Catalytic Converter Theft Statistics
According to data compiled by the National Insurance Crime Bureau (NICB), reported catalytic converter thefts jumped from 1,298 in 2018 to 14,433 in 2020. And this trend is still gaining speed. In the first half of 2022, the automotive insurance provider State Farm received more than 23,000 catalytic converter theft claims.
This national crime spree has drawn the attention of local law enforcement, as well as federal investigations. In November 2022,
on the bust of a multimillion-dollar catalytic converters theft network. Arrests, searches and seizures took place in California, Oklahoma, Wyoming, Minnesota, New Jersey, New York, Nevada, North Carolina and Virginia.
California accounts for nearly 25% of insurance claims for theft of catalytic converters followed by Texas with nearly 14% of claims. Approximately 1,600 catalytic converters are reportedly stolen in California each month. However, vehicle owners across the country must prepare ahead of time to prevent catalytic converters from getting stolen.
On December 9, 2022, the
in a suburb south of Chicago. They seized 128 stolen catalytic converters worth approximately $54,000. In the stash were several reciprocating saws, which are used by thieves to detach a catalytic converter in less than a minute.
Preventing Catalytic Converter Theft
To prevent catalytic converter theft, crime experts recommend parking your vehicle inside a secure garage or in a well-lit area. But that isn’t always possible, especially for work vehicles. Sure, an alarm system might help deter someone from quietly breaking into your vehicle for valuables, but a criminal ring willing to operate an electric reciprocating saw at night in a suburban neighborhood is most likely not scared away by an annoying alarm.
Because fleet vehicles like cargo vans and heavy-duty pickup trucks sit higher, they are often the target of catalytic converter theft. However, reports show that standard commuter hybrids, such as the Toyota Prius, Lexus RX and Honda Jazz, have the highest number of cases of catalytic converters getting stolen. Fortunately, The NAPA Network is here to help with catalytic converter theft prevention.
Best Catalytic Converter Anti-Theft Device
A
is a metal device designed to reduce harmful emissions and gases, such as hydrocarbons, carbon monoxide and other air pollutants. On a standard combustion engine, this required part converts toxic fumes into safe gases through a chemical reaction. On the inside, catalytic converters are lined with tiny pores that are coated with platinum, rhodium or palladium. These precious metals are what makes a premium catalytic converter worth more than $1,000 on the black market at junk yards.
For the best catalytic converter theft protection, the NAPA experts recommend installing the
. Built from heavy-duty metal wire, the cage of your CatClamp is unbreakable by design. Choose either the Standard Model with a 1-Year Warranty or the Stainless Steel MAXX Model with a Lifetime Warranty. Both versions are manufactured in the United States.
This easy-to-install catalytic converter theft deterrent product fits almost any gas-powered vehicle, including RVs. The durable metal rope can loop around your converter in as many as eight different points. Keep in mind, your CatClamp cables must route through a permanent (non-moving) component of your vehicle. While this catalytic converter anti-theft device can cost a couple hundred dollars, installing a replacement catalytic converter can cost thousands of dollars between the purchase of the part and the professional labor required.
Signs of a Stolen Catalytic Converter
Signs that your catalytic converter was stolen include a loud noise coming from your open exhaust, sluggish acceleration, dark smoke expelling from your tailpipe or the smell of rotten eggs coming from underneath your vehicle. If you notice any of these signs, investigate further. Driving a vehicle without a catalytic converter is illegal, unless the age of your vehicle makes it exempt. Without a catalytic converter, your vehicle will not pass the required annual emission test.
Operating a vehicle with no catalytic converter also means hot, dangerous gas is released under your car, which heats up sensitive components and exposes passengers to carbon monoxide. That’s why many car owners place an anti-theft device for catalytic converters on each of their gas-powered vehicles.
Keep in mind, all-electric vehicles, which consume no gasoline or diesel and plug into electric sockets to replenish their batteries, are the only vehicles on the road today that do not have and do not need a catalytic converter. But for all other vehicles, including standard hybrids and plug-in hybrids, NAPA is your one-stop-shop for all the
you need, as well as upgrades to your
Photo courtesy of
      Why you should empty the master cylinder before bleeding brakes
    • By Daysyore
      The catalytic converter is a critical component in modern vehicles that plays a crucial role in reducing harmful emissions. This device, typically located in the exhaust system, helps convert toxic pollutants from the engine's exhaust gases into less harmful substances. While catalytic converters have been instrumental in improving air quality and meeting emission standards, they have also become a hot topic of discussion due to their environmental impact, cost, and potential for theft. In this article, we will explore the significance of catalytic converters, their environmental benefits, challenges faced, and potential future developments.
      Environmental Benefits:
      Catalytic converters have made significant contributions to reducing air pollution and improving overall environmental quality. They primarily work by facilitating chemical reactions that convert harmful pollutants into less harmful compounds. Key environmental benefits include:
      1. Emission Reduction: Catalytic converters effectively reduce emissions of harmful pollutants such as carbon monoxide (CO), nitrogen oxides (NOx), and unburned hydrocarbons (HC). These pollutants contribute to smog formation, respiratory issues, and environmental degradation.
      2. Compliance with Regulations: Catalytic converters enable vehicles to meet stringent emission regulations imposed by governments worldwide. These regulations aim to mitigate the adverse effects of vehicle emissions on public health and the environment.
      Challenges and Concerns:
      Despite their environmental benefits, catalytic converters face several challenges and concerns:
      1. Precious Metal Usage: Catalytic converters contain precious metals like platinum, palladium, and rhodium, which act as catalysts. The extraction and mining of these metals can have negative environmental impacts, including habitat destruction and water pollution.
      2. Cost and Maintenance: Catalytic converters are expensive components, and their replacement or repair can be financially burdensome for vehicle owners. Additionally, improper maintenance or the use of low-quality fuels can lead to premature failure or reduced effectiveness of the catalytic converter.
      3. Theft: Catalytic converters contain valuable metals, making them a target for theft. Criminals often remove catalytic converters from vehicles due to their high resale value, leading to inconvenience and financial loss for vehicle owners.
      Future Developments:
      To address the challenges associated with catalytic converters, ongoing research and development efforts are focused on potential advancements:
      1. Alternative Catalyst Materials: Scientists are exploring alternative catalyst materials that can reduce or eliminate the need for precious metals in catalytic converters. This could help mitigate environmental concerns related to metal extraction and lower production costs.
      2. Improved Efficiency: Researchers are working on enhancing the efficiency of catalytic converters to further reduce emissions and improve fuel economy. Advancements in catalyst design and optimization of chemical reactions can contribute to more effective pollution control.
      3. Anti-Theft Measures: Automotive manufacturers and law enforcement agencies are collaborating to develop anti-theft measures, such as tamper-resistant designs and identification technologies, to deter catalytic converter theft.
      Conclusion:
      The catalytic converter remains a vital component in the automotive industry's efforts to reduce harmful emissions and improve air quality. While it has made significant environmental contributions, challenges such as precious metal usage, cost, and theft persist. Ongoing research and development endeavors aim to address these concerns through alternative catalyst materials, improved efficiency, and anti-theft measures. As technology advances, striking a balance between environmental impact, automotive performance, and affordability will be crucial in shaping the future of catalytic converters and sustainable transportation.
      Before selling a vehicle, make sure to remove personal data from the infotainment system
      The Environmental Protection Agency (EPA) enacted the Clean Air Act to reduce pollution in the late 1960s. Part of the act was to mandate the use of catalytic converters on new vehicles. As these emissions components required replacement, the Clean Air Act was revised to rules to also cover replacement catalytic components.
      At the same time, the California Air Resources Board (CARB) proposed a stricter set of rules for new vehicles and replacement emissions parts. This has made replacing a catalytic converter a very litigious process that requires specific steps are covered.
      link hidden, please login to viewEnvironmental Protection Agency EPA headquarters Here are the 10 commandments of converter replacement handed down from the EPA.
      1. If the replacement is not required by a state or local program, both the customer and technician must sign a statement concerning why the converter was replaced. (Manufacturers either provide such a statement with the converter or have an example in their catalogs.)
      2. If the replacement is required by a state or local program, the technician must keep a copy of the statement or order by the program representative.
      3. The invoice for replacement must include the customer’s name and complete address, the vehicle’s make, model year and mileage, as well as the reason for replacement.
      4. Retain copies of the invoices and statements for six months and the replaced converters for 15 days (converters must be identified or marked as to which customer’s car they came from).
      5. Install the converter in the same location as the original.
      link hidden, please login to viewChanging the location of the catalytic converter can change the performance. 6. Install the same type of converter as the original — oxidation, 3-way or 3-way plus oxidation (dual-bed). This information is sometimes available on the emission tune-up label or from the manufacturer’s application catalog.
      7. Install the proper converter for the vehicle as determined and specified by the converter manufacturer. There are engine-size and vehicle-weight limitations that make it inappropriate to install certain converters on certain vehicles. Newer vehicles with On-Board Diagnostic (OBD) systems may not always operate properly with certain aftermarket products. Therefore, the catalog should always be consulted for the correct application.
      8. The converter must always be properly connected to any existing air injection components.
      9. Install all the other required converters the vehicle would have originally come with unless the converter manufacturer has stated in writing that the aftermarket converter is designed to replace more than one converter.
      10. For new aftermarket converters, the installer must fill out the warranty information card supplied by the manufacturer and give it to the vehicle owner or operator.
      Violating the EPA rules is a breach of federal law since noncompliance is likely to increase the amount of pollution coming out of the vehicle. Penalties for violations by individuals, service or repair shops or fleet operators can be up to $2,500 per violation. (Each improper installation is considered a violation.)
      Additionally, new-car dealers can be penalized up to $25,000 per violation. Any person who causes a violation could be subject to the same penalty as the technician. New York State Environmental Conservation Law regarding catalytic converter installation mandates a minimum penalty of $500 for a first violation, and up to $26,000 for each subsequent violation. Failure to maintain complete records or submit reports may also result in a violation.
      The conditions under which the catalytic converter was installed is of great importance to the part manufacturer. Even simply using the wrong part on a vehicle may allow the converter manufacturer to not honor the 25,000-mile or the 5-year/50,000-mile warranty. For vehicles in California and other states that require California Air Resources Board (CARB)-mandated emissions equipment, the rules are different.
      link hidden, please login to view All of the same mandates apply, but they are much more strict about the replacement converter being CARB-compliant. Also, the CARB rules are based on a one-for-one replacement strategy, and the addition or consolidation of converters is forbidden. The greatest difference between states is the length of time needed to keep documentation. California and New York require paperwork be kept for at least four years. Also, it is important to check local and state laws before installation. New York, for instance, enacted a ban on installing used catalytic converters on vehicles.
      link hidden, please login to viewannounced the debut of the LuK TorCon 6L80, which the company said is “the only all-new, never remanufactured torque converter available in the independent aftermarket.”
      link hidden, please login to view has a design proven to last up to five times longer than rebuilt torque converters, according to the company. link hidden, please login to viewalso said that unlike remanufactured options that demand the labor-intensive process of acquiring and stocking model-specific cores, the Luk TorCon 6L80 requires only a straightforward match to the transmission, saving time and effort for customers. The fully furnaced brazed fins not only enhance heat dissipation, but also prevent premature wear, ensuring longevity and reliability, according to Schaeffler. The contamination-free manufacturing process is backed by rigorous 100% pressure and lockup testing, as well as precision balancing.
      The TorCon 6L80 (TC0017 24247371) is compatible with 2007-2020 GM trucks, vans and SUVs with a 5.3L, with a current VIO of 6,211,856, according to Schaeffler.
      Schaeffler added it “offers a solution to the common issue of core returns and eliminates the risks associated with remanufactured parts such as blemishes created during service, ensuring superior quality and reliability.”
      “As technology improves and torque converter designs are changing, the torque converters in the transmissions of today are becoming much more challenging to rebuild. Therefore LuK is offering a complete assembly, with built in quality that ensures a consistent performance in each unit.” says Rob Steinmetz, product manager. ”Years ago, the LuK brand was first-to-market with new service clutch alternatives to the rebuilt options previously available in the aftermarket. Replacement clutches are now almost exclusively new, not rebuilt. The launch of our new, not rebuilt torque converters stands as a prime example of the company’s continued commitment to changing the landscape of the aftermarket.”
      In the coming months, the company plans to release additional SKUs as it continues to expand product offerings.
