Serpentine Belt Wear Indicators
link hidden, please login to view N.A announced the expansion of its aftermarket portfolio with 13 new belt drive SKUs that offer application coverage for over 5.2 million vehicles in operation (VIO). A news release from
link hidden, please login to view said the latest product expansion “brings innovative solutions designed to meet the evolving needs of modern vehicles and repair technicians. The upgraded components enhance efficiency, simplify installation and reduce inventory complexity for distributors and shops.” The company’s new product lineup features:
Three pulleys covering over 2.1 million VIO. Seven overrunning alternator decouplers (OAD) spanning over 860,000 VIO. Three belt tensioners covering over 2.2 million VIO, now featuring advanced engineering upgrades for improved performance and ease of use. “It is essential that shops have access to reliable, OE-equivalent aftermarket parts as vehicles become more advanced. With 11 of the 13 new SKUs being first-to-market and OE-engineered, we’re giving technicians access to solutions that weren’t previously available,” said Ana Maria Lopez, product application manager at Litens Aftermarket N.A. “This is about staying ahead of industry complexity and ensuring shops have the right parts when they need them.”
All new SKUs are available now through
link hidden, please login to view distribution network, with additional product expansions planned throughout 2025, the company said.
You might not be able to see it, but an accessory-drive belt is always both speeding up and slowing down. When a piston accelerates downward after the ignition of the fuel and air, the crankshaft speeds up and then slows down as it reaches the bottom of the stroke. These changes in speed are minimal, but big enough to cause problems over time.
If the pulses aren’t minimized, they can hammer the belt and the attached rotating components. On a four-cylinder engine, the degrees of rotation between power pulses are greater than on a V-8 – so the amount of change in speed on the four-cylinder pulley is greater than on a V-6 or V-8. This has a direct effect on how the belt system is designed.
The belt-drive system is working hardest when the engine is at idle. When the engine is below 1,000 rpm, the alternator, A/C compressor and power-steering pump are putting the greatest strain on the belt.
Some of the forces can be taken up by the belt slipping on the pulleys. But, slipping causes friction and wear on the belt, as well as flutter. Over time, the slipping can get worse as removal of material from the ribs causes the belt to bottom out.
There are three components that help to keep the belt on the pulleys without slipping. The tensioner, harmonic balancer and decoupler pulley work together to keep the accessory-belt system quiet and the belt lasting until the replacement interval.
Tensioner
The tensioner applies force on the belt. Some tensioners have devices that dampen the movement of the spring and arm, helping to keep constant force on the belt even under a wide variety of conditions.
Harmonic Balancer
The harmonic dampener puts a layer of soft material between the crankshaft and outer ring of the pulley. The material helps to dissipate the power pulses and resonant frequencies. While the dampener may only flex one or two degrees of movement, this takes a lot of strain off attached components.
Decoupler Pulley
Some alternators have a decoupler pulley. This device serves two purposes. First, it helps to decouple the pulley from the alternator with a one-way clutch. The decoupler reduces parasitic losses by not having to fight against the momentum of the armature in the alternator while the engine is decelerating and accelerating.
Some decoupler pulleys have a spring and friction dampener to reduce vibration. When an alternator decoupler pulley is compromised, it can no longer absorb the same level of abuse, which has a trickle-down effect throughout the system.
Alternator decouplers and pulleys should be inspected every 10,000 miles for wear. Early design versions have a service life of 40,000 to 60,000 miles, with more recent versions lasting more than 100,000 miles.
When inspecting a decoupler or pulley, there are two signs that replacement is needed. First, after shutting down the engine, if there’s an audible buzzing, the bearings in the pulley have likely failed. The second sign depends on whether the vehicle has a one-way clutch (OWC), overrunning alternator pulley (OAP) or decoupler (OAD).
With the inspection cap/cover removed and the center locked, turn the pulley or decoupler with the appropriate tool. If it’s an OAP or OWC, the pulley can only be turned in the clockwise direction. If it’s an OAD, a counterclockwise turn will reveal a noticeable increase in spring force; a clockwise turn will only have slight resistance. The tensioner, harmonic balancer and decoupler pulley work together to keep the belt in contact with grooves in the pulleys. The three components are engineered together to match the engine. If one part is compromised, all are compromised, including the belt.
Litens Aftermarket introduced its new “System Reset” campaign, aiming to bring awareness to the importance of proper drive-belt system maintenance.
In an effort to educate professional vehicle service technicians, Litens details what a system reset entails, its significance and the potential repercussions of neglecting this essential maintenance step when replacing a drive belt.
For a belt-drive system to perform optimally, the system’s components must be properly maintained and in tune with each other throughout the lifespan of the vehicle. When it’s time to replace the drive belt, it’s also time to replace the drive-belt system’s tensioners and pulleys. The system is properly reset when all components of the belt-drive system, including the tensioner, idler pulley(s) and the belt, are all replaced at the same time.
“As vehicle belt-drive systems become more complex, we’re aiming to equip technicians with both education and solutions,” said Scott Howat, national sales manager, Litens Aftermarket. “Properly resetting the belt-drive system enables the technician to reset the vehicle to its optimal OE level of performance.”
Benefits of a system reset – replacing the tensioner and idler pulley(s) along with the belt – include enhancing the system’s reliability and longevity, as well as reducing the risk of component failure and subsequent breakdowns. Resetting all of the belt-drive system components together promotes optimal power transmission, minimizing slippage and improving overall efficiency, which can contribute to enhanced fuel economy and performance.
Failing to fully reset the system can lead to imbalanced stress distribution, reduced overall system efficiency and premature wear of both the newly replaced parts and the remaining older components. This could result in increased friction, potential belt slippage and an elevated risk of component failure, ultimately compromising the entire belt-drive system’s reliability and performance.
Litens designs OE belt-drive systems and components to last for a designated period of time. While that number also depends on miles driven and the number of vehicle starts/stops, the belt-drive system typically runs for 100,000 miles before needing maintenance. As all of the system’s components are designed to work together, when the belt is due for replacement, it’s highly likely that the rest of the components in the system are also due.
For more information, visit
Litens Aftermarket recently introduced its latest OE improvement, the 999420A belt tensioner.
This new tensioner boasts improvements to the OE design, enabling an efficient belt-tensioner replacement process by a single technician, according to Litens.
“This tensioner was engineered to improve upon the OE design by addressing the challenges technicians encounter during the installation of belt tensioners, particularly in the confined spaces of engine compartments,” Litens explained in a news release. “Focusing on ease of installation, Litens integrated a design advancement to simplify the installation process significantly.”
The design upgrade is the lift feature, strategically placed in an offset position between the mounting bolts that secure the tensioner – adding an extra inch under the lip for a technician, providing greater ease of access.
Typically, a tensioner is located at the side of the engine compartment where there’s very little room for working hands to get a wrench on the tensioner to loosen the belt during installation. The configuration in the Litens tensioner facilitates easy access for technicians to position their wrench when loosening the belt, streamlining the installation process even in the tightest engine compartments, according to the company.
Additionally, the lift feature is designed for a 14-millimeter hex wrench consistent with OE design, rather than using a 15-millimeter hex wrench traditionally used on aftermarket tensioners. Consequently, Litens says, the technician has one less tool to keep track of throughout the replacement process.
“As an engineering company that manufactures parts, we recognize the struggles that come with installing these parts in tight space,” said Randy Wolters, product manager, belt-tensioning products, Litens Aftermarket. “With these design improvements we’re able to give the tech an extra set of hands and save them from the bloody knuckles you get when working in such a tight space.”
link hidden, please login to view is available for all Mazda applications between the years 2006 through 2017, covering a total of 30,000 vehicles in operation. The post
