Air suspension provides drivers and their passengers with luxurious ride quality, increased safety and load-leveling capabilities. But the high-tech components in an air-suspension system come with high-tech replacement costs.
Chip Lofton, founder of Strutmasters, learned this the hard way.
In 1999, Lofton purchased a 1989 Lincoln Continental. While on vacation, the car’s suspension system failed. Lofton took his beloved Lincoln to a dealership, only to find out that it would cost several thousand dollars to repair the suspension.
Determined to find a more affordable strategy to repair the vehicle, he called salvage yards in hopes of tracking down used air struts, without any luck. To his surprise, however, Lofton found a wrecked Lincoln with a regular set of struts on it. After figuring out where to drill holes in the body and make adjustments to the height, he was up and running – at a fraction of the dealership’s estimated cost. The air-to-coil conversion was complete, and Strutmasters was born.
From the early days of making conversion kits in Lofton’s goat barn and selling them on eBay, Strutmasters has grown into a nationwide provider of affordable suspension solutions, headquartered in Roxboro, North Carolina.
While the Strutmasters portfolio today includes control arms, sway bars, shocks, trailer hitches and other replacement parts, the company’s bread and butter continues to be conversion kits – and with good reason. Citing RepairPal, Strutmasters estimates that the average cost of a replacement air spring is $1,200, while the average cost of an air compressor is $875. Suspension-control modules average $685, while ride-height sensors average $450. And that’s just for the parts.
According to Strutmasters, one OE-replacement front air strut for the Lexus GX 470 costs just under $1,500 for the part alone. A four-wheel conversion kit for the 2003-2009 Lexus GX 470 costs about $800. That’s the entire suspension replaced for less than the cost of one OE air strut.
“Air suspension is extremely expensive, especially for OE-quality parts,” says Scott Beaddles, director of operations for Strutmasters. “If you go back to the dealership with a Mercedes and you want to get your suspension replaced, it’s going to cost you about nine grand. We sell a kit for a fraction of that cost that replaces it all, and it’s not going to fail either.”
A conversion kit enables the customer to remove their vehicle’s air springs, ride-height sensors, compressor and air lines, and replace them with coil springs, hardware, mounts and passive struts. The kits are designed to bolt onto the vehicle, so no welding, cutting or modifications are necessary.
For Strutmasters, a typical customer might be the second or third owner of an air-equipped luxury vehicle.
“When you get that second or third Mercedes owner who bought a $10,000 car and now they need $12,000 worth of suspension parts – they’re not willing to do it,” Beaddles says. “That’s where we come in.”
Air suspension used to be the exclusive realm of luxury sedans. However, more and more OEMs are using air suspension to provide a luxury feel for SUVs and pickups. In parallel with this trend, conversion kits for models such as the 2011-2015 Jeep Grand Cherokee and 2013-2018 Ram 1500 have become top sellers.
While conversion kits are a cost-effective alternative to air-ride replacement, the original air-ride quality can’t be duplicated with conventional springs and hydraulic dampening. Still, for a customer with a long-dead system, the improvements will be noticeable.
“The people who are coming to us, their suspension has been screwed up for a while,” Beaddles adds. “They’ve been riding on just nothing, basically. By the time they switch over, the ride is much better because it’s actually functioning properly, and they’re not bouncing on the bump stops anymore, so the strut isn’t locked up or whatever the case may be.”
Beaddles notes that Strutmasters offers conversion kits for several types of active suspension systems – not just air. For example, a number of GM vehicles dating back to the 2002 model year feature MagneRide suspension technology. MagneRide systems utilize monotube dampers filled with magneto-rheological fluid, which contains soft iron particles that become magnetized when electromagnetic coils in the damper pistons are energized by the ECU. Strutmasters offers four-corner OE replacement kits for the 2007-2014 GMC Suburban 1500 and other GM models with magnetic suspension systems.
One final point: Beaddles emphasizes that an affordable price shouldn’t be mistaken for a cheap fix. Strutmasters’ conversion kits are assembled in the United States and are made with durable, high-quality materials such as cold-wound steel springs.
“We also have an ASE-certified staff here,” he says. “If you’re having a problem with your install, call us up, we’ll walk you through the entire install, step by step. If you’re having a problem getting your module installed, or a light’s still on, give us a call. We walk people through it all day long.”
      Frenkit, a European brake hardware supplier, is expanding coverage for the North American aftermarket. Featuring proprietary rubber components manufactured at its facilities in Spain and India, the company said it now offers U.S. customers nearly 4,500 different brake hardware kits, covering 95% of U.S. aftermarket sales.
      link hidden, please login to view said its program includes hardware kits for both disc and drum brakes, caliper pistons, brake caliper repair kits, electronic parking brake kits and more. The company said its portfolio is comprised of more than 12,000 different components covering 50,000 parts cross-referenced to OE. Frenkit added that its catalog is fully ACES and PIES compliant and FMSI-indexed. The post
      Standard Motor Products, Inc. (SMP) announced it continues to add to its line of kits. Standard and Blue Streak offer Kits and Multipacks in a variety of categories. Among its most popular are Blue Streak GDI High-Pressure Fuel Pump Kits and Ignition Coil Multipacks, the company said. Blue Streak GDI High-Pressure Fuel Pump Kits help technicians solve low-fuel-pressure symptoms by replacing all components at once to ensure a complete repair,
      link hidden, please login to view said. These kits include an all-new high-pressure fuel pump, cam follower, the required seals, and mounting hardware. Ignition coils can lose spark energy over time, causing poor fuel mileage and reduced performance and if one coil fails, it is likely the others are on track to fail. Blue Streak Ignition Coil Multipacks include a full, matched set of new, better-performing coils, saving time, restoring performance and reducing comebacks. SMP said other popular kits include complete Standard Turbocharger Kits, Oil Filter Housing Kits, and Fuel Injector Multipacks and Blue Streak Blower Motor Resistor Kits, Camshaft and Crankshaft Sensor Kits, Variable Valve Timing (VVT) Service Kits and VVT Solenoid Kits. In the past two years, specific Blue Streak Kits have been awarded the Best New Product of the Year and Best Problem-Solver by the Import Vehicle Community, a community of the Auto Care Association.
      New coverage has recently been introduced across many of these categories, according to SMP. Blue Streak GDI High-Pressure Fuel Pump Kits have been released for 3.7 million General Motor vehicles, like the 2019-16 Chevrolet Cruze, 2019-18 Chevrolet Equinox, and 2019-18 GMC Terrain. Standard Oil Filter Housing Kits are new for multiple popular makes and models, including the 2024-19 Jeep Grand Cherokee, 2024-19 RAM 1500, 2024-19 Dodge Durango, 2016-11 Volvo S60, and more. Blue Streak Cam and Crank Sensor Kits have been released for a variety of popular Ford vehicles, and Standard Turbocharger Kits are new for Ford, Volvo, and General Motors vehicles like the 2019-16 Chevrolet Cruze and Buick Encore, SMP said.
      Commenting on the expansion, John Herc, vice president of vehicle control marketing at
      link hidden, please login to view, said, “Parts professionals are looking for more complete kits and multipacks for a number of reasons. First, it helps technicians perform a complete repair without having to chase parts from multiple places. Additionally, service writers find it easier to explain one line item on an invoice rather than a list of parts. Whatever their reason, they look to Standard and Blue Streak for complete repair solutions.” The post
    • By Mypafway
      Mypafway
      https://mypafway.com/
      Mypafway is a marketplace for online distribution of automotive part information and one of the leading providers of online marketing services for manufacturers, suppliers and retailers. I'm looking for Economic and Strategic Buyers for Mypafway. You can hit me up via email at [email protected] or on social media. Thanks.
    • By CarPartAU
      Are you looking for some stores to buy used or new car parts? If so, then Car Part is the place for you. Rather than sharing a limited list of stores, we at Car Part have come with the list of the best link hidden, please login to view. These sites will connect you with a large number of car part sellers across Australia. Without wasting much time, fill out the form and click send a request button. To know more, visit us today.
    • By mariozhu
      Does anyone need Isuzu auto parts?
