Brake Rotors: Resurface Or Replace?
Standard Motor Products (SMP) announced new additions to its electronic parking brake actuator program. The company said the parking brake actuator is one of the fastest-growing categories in the automotive aftermarket. Standard offers coverage for both import and domestic vehicles.
Automakers now use electronic parking brake actuators on almost all new vehicles. These have replaced manually operated cable parking brakes. The new parking brake actuator plays a critical role in vehicle safety systems, according to SMP.
SMP: Quality Engineering in Every Parking Brake Actuator
Standard said its parking brake actuators are always 100% new and never remanufactured. They are engineered to match OE performance. These actuators integrate seamlessly with electronic safety systems.
The plug-and-play design simplifies installation. Technicians do not need additional programming. Many actuators also include the correct O-ring and hardware for a complete repair.
New Applications Cover Ford, Jeep, Subaru and More
link hidden, please login to view has introduced new applications for millions of late-model vehicles. Coverage now includes Ford models like the 2023–22 Escape, Bronco Sport, and Maverick. SMP also added the 2024–23 Super Duty trucks. Other new applications include the 2024–22 Jeep Grand Cherokee and Ram ProMaster. Mercedes-Benz vehicles through 2023 and Subaru models through 2024 are now covered.
SMP expanded its program to include additional Mazda, Audi, Volkswagen and General Motors vehicles.
SMP Supports Distributors with Training and Tools
“Standard’s parking brake actuator program is the most comprehensive in the industry,” said John Herc, vice president of vehicle control marketing at
link hidden, please login to view. “In addition to industry-leading coverage, we are providing our distribution partners with training, marketing materials and key category insights to help them capitalize on the growth of this category.” Actuator Catalog Available Online
Standard lists all parking brake actuators in its online catalog at
link hidden, please login to view. The company also supplies listings through electronic catalog providers. The post
5, Pallet
