Volkswagen HVAC systems have come a long way in the past 20 years. While the basics of heating and cooling may be the same, the controllers and sensors have improved dramatically. No longer does a driver have to worry about dealing with fogged-up windows or bad smells driving behind a semi-truck.
When a driver sets a temperature in the control head of an HVAC system, what does it mean to the vehicle? Seventy-two degrees could be captured at many different settings depending on the outside temperature, humidity and even the position of the sun. When a passenger then decides that 70 degrees is a better temperature for her zone, things get even more complicated.
Automatic Temperature Control (ATC) systems require a complex array of internal and external sensors that look at the temperature, humidity and quality of the air inside the vehicle.
TEMPERATURE SENSORS
To maintain a preset air temperature, the VW HVAC system will typically have one or more interior air temperature sensors, an ambient (outside) air temperature sensor, and possibly one or two sunload sensors.
Interior air temperature sensors are usually simple, two-wire thermistors that change resistance with temperature, but some are infrared sensors that detect heat from the vehicle’s occupants. This thermistor-type usually has an aspirator tube that pulls air through the sensor when the blower fan is running. Others use a small electric fan for the same purpose. A plugged aspirator tube or inoperative fan will slow the sensor’s response to temperature changes.
Most air temperature sensors have a “negative temperature coefficient,” which means they lose resistance as the temperature goes up. A simple way to check this type of sensor is to use a blow dryer to heat the sensor. The resistance should drop as the sensor warms up.
Ambient air temperature sensors typically have a slow sample rate to even out variations in readings that may be sensed at different vehicle speeds. When the vehicle stops moving, heat can build up quickly around the sensor and could mislead the ATC module into thinking it’s getting hotter outside. So, most ATC modules look at the ambient sensor input only every couple of minutes instead of continuously. On some applications, the ATC module may even ignore input from the ambient sensor when the vehicle is not moving.
There are other temperatures in the various ducts. Also, most systems will have sensors before and after the heater and evaporator cores. These sensors measure the performance of the system.
SOLAR LOAD SENSORS
Many ATC systems also make use of a photodiode solar load sensor on the dash. This sensor allows the ATC system to increase cooling needs when the cabin is being heated by direct sunlight. On vehicles with dual-zone systems, there is often a separate sunload sensor for each side. Sunload sensors receive reference voltage from the ATC module and pass current when the light intensity reaches a certain threshold.
Some ATC systems have additional temperature sensors located on the evaporator and/or compressor to prevent evaporator icing and to regulate the operation of the compressor. Some vehicles also have duct temperature sensors and heater core temperature sensors to further refine temperature control. These are usually found on the dual-zone ATC systems.
HUMIDITY SENSORS
Humidity sensors are capacitance sensors that measure the amount of moisture in the air. The information from the sensor both regulates the volume of air projected onto the windows to reduce misting and manages the humidity levels inside the car to enhance climate comfort. These sensors are typically mounted at the base of the rearview mirror.
From the data delivered by the humidity and temperature sensor, the HVAC system calculates the dew point temperature of the air. Some systems use an infrared sensor that remotely measures the windshield and side window temperatures, as well.
The performance of the sensor can degrade over time and cause the sensor to malfunction and give false readings. If this happens, you will see a code stored in the HVAC module.
AIR-QUALITY SENSOR
Air-quality sensors can prevent harmful gases and unpleasant odors that can get into the car cabin when the vehicle is sitting in heavy traffic, passing through congested areas or driving through tunnels.
The sensor signals the fresh air inlet door/ventilation flap to close when undesirable substances are detected. Volkswagen, Audi and other import nameplate luxury car manufacturers are using this sensor. This sensor is typically mounted behind the grill. Just hot and cold? Not anymore!
    • By dwil4
      What Are OEM Control Modules?
