.
Light-Emitting Diode (LED) Headlight Bulbs
If you have a newer vehicle with LED headlights then you likely won’t need a new LED bulb for quite some time. LED lights have long service lives and are very energy efficient. For automotive use on modern vehicles the LED light itself is likely part of the headlamp assembly and not meant to be replaced by itself. So if you have factory LED headlights and are asking “what kind of headlight bulb do i need” the answer is the entire headlamp assembly.
If you have an older vehicle there are
that simply plug in to the existing wiring and bulb mount. These let you use LED headlight bulbs in a vehicle that was not originally equipped with them.
Figuring out what is the best type of headlight bulb really comes down to vehicle application. Typically it is best to choose the same type of bulb the the design engineers specified for the vehicle. While it is possible to upgrade headlights, remember that the NHTSA has strict guidelines that control not just the light type but also how it is projected. Just dropping a brighter bulb in a headlamp assembly can seriously impair the vision of oncoming drivers due to a mismatch in bulb and reflector.
Check out all the
available on
or trust one of our 17,000
for routine maintenance and repairs. For more information on answering “what headlight bulbs do i need” all the way to picking the best LED headlight bulbs, chat with a knowledgeable expert at your
Photo courtesy of
      On Feb. 18, 2025, the automakers released a legislative proposal related to automotive right to repair; the views cited in this proposal represent a small fraction of the repair market and are not representative of the broader automotive aftermarket, MEMA said. The industry does appreciate automakers’ acknowledgment of the need for federal legislation to protect consumer choice in vehicle repair and looks forward to congressional consideration of the REPAIR Act.
      Auto Care Association President and CEO Bill Hanvey and MEMA Aftermarket Suppliers President Paul McCarthy released the following statement:
      “We’re pleased to see trade groups representing automakers finally admit what we’ve long known: congressional action is needed to ensure independent shops and aftermarket parts manufacturers can continue to offer Americans quality, affordable choices for vehicle repairs.
      “That said, this latest proposal appears to be a tactic to delay and defeat pro-consumer right to repair legislation at every level. The bipartisan Right to Equitable and Professional Auto Industry Repair Act (REPAIR Act) is a straightforward approach to ensure safe and secure access to vehicle repair and maintenance data.
      “The REPAIR Act, led by Congressman Neal Dunn, is the solution. Protection of consumer and fleet-owner choice ensured access to critical repair data, an established federal enforcement mechanism, and the prevention of repair monopolies is accomplished through the REPAIR Act. Without it, the aftermarket will lose the ability to not only innovate but continue to offer consumers options to keep their vehicles on the road.
      How to choose the correct battery for your car or truck
